Binary Installation on Ubuntu#
Jetty binaries are provided for Ubuntu Noble (24.04). The
Jetty binaries are hosted in the packages.osrfoundation.org repository.
To install all of them, the metapackage gz-jetty can be installed.
First install some necessary tools:
sudo apt-get update
sudo apt-get install curl lsb-release gnupg
Then install Gazebo Jetty:
sudo curl https://packages.osrfoundation.org/gazebo.gpg --output /usr/share/keyrings/pkgs-osrf-archive-keyring.gpg
echo "deb [arch=$(dpkg --print-architecture) signed-by=/usr/share/keyrings/pkgs-osrf-archive-keyring.gpg] https://packages.osrfoundation.org/gazebo/ubuntu-stable $(lsb_release -cs) main" | sudo tee /etc/apt/sources.list.d/gazebo-stable.list > /dev/null
sudo apt-get update
sudo apt-get install gz-jetty
All libraries should be ready to use and the gz sim app ready to be executed.
Head back to the Getting started page to start using Gazebo!
Server-only installation#
For headless and CI environments where the GUI is not needed, the
gz-sim10-server package provides a lightweight alternative. It installs only
the Gazebo simulation server (gz-sim-server) without any GUI or Qt
dependencies, resulting in a significantly smaller installation footprint.
After configuring the repository (same as above), install the server-only package:
sudo apt-get install gz-sim10-server
The server-only package includes the DART physics engine and the core simulation server plugins. To start a headless simulation:
/usr/libexec/gz/sim10/gz-sim-server <world_file.sdf>
Note
The server-only binary is installed at /usr/libexec/gz/sim10/gz-sim-server,
which is not in the PATH by default. The regular gz sim -s command is not
available in the server-only installation since it requires the full
gz-sim10-cli package.
Uninstalling binary install#
If you need to uninstall Gazebo or switch to a source-based install once you have already installed the library from binaries, run the following command:
sudo apt remove gz-jetty && sudo apt autoremove
Troubleshooting#
See Troubleshooting
