Moving the robot#
In this tutorial we will learn how to move our robot. We will use the robot we built in the Build your own robot tutorial. You can download the robot from here. You can also find the finished world of this tutorial here.
What is a plugin#
To make our robot move we will use the diff_drive
plugin. But before doing so let’s answer the question “What is a plugin?” A plugin is a chunk of code that is compiled as a shared library and inserted into the simulation. Plugins make us control many aspects of the simulation like world, models, etc.
Diff_drive plugin#
diff_drive
plugin helps us control our robot, specifically a robot that
can be differentially driven. Let’s setup the plugin on our robot. Open
the building_robot.sdf
and add the following code within the vehicle_blue
model tags.
filename="gz-sim-diff-drive-system"
name="gz::sim::systems::DiffDrive">
<left_joint>left_wheel_joint</left_joint>
<right_joint>right_wheel_joint</right_joint>
<wheel_separation>1.2</wheel_separation>
<wheel_radius>0.4</wheel_radius>
<odom_publish_frequency>1</odom_publish_frequency>
<topic>cmd_vel</topic>
The <plugin>
tag has two attributes, filename
which takes the library file name and name
which takes the name of the plugin.
In the <left_joint>
and <right_joint>
tags we define the joints which connect the left and the right wheel with the body of the robot, in our case left_wheel_joint
and right_wheel_joint
. <wheel_separation>
takes the distance between the two wheels.
Our robot has its left_wheel
at 0.6 m and the right_wheel
at -0.6 m in y-axis with respect to the chassis
, so the wheel_separation
is 1.2 m.
<wheel_radius>
takes the radius of the wheel which was defined in the <radius>
tag under the wheel link.
sets the frequency at which the odometry is published at /model/vehicle_blue/odometry
cmd_vel
is the input <topic>
to the DiffDrive
plugin.
Topics and Messages#
Now our model is ready. We just need to send commands (messages) to it.
These messages will be published (sent) on the cmd_vel
topic defined above.
A topic is simply a name for grouping a specific set of messages or a particular service.
Our model will subscribe (listen) to the messages sent on the cmd_vel
topic.
Launch the robot world:
gz sim building_robot.sdf
In another terminal let’s send a message to to our robot:
gz topic -t "/cmd_vel" -m gz.msgs.Twist -p "linear: {x: 0.5}, angular: {z: 0.05}"
Now you should have your robot moving in the simulation.
Note: Don’t forget to press the play button in the simulation.
The command specifies the topic to publish to after the -t
option.
After the -m
we specify the message type.
Our robot expects messages of type Twist
which consists of two components, linear
and angular
After the -p
option we specify the content (value) of the message: linear speed x: 0.5
and angular speed z: 0.05
Hint: You can know what every topic option does using this command: gz topic -h
For more information about Topics
and Messages
in Gazebo check the Transport library tutorials
Moving the robot using the keyboard#
Instead of sending messages from the terminal we will send messages using the keyboard keys. To do so we will add two new plugins: KeyPublisher
and TriggeredPublisher
KeyPublisher#
KeyPublisher
is an gz-gui
plugin that reads the keyboard’s keystrokes and sends them on a default topic /keyboard/keypress
Let’s try this plugin as follows:
In one terminal type
In the top right corner click on the plugins dropdown list (vertical ellipsis), click the Key Publisher.
In another terminal type
gz topic -e -t /keyboard/keypress
The last command will display all messages sent on /keyboard/keypress
topic.
In the Gazebo window press different keys and you should see data (numbers) on the terminal where you run the gz topic -e -t /keyboard/keypress
command.
$ gz topic -e -t /keyboard/keypress
data: 68
data: 85
data: 72
data: 74
data: 81
data: 16777235
data: 16777234
data: 16777237
data: 16777236
We want to map these keystrokes into messages of type Twist
and publish them to the /cmd_vel
topic which our model listens to.
The TriggeredPublisher
plugin will do this.
Triggered Publisher#
plugin publishes a user specified message on an output topic in response to an input message that matches user specified criteria.
Let’s add the following code under the <world>
tag:
<!-- Moving Forward-->
<plugin filename="gz-sim-triggered-publisher-system"
name="gz::sim::systems::TriggeredPublisher">
<input type="gz.msgs.Int32" topic="/keyboard/keypress">
<match field="data">16777235</match>
</input>
<output type="gz.msgs.Twist" topic="/cmd_vel">
linear: {x: 0.5}, angular: {z: 0.0}
</output>
This code defines the triggered-publisher
plugin.
It accepts messages of type gz.msgs.Int32
on the /keyboard/keypress
topic and if the value in the data
field matches 16777235
(Up arrow key) it outputs a Twist
message on the cmd_vel
topic with values x: 0.5
, z: 0.0
Now launch building_robot.sdf
then add the Key Publisher plugin and our robot should move forward as we press the Up arrow key ↑ (make sure you start the simulation by pressing the play button to see the robot move forward after pressing the Up arrow key).
There is a demo explaining how the Triggered Publisher works.
Moving using arrow keys#
To see what values are sent on the /keyboard/keypress
topic when pressing the arrows we can use the --echo
or -e
option
Run the model in one terminal:
In another terminal run the following command:
Start pressing the arrows keys and see what values they give:
Left ← : 16777234
Up ↑ : 16777235
Right → : 16777236
Down ↓ : 16777237
We will add the Triggered publisher
plugin for each arrow key.
For example, the Down arrow:
<!-- Moving Backward-->
<match field="data">16777237</match>
</input>
linear: {x: -0.5}, angular: {z: 0.0}
</output>
Map each arrow (key stroke) with the desired message (movement) as we did with the backward arrow:
Left ➞ 16777234 ➞ linear: {x: 0.0}, angular: {z: 0.5}
Up ➞ 16777235 ➞ linear: {x: 0.5}, angular: {z: 0.0}
Right ➞ 16777236 ➞ linear: {x: 0.0}, angular: {z: -0.5}
Down ➞ 16777237 ➞ linear: {x: -0.5}, angular: {z: 0.0}
Now it’s your turn try to make the robot move using different keys.
In the next tutorial, you’ll learn to create your own simulated world with SDF.
Video walk-through#
A video walk-through of this tutorial is available from our YouTube channel: Gazebo tutorials: Moving robot.
