ResourceSpawner.hh
16 */
17
18 #ifndef GZ_GAZEBO_GUI_RESOURCE_SPAWNER_HH_
19 #define GZ_GAZEBO_GUI_RESOURCE_SPAWNER_HH_
20
21 #include <qobjectdefs.h>
22 #include <algorithm>
23 #include <memory>
24 #include <string>
25 #include <vector>
26 #include <gz/fuel_tools/ClientConfig.hh>
27 #include <gz/fuel_tools/FuelClient.hh>
28
29 #include <gz/gui/Plugin.hh>
30
31 namespace ignition
32 {
33 namespace gazebo
34 {
35  class ResourceSpawnerPrivate;
36
38  struct Resource
39  {
42
46
49
53
55  // cppcheck-suppress unusedStructMember
56  bool isFuel = false;
57
60  // cppcheck-suppress unusedStructMember
61  bool isDownloaded = false;
62  };
63
66  struct Display
67  {
71
76
80
83  // cppcheck-suppress unusedStructMember
84  bool isFuel = false;
85  };
86
89  class PathModel : public QStandardItemModel
90  {
91  Q_OBJECT
92
94  public: explicit PathModel();
95
97  public: ~PathModel() override = default;
98
101  public: void AddPath(const std::string &_path);
102
105  public: void RemovePath(const std::string &_path);
106
107  // Documentation inherited
108  public: QHash<int, QByteArray> roleNames() const override;
109  };
110
113  class ResourceModel : public QStandardItemModel
114  {
115  Q_OBJECT
116
119  Q_PROPERTY(int totalCount MEMBER gridIndex NOTIFY sizeChanged)
120
121
122  public: explicit ResourceModel();
123
125  public: ~ResourceModel() override = default;
126
129  public: void AddResource(const Resource &_resource);
130
133  public: void AddResources(std::vector<Resource> &_resources);
134
136  public: void Clear();
137
143  public: void UpdateResourceModel(int index, Resource &_resource);
144
145  // Documentation inherited
146  public: QHash<int, QByteArray> roleNames() const override;
147
149  public: signals: void sizeChanged();
150
151  // \brief Index to keep track of the position of each resource in the qml
152  // grid, used primarily to access currently loaded resources for updates.
153  public: int gridIndex = 0;
154  };
155
158  class ResourceSpawner : public gz::gui::Plugin
159  {
160  Q_OBJECT
161
163  public: ResourceSpawner();
164
166  public: ~ResourceSpawner() override;
167
168  // Documentation inherited
169  public: void LoadConfig(const tinyxml2::XMLElement *_pluginElem) override;
170
173  public slots: void OnResourceSpawn(const QString &_sdfPath);
174
178  public: Resource LocalResource(const std::string &_path);
179
182  public: void AddPath(const std::string &_path);
183
189
195
199  public: void Resources(std::vector<Resource> &_resources);
200
204  public: void FilterResources(std::vector<Resource> &_resources);
205
211  public: void SortResources(std::vector<Resource> &_resources);
212
215  public slots: void DisplayResources();
216
220  public slots: void OnPathClicked(const QString &_path);
221
226  public slots: void OnOwnerClicked(const QString &_owner);
227
233  public slots: void OnDownloadFuelResource(const QString &_path,
234  const QString &_name, const QString &_owner, int index);
235
240  public slots: void OnSortChosen(const QString &_sortType);
241
245  public slots: void OnSearchEntered(const QString &_searchKeyword);
246
252  public: void SetThumbnail(const std::string &_thumbnailPath,
253  Resource &_resource);
254
260  public: Q_INVOKABLE void UpdateOwnerListModel(
261  ignition::gazebo::Resource _resource);
262
267  public: Q_INVOKABLE bool AddOwner(const QString &_owner);
268
272  public: Q_INVOKABLE void RemoveOwner(const QString &_owner);
273
276  public: Q_INVOKABLE bool IsDefaultOwner(const QString &_owner) const;
277
280  signals: void resourceSpawnerError(const QString &_errorMsg);
281
284  private: void RunFetchResourceListThread(const std::string &_owner);
285
289  };
290 }
291 }
292
293 #endif
Provides a model by which the resource spawner qml plugin pulls and updates from.
