gz/rendering/ogre/OgreMaterialSwitcher.hh
16 */
17
18 #ifndef GZ_RENDERING_OGRE_OGREMATERIALSWITCHER_HH_
19 #define GZ_RENDERING_OGRE_OGREMATERIALSWITCHER_HH_
20
21 #include <map>
22 #include <string>
23
24 #include <gz/common/SuppressWarning.hh>
25 #include <gz/math/Color.hh>
26 #include "gz/rendering/config.hh"
27 #include "gz/rendering/ogre/Export.hh"
30
31 namespace ignition
32 {
33  namespace rendering
34  {
35  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
36  //
37  // forward declarations
38  class OgreSelectionBuffer;
39
41  class IGNITION_RENDERING_OGRE_VISIBLE OgreMaterialSwitcher :
42 // Ogre::MaterialManager::Listener isn't a dll-interface class, this may cause
43 // issues
44 #ifdef _MSC_VER
45  #pragma warning(push)
46  #pragma warning(disable:4275)
47 #endif
48  public Ogre::MaterialManager::Listener,
49 #ifdef _MSC_VER
50  #pragma warning(pop)
51 #endif
52  Ogre::RenderTargetListener
53  {
56
59
63  const gz::math::Color &_color) const;
64
66  public: void Reset();
67
78  public: virtual Ogre::Technique *handleSchemeNotFound(
79  uint16_t _schemeIndex, const Ogre::String &_schemeName,
80  Ogre::Material *_originalMaterial, uint16_t _lodIndex,
81  const Ogre::Renderable *_rend);
82
86  public: virtual void preRenderTargetUpdate(
87  const Ogre::RenderTargetEvent &_evt);
88
92  public: virtual void postRenderTargetUpdate(
93  const Ogre::RenderTargetEvent &_evt);
94
96  private: gz::math::Color currentColor;
97
99  private: std::string lastEntity;
100
102  private: Ogre::Technique *lastTechnique = nullptr;
103
107  private: std::map<unsigned int, std::string> colorDict;
109
112  private: void NextColor();
113
116  public: friend class OgreSelectionBuffer;
117
119  private: Ogre::Technique *plainTechnique = nullptr;
120
122  private: Ogre::Technique *overlayTechnique = nullptr;
123  };
124  }
125  }
126 }
127 #endif
Helper class to assign unique colors to renderables.
Definition: gz/rendering/ogre/OgreMaterialSwitcher.hh:53
void Reset()
Reset the color value incrementor.
virtual void postRenderTargetUpdate(const Ogre::RenderTargetEvent &_evt)
Ogre's post render update callback.
std::string EntityName(const gz::math::Color &_color) const
Get the entity with a specific color.
virtual void preRenderTargetUpdate(const Ogre::RenderTargetEvent &_evt)
Ogre's pre render update callback.
virtual Ogre::Technique * handleSchemeNotFound(uint16_t _schemeIndex, const Ogre::String &_schemeName, Ogre::Material *_originalMaterial, uint16_t _lodIndex, const Ogre::Renderable *_rend)
Ogre callback that assigns colors to new renderables when the requested scheme is not found.
Generates a selection buffer object for a given camera. The selection buffer is used of entity select...
Definition: gz/rendering/ogre/OgreSelectionBuffer.hh:48
