src/gui/plugins/component_inspector_editor/Imu.hh
16 */
17 #ifndef IGNITION_GAZEBO_GUI_COMPONENTINSPECTOR_IMU_HH_
18 #define IGNITION_GAZEBO_GUI_COMPONENTINSPECTOR_IMU_HH_
20 #include <QObject>
21
22 namespace ignition
23 {
24 namespace gazebo
25 {
26  class ComponentInspectorEditor;
27
29  class Imu : public QObject
30  {
31  Q_OBJECT
32
35  public: explicit Imu(ComponentInspectorEditor *_inspector);
36
46  public: Q_INVOKABLE void OnLinearAccelerationXNoise(
47  double _mean, double _meanBias, double _stdDev,
48  double _stdDevBias, double _dynamicBiasStdDev,
49  double _dynamicBiasCorrelationTime);
50
60  public: Q_INVOKABLE void OnLinearAccelerationYNoise(
61  double _mean, double _meanBias, double _stdDev,
62  double _stdDevBias, double _dynamicBiasStdDev,
63  double _dynamicBiasCorrelationTime);
64
74  public: Q_INVOKABLE void OnLinearAccelerationZNoise(
75  double _mean, double _meanBias, double _stdDev,
76  double _stdDevBias, double _dynamicBiasStdDev,
77  double _dynamicBiasCorrelationTime);
78
88  public: Q_INVOKABLE void OnAngularVelocityXNoise(
89  double _mean, double _meanBias, double _stdDev,
90  double _stdDevBias, double _dynamicBiasStdDev,
91  double _dynamicBiasCorrelationTime);
92
102  public: Q_INVOKABLE void OnAngularVelocityYNoise(
103  double _mean, double _meanBias, double _stdDev,
104  double _stdDevBias, double _dynamicBiasStdDev,
105  double _dynamicBiasCorrelationTime);
106
116  public: Q_INVOKABLE void OnAngularVelocityZNoise(
117  double _mean, double _meanBias, double _stdDev,
118  double _stdDevBias, double _dynamicBiasStdDev,
119  double _dynamicBiasCorrelationTime);
120
123  private: ComponentInspectorEditor *inspector{nullptr};
124  };
125 }
126 }
127 #endif
A class that handles IMU sensor changes.
Definition: src/gui/plugins/component_inspector_editor/Imu.hh:30
Q_INVOKABLE void OnAngularVelocityZNoise(double _mean, double _meanBias, double _stdDev, double _stdDevBias, double _dynamicBiasStdDev, double _dynamicBiasCorrelationTime)
This function is called when a user changes values in the Imu sensor's angular velocity Z noise value...
Q_INVOKABLE void OnLinearAccelerationYNoise(double _mean, double _meanBias, double _stdDev, double _stdDevBias, double _dynamicBiasStdDev, double _dynamicBiasCorrelationTime)
This function is called when a user changes values in the Imu sensor's linear acceleration Y noise va...
Q_INVOKABLE void OnAngularVelocityYNoise(double _mean, double _meanBias, double _stdDev, double _stdDevBias, double _dynamicBiasStdDev, double _dynamicBiasCorrelationTime)
This function is called when a user changes values in the Imu sensor's angular velocity Y noise value...
Q_INVOKABLE void OnLinearAccelerationZNoise(double _mean, double _meanBias, double _stdDev, double _stdDevBias, double _dynamicBiasStdDev, double _dynamicBiasCorrelationTime)
This function is called when a user changes values in the Imu sensor's linear acceleration Z noise va...
Q_INVOKABLE void OnLinearAccelerationXNoise(double _mean, double _meanBias, double _stdDev, double _stdDevBias, double _dynamicBiasStdDev, double _dynamicBiasCorrelationTime)
This function is called when a user changes values in the Imu sensor's linear acceleration X noise va...
Q_INVOKABLE void OnAngularVelocityXNoise(double _mean, double _meanBias, double _stdDev, double _stdDevBias, double _dynamicBiasStdDev, double _dynamicBiasCorrelationTime)
This function is called when a user changes values in the Imu sensor's angular velocity X noise value...
