Gazebo on HPC clusters
This tutorial should help debugging and resolving the following problem: I run Gazebo via Apptainer/Singularity on an HPC cluster and adding rendering sensors like cameras leads to a crash or they do not work (provide no or black output).
Prerequisites
You have a Singularity/Apptainer image with Gazebo (and possibly ROS 2). Let's call it image.sif.
You work on an HPC (High-performance Computing) cluster such as university or national HPC centers. These clusters usually do not support Docker for security reasons and support Singularity/Apptainer instead. Some ideas from this answer may be applicable to Docker, too, but it is not a goal of this answer to provide support for Docker users.
Apptainer == Singularity for this tutorial. There are minor differences between reasonably new versions of these frameworks - but these are not important here (Singularity at least version 3.x, Apptainer any version). Since Apptainer installs command singularity for backwards compatibility, we'll be using singularity command here, but Apptainer users can substitute it for apptainer if they want.
Your HPC cluster has nodes with GPUs and you have access to them. These GPUs are capable of rendering. The author of this tutorial is not sure if the specialized "AI accelerators" like AMD MI300X and similar are capable of rendering at all. But the normal NVidia datacenter cards like A100, B200, V100 and similar are okay. Check the GPU type with nvidia-smi command run on a GPU node.
The HPC cluster runs some kind of task allocator that can give you time-limited access to some node with requested resources. The tutorial author's cluster uses SLURM, so we'll use SLURM commands here (salloc, srun etc.). But theoretically, this guide should be independent from the task allocation engine. For debugging purposes, it is better if the cluster provides interactive sessions. But even if it only supports batch sessions, this should be doable, it would just take more time to debug via batch jobs.
Let's assume the cluster partition with GPUs and interactive access is called gpufast and the partition with non-interactive GPU access is gpu.
We also assume the home directory of your user is shared between the cluster login node and the compute nodes. I.e. all files in your home folder are accessible both from the login node and from within allocated tasks running on nodes.
Your Gazebo world may be using either ogre or ogre2 render engines, but ogre2 provides more options, so it is suggested to use that. It should be configured in the Sensors system. You can also pass --render-engine ogre2 on the Gazebo command line to override the value specified in the world file.
Gazebo can render using 2 backends on Linux: GLX or EGL. GLX is the older one, supported by both ogre and ogre2 render engines. GLX needs a running X11 server and it uses its GPU to do the rendering. Running a HW-accelerated X11 server yourself is a bit nontrivial, but doable, as we'll show later. EGL is the newer backend and it is only supported by ogre2 render engine and only for server-side rendering (i.e. it cannot be used for GUI). EGL is selected by the --headless-rendering flag of Gazebo server. EGL works with devices /dev/dri/card? and /dev/dri/renderD???. Each pair of these files belongs to one GPU. Gazebo uses an autoselection algorithm to choose which GPU will be used (it takes the first one capable of creating an EGL context). This guide shows how the GPU can be selected explicitly.
To use EGL, you need read-write access to both /dev/dri/card? and /dev/dri/renderD??? devices. To check that, run the following command:
user@cluster$ srun -p gpufast--gres=gpu:1 --pty bash -i
user@gpu-node-1$ for f in /dev/dri/*; do [ -r "$f" ] && [ -w "$f" ] && echo "OK $f" || echo "NOK $f"; done
Even if you see some NOKs, you can try following this guide. SLURM uses some other magic to allow access (cgroups).
Note
All the following approaches use gz sim -s command to test the rendering. It might be easier for you to test it with glxgears instead, which is a simple binary that should just show rotating cog wheels rendered by the GPU. This will work with all further described approaches, except approach 3 (--headless-rendering). To use glxgears, you need to install package mesa-utils (on Debian-based systems) or glx-utils (on Fedora-based systems) inside your image. Then, instead of gz sim -v4 -r -s sensors_demo.sdf, type glxgears -info | cut -c -80 and look at the value of GL_RENDERER. llvmpipe is software rendering (slow), anything else should be GPU-accelerated.
The approaches are ordered by the simplicity of their use/setup if they work. However, most HPC clusters will probably not support Approach 1 and 2, so you can also start with Approach 3 first and then go to 1 and 2 if it doesn't work.
Approach 1: Initial test
Note
Do not try to run GUI on the cluster unless the server-only part works. It would only complicate things. To run only Gazebo server, make sure flag -s is in the gz sim command line (and -g is not).
This tests Gazebo in GLX mode connected to an existing X server.
