gz/rendering/ogre2/Ogre2SelectionBuffer.hh
16 */
17 #ifndef GZ_RENDERING_OGRE2_OGRE2SELECTIONBUFFER_HH_
18 #define GZ_RENDERING_OGRE2_OGRE2SELECTIONBUFFER_HH_
20 #include <memory>
21 #include <string>
22
23 #include "gz/rendering/config.hh"
24 #include "gz/rendering/ogre2/Export.hh"
25
26 namespace Ogre
27 {
28  class Item;
29  class RenderTarget;
30  class SceneManager;
31 }
32
33 namespace ignition
34 {
35  namespace rendering
36  {
37  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
38  //
39  // forward declaration
40  struct Ogre2SelectionBufferPrivate;
41
47  class IGNITION_RENDERING_OGRE2_VISIBLE Ogre2SelectionBuffer
48  {
55  public: Ogre2SelectionBuffer(const std::string &_cameraName,
56  Ogre2ScenePtr _scene, unsigned int _width,
57  unsigned int _height);
58
61
66  public: Ogre::Item *OnSelectionClick(const int _x, const int _y);
67
75  public: bool ExecuteQuery(const int _x, const int _y, Ogre::Item *&_item,
76  math::Vector3d &_point);
77
81  public: void SetDimensions(unsigned int _width, unsigned int _height);
82
84  public: void Update();
85
87  private: void DeleteRTTBuffer();
88
90  private: void CreateRTTBuffer();
91
93  // private: void CreateRTTOverlays();
94
98  };
99  }
100  }
101 }
102 #endif
Generates a selection buffer object for a given camera. The selection buffer is used of entity select...
Definition: gz/rendering/ogre2/Ogre2SelectionBuffer.hh:48
bool ExecuteQuery(const int _x, const int _y, Ogre::Item *&_item, math::Vector3d &_point)
Perform selection operation and get ogre item and point of intersection.
Ogre::Item * OnSelectionClick(const int _x, const int _y)
Handle on mouse click.
Set dimension of the selection buffer.
void Update()
Call this to update the selection buffer contents.
Ogre2SelectionBuffer(const std::string &_cameraName, Ogre2ScenePtr _scene, unsigned int _width, unsigned int _height)