Definition: ResourceSpawner.hh:90
Add a path. param[in] _path The path to be added.
~PathModel() override=default
QHash< int, QByteArray > roleNames() const override
Remove a path. param[in] _path The path to be removed.
Definition: ResourceSpawner.hh:114
void sizeChanged()
Signal used with the totalCount property.
int gridIndex
Definition: ResourceSpawner.hh:153
Updates the resource at the provided index with the values in the passed in resource.
void AddResources(std::vector< Resource > &_resources)
Add a vector of resources to the grid view. param[in] _resource The vector of local resources to be a...
int totalCount
Property used to display the total number of resources associated with an owner.
Definition: ResourceSpawner.hh:119
void Clear()
Clear the current resource model.
Add a resource to the grid view. param[in] _resource The local resource to be added.
Provides interface for communicating to backend for generation of local models.
Definition: ResourceSpawner.hh:159
std::vector< Resource > FuelResources(const std::string &_owner)
Returns the fuel resources as a vector belonging to the passed in owner.
Callback when a sort request is made.
void SetThumbnail(const std::string &_thumbnailPath, Resource &_resource)
Finds a thumbnail on the provided thumbnail path and sets the model's thumbnail path attribute to it,...
Adds a path to the path list model.
Determine if owner is the default owner.
Remove owner from the list of owners whose resources would be fetched from Fuel.
void Resources(std::vector< Resource > &_resources)
Populates the passed in _resources vector with the currently selected group of resources.
void SortResources(std::vector< Resource > &_resources)
Sorts the vector of resources by the previously entered sort method. The sorting types as a string,...
Q_INVOKABLE void UpdateOwnerListModel(ignition::gazebo::Resource _resource)
Called form a download thread to update the GUI's list of resources.
Callback when a resource is selected.
Add owner to the list of owners whose resources would be fetched from Fuel.
void OnDownloadFuelResource(const QString &_path, const QString &_name, const QString &_owner, int index)
Callback when a request is made to download a fuel resource.
Displays the resources to the qml grid abiding by all search and sort criteria.
Callback when a resource path is selected, will clear the currently loaded resources and load the one...
Signal emitted when an error is encountered regarding an owner.
Returns the resource corresponding to the model.config file.
void FilterResources(std::vector< Resource > &_resources)
Filters the vector of resources by the previously entered search keyword.
Callback when a search request is made.
std::vector< Resource > LocalResources(const std::string &_path)
Returns the local resources as a vector located under the passed in path.
Callback when a fuel owner is selected, will clear the currently loaded resources and load the ones b...
Definition: config.hh:56
STL namespace.
Data used by the DisplayData() function to filter and sort the resources to be displayed.
Definition: ResourceSpawner.hh:67
std::string sortMethod
The currently chosen method of sorting, which includes "A - Z", "Z - A", "Most Recent",...
Definition: ResourceSpawner.hh:75
std::string searchKeyword
The currently entered keyword that the user wants to search, empty if there is currently no search qu...
Definition: ResourceSpawner.hh:70
bool isFuel
True if the user is currently observing fuel resources and false if the user is currently observing l...
Definition: ResourceSpawner.hh:84
std::string ownerPath
The name of the owner if the user has Fuel resources chosen, and the name of the local path if the us...
Definition: ResourceSpawner.hh:79
Resource used to update the ResourceModel.
Definition: ResourceSpawner.hh:39
std::string thumbnailPath
The absolute path to the thumbnail of the local model, will be empty if no thumbnail is found.
Definition: ResourceSpawner.hh:52
std::string sdfPath
The absolute path to the sdf corresponding to the local model.
Definition: ResourceSpawner.hh:48
bool isFuel
Bool to indicate if this model is fuel or not.
Definition: ResourceSpawner.hh:56
std::string name
The name of the resource.
Definition: ResourceSpawner.hh:41
std::string owner
The owner of the resource, if the resource is local, owner will be empty.
Definition: ResourceSpawner.hh:45
bool isDownloaded
Bool to indicate if this model has been downloaded or not, will always be false with local models as ...
Definition: ResourceSpawner.hh:61
