Component< NoData, Identifier, Serializer > Class Template Reference
#include <Component.hh>
std::unique_ptr< BaseComponentClone () const override
 Clone the component. More...
void Deserialize (std::istream &_in) override
 Fills a component based on a stream with a serialized data. By default, it will do nothing. Derived classes should override this function to support deserialization. More...
bool operator!= (const Component< NoData, Identifier, Serializer > &_component) const
 Components with no data are always equal to another instance of the same type. More...
bool operator== (const Component< NoData, Identifier, Serializer > &_component) const
void Serialize (std::ostream &_out) const override
 Fills a stream with a serialized version of the component. By default, it will leave the stream empty. Derived classes should override this function to support serialization. More...
ComponentTypeId TypeId () const override
 Returns the unique ID for the component's type. The ID is derived from the name that is manually chosen during the Factory registration and is guaranteed to be the same across compilers and runs. More...
- Public Member Functions inherited from BaseComponent
 BaseComponent ()=default
 Default constructor. More...
virtual ~BaseComponent ()=default
 Default destructor. More...
Static Public Attributes
static ComponentTypeId typeId {0}
 Unique ID for this component type. This is set through the Factory registration. More...
static const char * typeName {nullptr}
 Unique name for this component type. This is set through the Factory registration. More...
template<typename Identifier, typename Serializer>
class gz::sim::components::Component< NoData, Identifier, Serializer >
using Joint = Component<NoData, class JointTag>;
◆ Clone()
std::unique_ptr< BaseComponent > Clone ( ) const
A pointer to the component.
Implements BaseComponent.
◆ Deserialize()
void Deserialize ( std::istream _in)
[in]_inIn stream.
Reimplemented from BaseComponent.
◆ operator!=()
bool operator!= ( const Component< NoData, Identifier, Serializer > &  _component) const
[in]_componentComponent to compare to
False.
◆ operator==()
bool operator== ( const Component< NoData, Identifier, Serializer > &  _component) const
True.
◆ Serialize()
void Serialize ( std::ostream _out) const
[in]_outOut stream.
◆ TypeId()
ComponentTypeId TypeId ( ) const
References Component< DataType, Identifier, Serializer >::typeId.
◆ typeId
inlinestatic
◆ typeName
const char* typeName {nullptr}
inlinestatic