Try directly running Gazebo on the GPU node. For easier testing and to rule-out ROS complexity, use the sensors_demo.sdf world that comes preinstalled with Gazebo. If you don't have it, just download it e.g. to your home folder and provide an absolute path to the file instead of simply sensors_demo.sdf.
user@gpu-node-1$ singularity exec image.sif bash -c "echo $DISPLAY; gz sim -v4 -s -r sensors_demo.sdf & (gz topic -t /camera -e | cut -c -80) & sleep 30; kill %1; kill %2; sleep 2; kill -9 %1; kill -9 %2"
This tests Gazebo on the interactive GPU partition. Now, let's do the same test on a noninteractive one. Prepare the following job spec into file test.batch:
#!/bin/sh
#SBATCH --time=1 -p gpu --gres=gpu:1
singularity exec image.sif bash -c "gz sim -v4 -s -r sensors_demo.sdf & (gz topic -t /camera -e | cut -c -80) & sleep 30; kill %1; kill %2; sleep 2; kill -9 %1; kill -9 %2"
Of course, replace -p gpu with the name of your non-interactive GPU partition.
Schedule the batch for execution and wait until it is executed. Check test.stdout file for the output.
user@cluster$ sbatch -n1 -o test.stdout test.batch
user@cluster$ tail -F test.stdout
If the commands did not fail, did not print anything red and you see camera messages printed out, rendering is working for you. Now it's time to find out if it is HW-accelerated:
user@cluster$ grep -C2 RENDERER ~/.gz/rendering/ogre2.log
If you see llvmpipe in the output, the rendering is not HW-accelerated and you should keep following this guide (unless you're happy with slower rendering). If the output contains NVidia (or AMD), tadaa, you have a working HW-accelerated rendering.
But usually, you'll see some kind of error like:
[Err] [Ogre2RenderEngine.cc:342] Unable to open display:
terminate called after throwing an instance of 'Ogre::RenderingAPIException'
what(): OGRE EXCEPTION(3:RenderingAPIException): Couldn't open X display in GLXGLSupport::getGLDisplay at /var/lib/jenkins/workspace/ogre-2.1-debbuilder/repo/RenderSystems/GL3Plus/src/windowing/GLX/OgreGLXGLSupport.cpp (line 789)
Explanation why this worked: The cluster probably starts an X server for each GPU node allocation and gives you access to this X server (via $DISPLAY variable). Not many clusters do this. Some do it e.g. only for the interactive partitions (like the OP's one) so the first set of commands works, but the latter does not.
Approach 2: Add --nv switch
This tests Gazebo in GLX mode connected to an existing X server, passing –nv to Singularity.
Now it's time to get a bit further and try running Singularity with the --nv switch which basically adds some GPU-related host libraries to the container. If you're on AMD GPUs, you should use --rocm instead, but that is not tested. Contributions are welcome!
Test with almost the same command, just add --nv to singularity command:
user@gpu-node-1$ singularity exec --nv image.sif bash -c "echo $DISPLAY; gz sim -v4 -s -r sensors_demo.sdf & (gz topic -t /camera -e | cut -c -80) & sleep 30; kill %1; kill %2; sleep 2; kill -9 %1; kill -9 %2"
Also, try it on the non-interactive partition, adjusting test.batch appropriately.
What can happen if the node's OS is much newer than the OS inside your image, is you'll get errors with GLIBC version mismatch. See https://github.com/apptainer/apptainer/issues/945#issuecomment-2096052536 for a workaround if that's your case.
If both interactive and non-interactive commands work for you in this case, you are done (again, verify RENDERER in ogre2.log).
Explanation why this worked: Most Singularity images do not install proprietary NVidia drivers inside. Instead, they rely on the host drivers, and the --nv switch bind-mounts all files related to the host drivers inside the container. So if there is a running X11 server, the programs from container can use it.
Approach 3: Try --headless-rendering
This tests Gazebo in EGL mode using autodetected GPU, passing –nv to Singularity.
This is the mode described in tutorial Headless Rendering.
If GLX does not work, let's try EGL backend:
user@cluster$ srun -p gpufast --gres=gpu:1 --pty bash -i
user@gpu-node-1$ singularity exec --nv image.sif bash -c "gz sim -v4 -s -r --headless-rendering sensors_demo.sdf & (gz topic -t /camera -e | cut -c -80) & sleep 30; kill %1; kill %2; sleep 2; kill -9 %1; kill -9 %2"
And, again, try the same on a non-interactive partition.
Check RENDERER in ogre2.log again.
You can also have a more detailed look into ~/.gz/rendering/ogre2.log. It contains two parts. In the first part, Gazebo is probing the available GLX and EGL rendering devices. Here you can see whether Gazebo correctly detects your GPU. You can ignore the GLX errors as we've verified GLX doesn't work. Also, some EGL devices might occur multiple times, e.g. in this example /dev/dri/card2 appears as EGL_NV_device_cuda and EGL_EXT_device_drm. It is okay if just one of the two "views" of the device work.
