Camera tracking
This example shows a camera tracking a moving target. You can use the keyboard to move the target being tracked, toggle between different tracking modes, and adjust the tracking offsets.
cd ign-rendering/examples/camera_tracking
./camera_tracking
W: Move box forward
S: Move box backward
A: Rotate box to the left
D: Rotate box to the right
1: Camera tracking only
2: Camera tracking and
following
3: Camera tracking and
following (world frame)
T: Toggle smooth tracking
F: Toggle smooth following
Track offset
u/U: +- 0.1 on X
i/I: +- 0.1 on Y
o/O: +- 0.1 on Z
Follow offset
j/J: +- 0.1 on X
k/K: +- 0.1 on Y
l/L: +- 0.1 on Z
There are two main functions in the Camera class that allow us to track and follow the object:
SetTrackTarget: Set a node for camera to track. The camera will automatically change its orientation to face the target being tracked. If a null node is specified, tracking is disabled. In contrast to SetFollowTarget the camera does not change its position when tracking is enabled.
cam->SetTrackTarget(node, g_trackOffset, false);
SetFollowTarget: Set a node for camera to follow. The camera will automatically update its position to keep itself at the specified offset distance from the target being followed. If a null node is specified, camera follow is disabled. In contrast to SetTrackTarget, the camera does not change its orientation when following is enabled.
cam->SetFollowTarget(node, g_followOffset, false);
