Parameters.hh
17
18 #ifndef GZ_GAZEBO_SYSTEMS_MULTICOPTERVELOCITYCONTROL_PARAMETERS_HH_
19 #define GZ_GAZEBO_SYSTEMS_MULTICOPTERVELOCITYCONTROL_PARAMETERS_HH_
20
21 #include <Eigen/Geometry>
22 #include <vector>
23
24 #include "gz/sim/config.hh"
25
26 namespace ignition
27 {
28 namespace gazebo
29 {
32 namespace systems
33 {
34 namespace multicopter_control
35 {
37  struct Rotor
38  {
42  // cppcheck-suppress unusedStructMember
43  double angle;
46  // cppcheck-suppress unusedStructMember
47  double armLength;
50  // cppcheck-suppress unusedStructMember
51  double forceConstant;
54  // cppcheck-suppress unusedStructMember
58  // cppcheck-suppress unusedStructMember
59  int direction;
60  };
61
64
69  {
71  // cppcheck-suppress unusedStructMember
72  double mass;
74  Eigen::Matrix3d inertia;
76  Eigen::Vector3d gravity;
80  };
81
85  {
86  Eigen::Vector3d linearVelocityMean;
87  Eigen::Vector3d linearVelocityStdDev;
88  Eigen::Vector3d angularVelocityMean;
89  Eigen::Vector3d angularVelocityStdDev;
90  };
91
92 } // namespace multicopter_control
93 } // namespace systems
94 } // namespace IGNITION_GAZEBO_VERSION_NAMESPACE
95 } // namespace gazebo
96 } // namespace ignition
97
98 #endif
Noise parameters used when computing frame data. These are all assumed to be gaussian.
Definition: Parameters.hh:85
Definition: Parameters.hh:88
Definition: Parameters.hh:86
Definition: Parameters.hh:87
Definition: Parameters.hh:89
A struct that holds various properties of a rotor.
Definition: Parameters.hh:38
double armLength
The length of the vector going from the center of mass to the rotor.
Definition: Parameters.hh:47
double momentConstant
A constant the multiplies with the rotor's thrust to compute its moment.
Definition: Parameters.hh:55
double angle
The angle formed on the xy plane by the vector going from the the center of mass to the rotor....
Definition: Parameters.hh:43
A constant that multiplies with the square of the rotor's velocity to compute its thrust.
Definition: Parameters.hh:51
int direction
Direction of rotation of the rotor. +1 is counterclockwise and -1 is clockwise.
Definition: Parameters.hh:59
A struct that holds properties of the vehicle such as mass, inertia and rotor configuration....
Definition: Parameters.hh:69
double mass
Total mass of the vehicle.
Definition: Parameters.hh:72
Moment of inertia matrix of the vehicle.
Definition: Parameters.hh:74
RotorConfiguration rotorConfiguration
A collection of Rotor objects that specifiy various properties of the rotors in the vehicle.
Definition: Parameters.hh:79
Gravity vector.
Definition: Parameters.hh:76
