gz/sim/Actor.hh
2  * Copyright (C) 2023 Open Source Robotics Foundation
17 #ifndef GZ_GAZEBO_ACTOR_HH_
18 #define GZ_GAZEBO_ACTOR_HH_
20 #include <memory>
21 #include <optional>
22 #include <string>
23
24 #include <gz/math/Pose3.hh>
25
26 #include <gz/utils/ImplPtr.hh>
27
28 #include "gz/sim/config.hh"
30 #include "gz/sim/Export.hh"
31 #include "gz/sim/Types.hh"
32
33 namespace ignition
34 {
35  namespace gazebo
36  {
37  // Inline bracket to help doxygen filtering.
38  inline namespace IGNITION_GAZEBO_VERSION_NAMESPACE {
39  //
59  class IGNITION_GAZEBO_VISIBLE Actor
60  {
63  public: explicit Actor(gazebo::Entity _entity = kNullEntity);
64
67  public: gazebo::Entity Entity() const;
68
71  public: void ResetEntity(gazebo::Entity _newEntity);
72
77  public: bool Valid(const EntityComponentManager &_ecm) const;
78
83  public: std::optional<std::string> Name(
84  const EntityComponentManager &_ecm) const;
85
93  public: std::optional<math::Pose3d> Pose(
94  const EntityComponentManager &_ecm) const;
95
104  public: std::optional<math::Pose3d> TrajectoryPose(
105  const EntityComponentManager &_ecm) const;
106
116  const math::Pose3d &_pose);
117
128  public: std::optional<math::Pose3d> WorldPose(
129  const EntityComponentManager &_ecm) const;
130
135  const std::string &_name);
136
141  const std::chrono::steady_clock::duration &_time);
142
146  public: std::optional<std::string> AnimationName(
147  const EntityComponentManager &_ecm) const;
148
152  public: std::optional<std::chrono::steady_clock::duration> AnimationTime(
153  const EntityComponentManager &_ecm) const;
154
156  IGN_UTILS_IMPL_PTR(dataPtr)
157  };
158  }
159  }
160 }
161 #endif
This class provides wrappers around entities and components which are more convenient and straight-fo...
Definition: gz/sim/Actor.hh:60
std::optional< math::Pose3d > Pose(const EntityComponentManager &_ecm) const
Get the pose of the actor. If the actor has a trajectory, this will only return the origin pose of th...
void SetAnimationTime(EntityComponentManager &_ecm, const std::chrono::steady_clock::duration &_time)
Set the time of animation for this actor.
std::optional< math::Pose3d > TrajectoryPose(const EntityComponentManager &_ecm) const
Get the trajectory pose of the actor. There are two ways that the actor can follow a trajectory: 1) S...
std::optional< std::chrono::steady_clock::duration > AnimationTime(const EntityComponentManager &_ecm) const
Get the time of animation for this actor.
std::optional< std::string > Name(const EntityComponentManager &_ecm) const
Get the actor's unscoped name.
void SetTrajectoryPose(EntityComponentManager &_ecm, const math::Pose3d &_pose)
Set the trajectory pose of the actor. There are two ways that the actor can follow a trajectory: 1) S...
Actor(gazebo::Entity _entity=kNullEntity)
Reset Entity to a new one.
Check whether this actor correctly refers to an entity that has a components::Actor.
std::optional< std::string > AnimationName(const EntityComponentManager &_ecm) const
Get the name of animation used by the actor.
Get the entity which this Actor is related to.
std::optional< math::Pose3d > WorldPose(const EntityComponentManager &_ecm) const
Get the world pose of the actor. This returns the current world pose of the actor computed by gazebo....
void SetAnimationName(EntityComponentManager &_ecm, const std::string &_name)
Set the name of animation to use for this actor.
const Entity kNullEntity
Indicates a non-existant or invalid Entity.
Definition: gz/sim/Entity.hh:61
uint64_t Entity
