Adding system plugins
This tutorial explains how to add plugins to your model to provide extra capabilities to it.
Prerequisites
Make sure to go through the following tutorial first, where you'll learn how to create the vehicle used in this tutorial.
Create a maritime vehicle
Related tutorials
Create System Plugins
Adding a system plugin
This Gazebo tutorial describes what is a system plugin in depth. Intuitively, you can envision a system plugin as a piece of code that modifies the behavior of the simulation when the general physics engine does not exactly capture your needs. In our example, our turtle does not move because it's configured as a static model. Let's see what happens if you remove that tag.
Modify your ~/gazebo_maritime/models/my_turtle/model.sdf and remove the line <static>true</static>. Then launch the simulation:
gz sim ~/gazebo_maritime/models/my_turtle/model.sdf
Hit the play button and you'll see how your turtle falls into the void. Perhaps not what you expected but this is completely normal. Gazebo thinks that your turtle is in the air without any support underneath. Then, gravity makes your turtle to free fall forever.
If we want to simulate that our turtle floats like if it was in the water, we'll need to attach a custom buoyancy plugin to our world. This buoyancy plugin already exists in Gazebo, we only need to load it.
Now, run Gazebo with the provided buoyant_turtle.sdf world and you'll see how your turtle does not sink anymore.
mkdir -p ~/gazebo_maritime/worlds
wget https://raw.githubusercontent.com/gazebosim/gz-sim/gz-sim10/tutorials/files/adding_system_plugins/buoyant_turtle.sdf -O ~/gazebo_maritime/worlds/buoyant_turtle.sdf
export GZ_SIM_RESOURCE_PATH=:$HOME/gazebo_maritime/models
gz sim -r ~/gazebo_maritime/worlds/buoyant_turtle.sdf
The turtle now stays floating with an oscillating movement up and down.
You just added buoyancy to your model! As a general rule, a maritime model will need at least two system plugins:
  1. Buoyancy
  2. Hydrodynamics
As you have experienced, the buoyancy plugin generates an upthrust opposing some weight of the model. Your model could have positive, neutral or negative buoyancy. You'll be able to tune that aspect of your model later.
The hydrodynamics plugin models the force and torque that the vehicle experiences when moving within a fluid. Intuitively, the hydrodynamics plugin generates drag opposing the movement of the vehicle. If your model does not have hydrodynamics, it will behave as if there's no resistance.
For the sake of illustrating the effect of hydrodynamics, let's attach a simple controller to our turtle and move it without hydrodynamics. Keep in mind that the goal is to move the model one meter and stop it.
Uncomment the following block from buoyant_turtle.sdf:
<plugin filename="gz-sim-trajectory-follower-system"
name="gz::sim::systems::TrajectoryFollower">
<link_name>base_link</link_name>
<force>0.2</force>
<torque>0.01</torque>
<range_tolerance>0.1</range_tolerance>
<waypoints>
<waypoint>1 0</waypoint>
</waypoints>
And run Gazebo:
As you just observed, we failed in our goal and the turtle behaved as if it was moving on ice. Now, let's add hydrodynamics.
First, add <fluid_added_mass> to the base_link's <inertial> element in your model.sdf to account for the inertia of the surrounding fluid:
<fluid_added_mass>
<xx>0.04876161</xx>
<yy>1.26324739</yy>
<zz>1.26324739</zz>
<qq>0.3346</qq>
<rr>0.3346</rr>
</fluid_added_mass>
Then, uncomment the following block from buoyant_turtle.sdf to add hydrodynamic damping:
filename="gz-sim-hydrodynamics-system"
name="gz::sim::systems::Hydrodynamics">
<xUabsU>-0.62282</xUabsU>
<xU>-5</xU>
<yVabsV>-60.127</yVabsV>
<yV>-5</yV>
<zWabsW>-6.0127</zWabsW>
<zW>-100</zW>
<kPabsP>-0.001916</kPabsP>
<kP>-1</kP>
<mQabsQ>-6.32698957</mQabsQ>
<mQ>-1</mQ>
<nRabsR>-6.32698957</nRabsR>
<nR>-1</nR>
And run Gazebo:
Now, when our simple trajectory controller reaches its target and stops applying force, the turtle stops moving acting like the fluid decelerates its motion. Additionally you can notice how the up and down oscillations are also damped by the effect of the hydrodynamics.
The hydrodynamics are also configurable with its SDF parameters but we'll talk about configuration in a separate tutorial.
