EntityContextMenuPlugin.hh
16 */
17
18 #ifndef IGNITION_GUI_PLUGINS_ENTITY_CONTEXT_MENU_HH_
19 #define IGNITION_GUI_PLUGINS_ENTITY_CONTEXT_MENU_HH_
20
21 #include <memory>
22
23 #include <gz/common/MouseEvent.hh>
24
25 #include <gz/gui/Plugin.hh>
26
27 #include <gz/rendering/Camera.hh>
28
29 namespace ignition
30 {
31 namespace gazebo
32 {
33  class EntityContextMenuPrivate;
34
37  class EntityContextMenu : public gz::gui::Plugin
38  {
39  Q_OBJECT
40
42  public: EntityContextMenu();
43
45  public: ~EntityContextMenu() override;
46
47  // Documentation inherited
48  public: void LoadConfig(const tinyxml2::XMLElement *_pluginElem) override;
49
50  // Documentation inherited
51  protected: bool eventFilter(QObject *_obj, QEvent *_event) override;
52
56  };
57
58  class EntityContextMenuHandler : public QObject
59  {
60  Q_OBJECT
61
64
68  public: void HandleMouseContextMenu(const common::MouseEvent &_mouseEvent,
69  const rendering::CameraPtr &_camera);
70
75  signals: void ContextMenuRequested(
76  QString _entity, int _mouseX, int _mouseY);
77  };
78
80  class EntityContextMenuItem : public QQuickItem
81  {
82  Q_OBJECT
83
86  public: explicit EntityContextMenuItem(QQuickItem *_parent = nullptr);
87
91  const EntityContextMenuHandler &_entityContextMenuHandler);
92
99  signals: void openContextMenu(QString _entity, int _mouseX, int _mouseY); // NOLINT
100
105  public slots: void OnContextMenuRequested(
106  QString _entity, int _mouseX, int _mouseY);
107  };
108 }
109 }
110
111 #endif
Definition: EntityContextMenuPlugin.hh:59
void HandleMouseContextMenu(const common::MouseEvent &_mouseEvent, const rendering::CameraPtr &_camera)
Handle mouse event for context menu.
void ContextMenuRequested(QString _entity, int _mouseX, int _mouseY)
Signal fired when context menu event is triggered.
A QQUickItem that manages the render window.
Definition: EntityContextMenuPlugin.hh:81
EntityContextMenuItem(QQuickItem *_parent=nullptr)
Signal fired to open context menu Note that the function name needs to start with lowercase in order ...
void OnContextMenuRequested(QString _entity, int _mouseX, int _mouseY)
Qt callback when context menu request is received.
void SetEntityContextMenuHandler(const EntityContextMenuHandler &_entityContextMenuHandler)
Set the entity context menu handler.
This plugin is in charge of showing the entity context menu when the right button is clicked on a vis...
Definition: EntityContextMenuPlugin.hh:38
