gz/rendering/ogre/OgreRenderTargetMaterial.hh
2  * Copyright (C) 2017 Open Source Robotics Foundation
17 #ifndef GZ_RENDERING_OGRE_OGRRENDERTARGETMATERIAL_HH_
18 #define GZ_RENDERING_OGRE_OGRRENDERTARGETMATERIAL_HH_
20 #include <vector>
21
22 #include "gz/rendering/config.hh"
25 #include "gz/rendering/ogre/Export.hh"
26
27 // Ogre::MaterialManager::Listener isn't a dll-interface class, this may cause
28 // issues
29 #ifdef _MSC_VER
30  #pragma warning(push)
31  #pragma warning(disable:4275)
32 #endif
33
34 namespace ignition
35 {
36  namespace rendering
37  {
38  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
39  //
52  class IGNITION_RENDERING_OGRE_VISIBLE OgreRenderTargetMaterial :
53  public Ogre::RenderTargetListener,
54  public Ogre::MaterialManager::Listener
55  {
61  Ogre::RenderTarget *_renderTarget, Ogre::Material *_material);
62
65
69  private: virtual void preRenderTargetUpdate(
70  const Ogre::RenderTargetEvent &_evt) override;
71
75  private: virtual void postRenderTargetUpdate(
76  const Ogre::RenderTargetEvent &_evt) override;
77
88  public: virtual Ogre::Technique *handleSchemeNotFound(
89  uint16_t _schemeIndex, const Ogre::String &_schemeName,
90  Ogre::Material *_originalMaterial, uint16_t _lodIndex,
91  const Ogre::Renderable *_rend) override;
92
94  private: OgreScenePtr scene;
95
97  private: Ogre::RenderTarget *renderTarget;
98
100  private: Ogre::Material *material;
101
103  private: Ogre::String schemeName;
104  };
105  }
106  }
107 }
108
109 #ifdef _MSC_VER
110  #pragma warning(pop)
111 #endif
112
113 #endif
Causes all objects in a scene to be rendered with the same material when rendered by a given RenderTa...
Definition: gz/rendering/ogre/OgreRenderTargetMaterial.hh:55
virtual Ogre::Technique * handleSchemeNotFound(uint16_t _schemeIndex, const Ogre::String &_schemeName, Ogre::Material *_originalMaterial, uint16_t _lodIndex, const Ogre::Renderable *_rend) override
Ogre callback that assigned same material to all renderables when the requested scheme is not found.
OgreRenderTargetMaterial(OgreScenePtr _scene, Ogre::RenderTarget *_renderTarget, Ogre::Material *_material)
constructor
