DriveToPoseController Class Reference
DriveToPoseController is a simple proportional controller that is attached to a model to move it by giving a pose in Gazebo's world coordinate system. This is not a standalone plugin, and requires the DiffDrive and OdometryPublisher plugins respectively. More...
#include <DriveToPoseController.hh>
 DriveToPoseController ()
 ~DriveToPoseController () override=default
 Configure the system.
The plugin has the following tags:
  • <linear_p_gain>: (Optional) Proportional gain for the linear velocity controller | Default: 1.0
  • <angular_p_gain>: (Optional) Proportional gain for the angular velocity controller | Default: 2.0
  • <linear_deviation>: (Optional) Allowable linear deviation (in meters) from the desired coordinate | Default: 0.1
  • <angular_deviation>: (Optional) Allowable angular deviation (in rad) from the desired orientation | Default: 0.05
◆ DriveToPoseController()
◆ ~DriveToPoseController()
~DriveToPoseController ( )
overridedefault
◆ PostUpdate()