01:13:59: OpenGL 3+ Rendering Subsystem created.
01:13:59: OGRE EXCEPTION(3:RenderingAPIException): Couldn't open X display in GLXGLSupport::getGLDisplay at ./.obj-x86_64-linux-gnu/gz_ogre_next_vendor-prefix/src/gz_ogre_next_vendor/RenderSystems/GL3Plus/src/windowing/GLX/OgreGLXGLSupport.cpp (line 808)
01:13:59: GLX raised an exception. Won't be available. Is X11 running?
01:13:59: Found Num EGL Devices: 5
01:13:59: EGL Device: EGL_NV_device_cuda EGL_EXT_device_drm EGL_EXT_device_drm_render_node EGL_EXT_device_query_name EGL_EXT_device_persistent_id #0 /dev/dri/card2
01:13:59: Trying to init device: EGL_NV_device_cuda EGL_EXT_device_drm EGL_EXT_device_drm_render_node EGL_EXT_device_query_name EGL_EXT_device_persistent_id #0 /dev/dri/card2...
01:13:59: Created GL 4.5 context for device EGL_NV_device_cuda EGL_EXT_device_drm EGL_EXT_device_drm_render_node EGL_EXT_device_query_name EGL_EXT_device_persistent_id #0 /dev/dri/card2
01:13:59: Destroying device: EGL_NV_device_cuda EGL_EXT_device_drm EGL_EXT_device_drm_render_node EGL_EXT_device_query_name EGL_EXT_device_persistent_id #0 /dev/dri/card2...
01:13:59: EGL Device: EGL_NV_device_cuda EGL_EXT_device_drm EGL_EXT_device_drm_render_node EGL_EXT_device_query_name EGL_EXT_device_persistent_id #1 /dev/dri/card3
01:13:59: Trying to init device: EGL_NV_device_cuda EGL_EXT_device_drm EGL_EXT_device_drm_render_node EGL_EXT_device_query_name EGL_EXT_device_persistent_id #1 /dev/dri/card3...
01:13:59: Created GL 4.5 context for device EGL_NV_device_cuda EGL_EXT_device_drm EGL_EXT_device_drm_render_node EGL_EXT_device_query_name EGL_EXT_device_persistent_id #1 /dev/dri/card3
01:13:59: Destroying device: EGL_NV_device_cuda EGL_EXT_device_drm EGL_EXT_device_drm_render_node EGL_EXT_device_query_name EGL_EXT_device_persistent_id #1 /dev/dri/card3...
01:13:59: EGL Device: EGL_EXT_device_drm EGL_EXT_device_drm_render_node #2 /dev/dri/card2
01:13:59: Trying to init device: EGL_EXT_device_drm EGL_EXT_device_drm_render_node #2 /dev/dri/card2...
01:13:59: OGRE EXCEPTION(3:RenderingAPIException): eglInitialize failed for device EGL_EXT_device_drm EGL_EXT_device_drm_render_node #2 /dev/dri/card2 in EGLSupport::getGLDisplay at ./.obj-x86_64-linux-gnu/gz_ogre_next_vendor-prefix/src/gz_ogre_next_vendor/RenderSystems/GL3Plus/src/windowing/EGL/PBuffer/OgreEglPBufferSupport.cpp (line 320)
01:13:59: Destroying device: EGL_EXT_device_drm EGL_EXT_device_drm_render_node #2 /dev/dri/card2...
01:13:59: EGL Device: EGL_EXT_device_drm EGL_EXT_device_drm_render_node #3 /dev/dri/card3
01:13:59: Trying to init device: EGL_EXT_device_drm EGL_EXT_device_drm_render_node #3 /dev/dri/card3...
01:13:59: OGRE EXCEPTION(3:RenderingAPIException): eglInitialize failed for device EGL_EXT_device_drm EGL_EXT_device_drm_render_node #3 /dev/dri/card3 in EGLSupport::getGLDisplay at ./.obj-x86_64-linux-gnu/gz_ogre_next_vendor-prefix/src/gz_ogre_next_vendor/RenderSystems/GL3Plus/src/windowing/EGL/PBuffer/OgreEglPBufferSupport.cpp (line 320)
01:13:59: Destroying device: EGL_EXT_device_drm EGL_EXT_device_drm_render_node #3 /dev/dri/card3...
