Plot3D.hh
16 */
17
18 #ifndef GZ_GAZEBO_GUI_3DPLOT_HH_
19 #define GZ_GAZEBO_GUI_3DPLOT_HH_
20
21 #include <memory>
22
23 #include <gz/sim/gui/GuiSystem.hh>
24
25 #include "gz/gui/qt.h"
26
27 namespace ignition
28 {
29 namespace gazebo
30 {
31 namespace gui
32 {
33  class Plot3DPrivate;
34
63  {
64  Q_OBJECT
65
67  Q_PROPERTY(
69  READ TargetEntity
70  WRITE SetTargetEntity
71  NOTIFY TargetEntityChanged
72  )
73
74
75  Q_PROPERTY(
76  QString targetName
77  READ TargetName
78  WRITE SetTargetName
79  NOTIFY TargetNameChanged
80  )
81
82
83  Q_PROPERTY(
84  bool locked
85  READ Locked
86  WRITE SetLocked
87  NOTIFY LockedChanged
88  )
89
90
91  Q_PROPERTY(
92  QVector3D offset
93  READ Offset
94  WRITE SetOffset
95  NOTIFY OffsetChanged
96  )
97
98
99  Q_PROPERTY(
100  QVector3D color
101  READ Color
102  WRITE SetColor
103  NOTIFY ColorChanged
104  )
105
106
107  Q_PROPERTY(
108  double minDistance
109  READ MinDistance
110  WRITE SetMinDistance
111  NOTIFY MinDistanceChanged
112  )
113
114
115  Q_PROPERTY(
116  int maxPoints
117  READ MaxPoints
118  WRITE SetMaxPoints
119  NOTIFY MaxPointsChanged
120  )
121
122
123  public: Plot3D();
124
126  public: ~Plot3D() override;
127
128  // Documentation inherited
129  public: void LoadConfig(const tinyxml2::XMLElement *_pluginElem) override;
130
131  // Documentation inherited
132  public: void Update(const UpdateInfo &_info,
133  EntityComponentManager &_ecm) override;
134
137  public: Q_INVOKABLE Entity TargetEntity() const;
138
141  public: Q_INVOKABLE void SetTargetEntity(Entity _entity);
142
144  signals: void TargetEntityChanged();
145
148  public: Q_INVOKABLE QString TargetName() const;
149
152  public: Q_INVOKABLE void SetTargetName(const QString &_name);
153
155  signals: void TargetNameChanged();
156
159  public: Q_INVOKABLE bool Locked() const;
160
163  public: Q_INVOKABLE void SetLocked(bool _locked);
164
166  signals: void LockedChanged();
167
170  public: Q_INVOKABLE QVector3D Offset() const;
171
174  public: Q_INVOKABLE void SetOffset(const QVector3D &_offset);
175
177  signals: void OffsetChanged();
178
181  public: Q_INVOKABLE QVector3D Color() const;
182
185  public: Q_INVOKABLE void SetColor(const QVector3D &_color);
186
188  signals: void ColorChanged();
189
192  public: Q_INVOKABLE double MinDistance() const;
193
197  public: Q_INVOKABLE void SetMinDistance(double _minDistance);
198
200  signals: void MinDistanceChanged();
201
204  public: Q_INVOKABLE int MaxPoints() const;
205
209  public: Q_INVOKABLE void SetMaxPoints(int _maxPoints);
210
212  signals: void MaxPointsChanged();
213
214  // Documentation inherited
215  protected: bool eventFilter(QObject *_obj, QEvent *_event) override;
216
218  private: void ClearPlot();
219
222  private: std::unique_ptr<Plot3DPrivate> dataPtr;
223  };
224 }
225 }
226 }
227
228 #endif
Base class for a GUI System.
Definition: gz/sim/gui/GuiSystem.hh:45
Plot the trajectory of an entity into the 3D scene.
Definition: Plot3D.hh:63
Get the minimum distance between points.
QVector3D offset
XYZ offset to the entity's origin to plot.
Definition: Plot3D.hh:96
bool locked
Whether the plugin is locked on an entity.
Definition: Plot3D.hh:88
Set the offset.
Get the maximum number of points.
Get whether the plugin is currently locked on a target.
Set whether the plugin is currently locked on a target.
void Update(const UpdateInfo &_info, EntityComponentManager &_ecm) override
Update callback called every time the system is stepped. This is called at an Ignition transport thre...
Get the color of the plot.
Notify that the offset has changed.
Get the name of target currently controlled.
Notify that the minimum distance has changed.
Notify that target name has changed.
Set the color of the plot.
Set the target currently controlled.
QString targetName
Target entity scoped name.
Definition: Plot3D.hh:80
Notify that the maximum points has changed.
Entity targetEntity
Target entity.
Definition: Plot3D.hh:72
Set the name of target currently controlled.
Get the target currently controlled.
QVector3D color
Plot line color.
Definition: Plot3D.hh:104
Get the offset in the target's frame.
double minDistance
Minimum distance between plot points.
Definition: Plot3D.hh:112
int maxPoints
Maximum number of total points on the plot.
Definition: Plot3D.hh:120
Set the maximum number of points. If the plot has more than this number, older points start being rem...
void ColorChanged()
Notify that the color has changed.
Set the minimum distance between points. If the target moved less than this distance,...
uint64_t Entity
STL namespace.
Definition: include/gz/sim/Types.hh:39
