gz/rendering/ogre/OgreRTShaderSystem.hh
17 #ifndef GZ_RENDERING_OGRE_OGRERTSHADERSYSTEM_HH_
18 #define GZ_RENDERING_OGRE_OGRERTSHADERSYSTEM_HH_
20 #include <memory>
21 #include <string>
22
23 #include <gz/common/SingletonT.hh>
26 #include "gz/rendering/ogre/Export.hh"
27
28 namespace ignition
29 {
30  namespace rendering
31  {
32  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
33  //
34  // forward declaration
35  class OgreRTShaderSystemPrivate;
36
39
45  class IGNITION_RENDERING_OGRE_VISIBLE OgreRTShaderSystem :
46  public common::SingletonT<OgreRTShaderSystem>
47  {
50  public: enum LightingModel
51  {
61  SSLM_NormalMapLightingObjectSpace
62  };
63
65  private: OgreRTShaderSystem();
66
68  private: virtual ~OgreRTShaderSystem();
69
73  public: bool Init();
74
76  public: void Fini();
77
79  public: void Clear();
80
83  public: void AddScene(OgreScenePtr _scene);
84
87  public: void RemoveScene(OgreScenePtr _scene);
88
91  public: void RemoveScene(const std::string &_scene);
92
94  public: void UpdateShaders();
95
98  public: void AttachEntity(OgreSubMesh *_vis);
99
102  public: void DetachEntity(OgreSubMesh *_vis);
103
107  public: static void AttachViewport(Ogre::Viewport *_viewport,
108  OgreScenePtr _scene);
109
113  public: static void DetachViewport(Ogre::Viewport *_viewport,
114  OgreScenePtr _scene);
115
118  public: void SetPerPixelLighting(bool _set);
119
122  public: void RemoveShaders(OgreSubMesh *_subMesh);
123
126  public: void GenerateShaders(OgreSubMesh *_subMesh);
127
130  public: void ApplyShadows(OgreScenePtr _scene);
131
134  public: void RemoveShadows(OgreScenePtr _scene);
135
138  public: Ogre::PSSMShadowCameraSetup *PSSMShadowCameraSetup() const;
139
144  private: bool Paths(std::string &_coreLibsPath,
145  std::string &_cachePath);
146
151  public: bool SetShadowTextureSize(const unsigned int _size);
152
155  public: unsigned int ShadowTextureSize() const;
156
159  public: bool IsInitialized() const;
160
169  public: void Update();
170
172  private: friend class common::SingletonT<OgreRTShaderSystem>;
173
176  };
178  }
179  }
180 }
181 #endif
Implements Ogre's Run-Time Shader system.
Definition: gz/rendering/ogre/OgreRTShaderSystem.hh:47
void Fini()
Finalize the shader system.
Remove and entity.
static void AttachViewport(Ogre::Viewport *_viewport, OgreScenePtr _scene)
Set a viewport to use shaders.
Get the shadow texture size.
LightingModel
The type of lighting.
Definition: gz/rendering/ogre/OgreRTShaderSystem.hh:51
@ SSLM_PerPixelLighting
Per-Pixel lighting: best look.
Definition: gz/rendering/ogre/OgreRTShaderSystem.hh:55
@ SSLM_NormalMapLightingTangentSpace
Normal Map lighting: lighting calculations have been stored in a light map (texture) using tangent sp...
Definition: gz/rendering/ogre/OgreRTShaderSystem.hh:58
@ SSLM_PerVertexLighting
Per-Vertex lighting: best performance.
Definition: gz/rendering/ogre/OgreRTShaderSystem.hh:53
Update the shaders. This should not be called frequently.
Get if RTShaderSystem is initialized or not.
Set the shadow texture size.
Set the lighting model to per pixel or per vertex.
Remove shadows from a scene.
Remove a scene.
Remove a scene.
Set an Ogre::Entity to use RT shaders.
void Clear()
Clear the shader system.
static void DetachViewport(Ogre::Viewport *_viewport, OgreScenePtr _scene)
Set a viewport to not use shaders.
Add a scene manager.
bool Init()
Initialize the run time shader system.
Generate shaders for an entity.
Apply shadows to a scene.
Ogre::PSSMShadowCameraSetup * PSSMShadowCameraSetup() const
Get the Ogre PSSM Shadows camera setup.
Definition: gz/rendering/ogre/OgreMesh.hh:106