01:13:59: EGL Device: EGL_MESA_device_software EGL_EXT_device_drm_render_node #4
01:13:59: Trying to init device: EGL_MESA_device_software EGL_EXT_device_drm_render_node #4...
01:13:59: Created GL 4.5 context for device EGL_MESA_device_software EGL_EXT_device_drm_render_node #4
01:13:59: Destroying device: EGL_MESA_device_software EGL_EXT_device_drm_render_node #4...
01:13:59: Plugin successfully installed
In the second part, you should see Starting EGL Subsystem. This confirms Gazebo uses the EGL backend. Right beneath this line, you should see which device is used for rendering:
01:13:59: ******************************
*** Starting EGL Subsystem ***
01:13:59: GL3PlusRenderSystem::_createRenderWindow "OgreWindow(0)_0", 1x1 windowed miscParams: FSAA=0 border=none contentScalingFactor=1.000000 gamma=Yes parentWindowHandle=0 stereoMode=Frame Sequential
01:13:59: GL Version = 4.5.0.0
01:13:59: GL_VERSION = 4.5.0 NVIDIA 550.120
01:13:59: GL_VENDOR = NVIDIA Corporation
01:13:59: GL_RENDERER = NVIDIA GeForce RTX 3090/PCIe/SSE2
If you see EGL_MESA_device_software or llvmpipe in this part, it means EGL works, but is not HW-accelerated. Look in the first section with probing to find out what problems are preventing to use a HW device.
Explanation why this worked: --headless-rendering switches Gazebo to the EGL backend.
Approach 4: Use VirtualGL and a dummy X server
This tests Gazebo in GLX mode using a selected GPU, connected to a dummy X server.
Generally, one of the 3 above approaches should work for you if your cluster allows rendering at all. However, some GPUs have problems with some ways of rendering, while working fine when done differently. Also, this allows you to explicitly select the GPU to be used. Last, this method can be used to run even Gazebo GUI on the cluster (if you e.g. want to record the GUI camera programmatically).
First, you will need VirtualGL inside your image. Download a .deb or .rpm from https://github.com/VirtualGL/virtualgl/releases and sudo apt install name_of.deb or sudo rpm -i name_of.deb. You will also need an X server. You can install Xvfb (sudo apt install xvfb), which only provides the rendering backbone, but the actual rendered on-screen images are thrown away (sensor rendering happens in off-screen buffers, so sensors are not affected). Or you can install TurboVNC (from https://github.com/TurboVNC/turbovnc/releases), which is an X server that provides a VNC interface to which you can connect with any remote desktop client. Also install mesa-utils/glx-utils if you haven't yet.
Rebuild the image and you should be able to run this command:
user@gpu-node-1$ singularity exec image.sif xvfb-run -a glxgears -info | cut -c -80
This does not yet mean Gazebo HW-accelerated rendering works, because this only tests software (non-accelerated) rendering.
Now you have to figure out which of the /dev/dri/card? EGL devices is the card allocated to you by the cluster. The easiest thing is just trial and error (you can use any of the card devices for which the command does not fail):
user@gpu-node-1$ singularity exec --nv image.sif bash -c 'for f in /dev/dri/card*; do vglrun +v -d "$f" xvfb-run -a glxgears -info | cut -c -80; done'
Of course, there are more sophisticated methods. Here is an example Bash script that translates IDs of the cards as shown by nvidia-smi to the card? and renderD??? devices:
#!/bin/bash -e
NVIDIA_SMI_ID=${1:-0}
minor=$(nvidia-smi -q -x -i $NVIDIA_SMI_ID 2>/dev/null | grep minor | cut -d > -f2 | cut -d < -f1)
if [ -z "$minor" ]; then
echo "NVIDIA_SMI_ID=${NVIDIA_SMI_ID} does not denote an accessible GPU. Please, pass one of the IDs displayed by nvidia-smi." >&2
exit 1
fi
echo "NVIDIA_SMI_ID=${NVIDIA_SMI_ID}"
pci_id=$(nvidia-smi -i $NVIDIA_SMI_ID --query-gpu=pci.bus_id --format=noheader,csv | tail -c+5 | tr '[:upper:]' '[:lower:]')
nvidia=/dev/nvidia$minor
card=$(ls /sys/bus/pci/devices/${pci_id}/drm/ | grep card)
render=$(ls /sys/bus/pci/devices/${pci_id}/drm/ | grep renderD)
echo "NVIDIA_DEVICE=$nvidia"
echo "DRI_DEVICE=$card"
echo "RENDER_NODE=$render"
If you find a working card (let's call it cardN), you can run Gazebo (do not logout from the GPU node, otherwise the number of the card can change!) :
# on the same GPU node where you determined the available card
user@gpu-node-1$ singularity exec --nv image.sif bash -c "vglrun +v -d /dev/dri/cardN xvfb-run -a gz sim -v4 -s -r sensors_demo.sdf & (gz topic -t /camera -e | cut -c -80) & sleep 30; kill %1; kill %2; sleep 2; kill -9 %1; kill -9 %2"
Testing on the non-interactive partition looks the same, but you have to figure out the available card device automatically, e.g. using the Bash script above.
