include/gz/sim/Types.hh
16 */
17 #ifndef GZ_GAZEBO_TYPES_HH_
18 #define GZ_GAZEBO_TYPES_HH_
20 #include <chrono>
21 #include <cstdint>
22 #include <functional>
23 #include <utility>
24
25 #include "gz/sim/Entity.hh"
26
27 namespace ignition
28 {
29  namespace gazebo
30  {
31  // Inline bracket to help doxygen filtering.
32  inline namespace IGNITION_GAZEBO_VERSION_NAMESPACE {
33  // Forward declarations.
34  class EntityComponentManager;
35
38  struct UpdateInfo
39  {
42  std::chrono::steady_clock::duration simTime{0};
43
46  std::chrono::steady_clock::duration realTime{0};
47
49  std::chrono::steady_clock::duration dt{0};
50
52  // cppcheck-suppress unusedStructMember
53  uint64_t iterations{0};
54
60  // cppcheck-suppress unusedStructMember
61  bool paused{true};
62  };
63
65  enum class ComponentState
66  {
68  NoChange = 0,
69
72  PeriodicChange = 1,
73
77  OneTimeChange = 2
78  };
79
85  using ComponentId = int;
86
90  using ComponentTypeId = uint64_t;
91
98
100  using EntityQueryCallback = std::function<void (const UpdateInfo,
102
104  static const ComponentId kComponentIdInvalid = -1;
105
107  static const ComponentTypeId kComponentTypeIdInvalid = UINT64_MAX;
108  }
109  }
110 }
111 #endif
Simulation time handled during a single update.
Definition: include/gz/sim/Types.hh:49
Definition: gz/sim/Actor.hh:33
Definition: gz/sim/EntityComponentManager.hh:66
Total wall clock time elapsed while simulation is running. This will not increase while paused.
Definition: include/gz/sim/Types.hh:46
@ PeriodicChange
Component value has changed, and is changing periodically. This indicates to systems that it is ok to...
Total time elapsed in simulation. This will not increase while paused.
Definition: include/gz/sim/Types.hh:42
uint64_t iterations
Total number of elapsed simulation iterations.
Definition: include/gz/sim/Types.hh:53
Id that indicates an invalid component type.
Definition: include/gz/sim/Types.hh:107
@ NoChange
Component value has not changed.
Definition: include/gz/sim/Types.hh:38
ComponentState
Possible states for a component.
Definition: include/gz/sim/Types.hh:65
@ OneTimeChange
Component value has suffered a one-time change. This indicates to systems that this change must be pr...
int ComponentId
A unique identifier for a component instance. The uniqueness of a ComponentId is scoped to the compon...
Definition: include/gz/sim/Types.hh:85
Id that indicates an invalid component.
Definition: include/gz/sim/Types.hh:104
bool paused
True if simulation is paused, which means the simulation time is not currently running,...
Definition: include/gz/sim/Types.hh:61
uint64_t ComponentTypeId
A unique identifier for a component type. A component type must be derived from components::BaseCompo...
Definition: include/gz/sim/Types.hh:90