If you want to actually see the graphical output (if running Gazebo with GUI), use TurboVNC instead of Xvfb (it will print the VNC port at the start):
user@gpu-node-1$ singularity exec --nv image.sif /opt/TurboVNC/bin/vncserver -fg -log /dev/stdout -xstartup "vglrun +v -d /dev/dri/cardN gz sim -v4 -r sensors_demo.sdf & (gz topic -t /camera -e | cut -c -80) & sleep 30; kill %1; kill %2; sleep 2; kill -9 %1; kill -9 %2"
This, of course, assumes you have direct network access to the cluster nodes and any ports you open on them.
Again, verify that Gazebo outputs no red text and check RENDERER in ogre2.log.
Explanation why this worked: VirtualGL redirects GLX calls to a specified EGL device (using some very low-level tricks). However, the app (Gazebo) still thinks it's using GLX, so it needs an X server. That's the place for xvfb or TurboVNC.
Approach 5: --nv is broken, but there is hope
On some systems, the --nv switch does not add all files necessary for working with VirtualGL inside a container. You can try to fix that and bind-mount these manually. This should help with approaches 2, 3 and 4.
Someone had to mount these in addition to the default:
--bind /usr/lib64/libEGL_nvidia.so.0 --bind /usr/share/glvnd/egl_vendor.d/
It seems that Apptainer 1.4.0 and newer should already have this fixed. But if you have an older version, these manual binds will do the job.
It is possible that your system has other files that will need to be mounted. You can try to search for them manually around the files that are mentioned in /etc/singularity/nvliblist.conf. Or, if your cluster provides nvidia-container-cli command, you can try to extract the list of files from nvidia-container-cli list. But the author of the tutorial does not have access to a cluster with this command, so this is untested (there is even --nvccli flag in addition to --nv in Apptainer that could help with this).
Low-Level Last Resort (only for adventurous or desperate)
Alternatively, you can utilize strace and try running VirtualGL directly on the GPU node outside Singularity container. However, this approach is quite complicated for many users.
If you can get strace working directly on the GPU node (not inside Singularity), you can also unpack packages mesa-utils/glx-utils, xvfb and VirtualGL to some of your writable locations and try to run them directly on the node. This will rule-out problems introduced by Singularity.
First, download .deb or .rpm files of the packages for the version of OS that is running on the GPU node (use cat /etc/*-release to figure it out). To unpack a .deb file, run dpkg-deb -xv file.deb . . To unpack an .rpm file, run rpm2cpio file.rpm | cpio -idmv or rpm2cpio file.rpm | zstd -d | cpio -idmv .
Next, add the unpacked lib and lib64 folders to LD_LIBRARY_PATH and bin folders to PATH. Then you can use strace, xvfb, virtualgl and glxgears to test which NVidia files are loaded:
LD_LIBRARY_PATH="`pwd`/usr/lib64:$LD_LIBRARY_PATH" PATH="`pwd`/usr/bin:$PATH" strace -f -e openat ./opt/VirtualGL/bin/vglrun +v -d /dev/dri/card1 xvfb-run -a glxgears -info 2>&1 | grep -v ENOENT | grep -i nv
The command may fail for various reasons, you might need to download recursive dependencies and so on. If your cluster uses e.g. the Lmod modules system, you can provide a part of the dependencies just by typing module load X11. If you can get this working, you would get the definitive answer to which files are needed inside the container. If not, you just have to guess. Explanation why this worked: The list of files in nvliblist.conf is just a guess. Some might be missing, some are there and shouldn't. If you finish this list manually by adding --bind mounts of the missing files, you will have a working GLX and EGL system inside the container.
If Nothing Works
If nothing from the above works, it is possible that your cluster has just not configured the GPU resources properly and it doesn't give you the permissions to use the GPUs via the /dev/dri/ files, but only through /dev/nvidia?.
You can try contacting your cluster admins and showing them this link with a suggestion how to reconfigure the resources: https://groups.google.com/g/slurm-users/c/n_oUtvdTC4o/m/r4abS8KMBAAJ . At the time of writing that post, there was no folder /dev/dri/by-path. On recent machines, this folder is present, so it could be even easier to define the resources.
