Gazebo Release Instructions#
Initial setup#
A small number of configurations and credentials need to be made on the developerās system before triggering the release. If a permanent operating system is used for releasing, these installation steps only need to be executed once.
1. Software and configurations#
Triggering the releasing process is only supported on Linux at this moment.
The tool designed to facilitate the process of releasing software for all
platforms is called release.py
, and is hosted at gazebo-tooling/release-tools.
Cloning the release-tools
repository is required to perform a new release:
cd ~/
git clone https://github.com/gazebo-tooling/release-tools.git
Some Debian tools require the following variables to be set:
export DEBEMAIL="<username>@openrobotics.org"
export DEBFULLNAME="<Your full name>"
Note: the two above exported variables can be added to
.bashrc
to have them configured automatically on every run.
2. Access and Credentials#
Before starting the release process, make sure to ask for write access to:
The Gz library intended to be released and
gazebo-release
repository.
To interact with Jenkins an API token needs to be created and stored in the user system:
Creating a Jenkins API token: Open https://build.osrfoundation.org/user/<user>/security/ (Remember to change
<user>
to your username). In the āAPI Tokenā section, there is anAdd new Token
button to add a new Jenkins API token.The token needs to be stored in
~/.buildfarm/jenkins.ini
in the form:[https://build.osrfoundation.org] username = <your-github-user> password = <token created in step 1>
For Each Release#
1. Team and development checks#
When creating a new release, there are some guidelines to follow before starting the process:
Ask the team if there are any concerns about making the release.
Check if there are changes to previous library versions that need to be forward-ported.
See if there are open PRs against the release branch (release branch is the one with the name
ign/gz-fooX
where foo is the name of the Gz library and X the major version of the version bump planned) that could go into the new release.
2. Update code version and changelogs#
The first step to get a new release ready is to update the current code (upstream) version (view the versioning section for more information). This bump could be in the major number (non-compatible changes), minor number (new features), patch number (patches and bugfixes).
Bumping major number of the version implies some work to have the metadata updated correctly. There is a dedicated document that you should go through before continuing to work through the steps in this document.
To update the upstream version a local checkout of the Gz library is needed. A new branch is required to submit changes:
# version X.Y.Z git checkout -b bump_to_X_Y_Z
The current upstream version can be found in
CMakeLists.txt
file following the CMakeproject declaration
:# Gz library named foo and version X.Y.Z project(gz-fooX VERSION X.Y.Z)
Stable releases can modify the X, Y or Z directly while prereleases will need to include the preX (X number starts with 1) suffix in the
gz_configure_project
:# first prerelease of a serie, number 1 gz_configure_project(VERSION_SUFFIX pre1)
Together with bumping the version number, updating the Changelog and Migration documents is required. For updating the
Changelog.md
file, the script source_changelog.bash can be useful:cd <path to source code> bash <path to release-tools>/source-repo-scripts/source_changelog.bash <previous tag> # e.g. bash ../release-tools/source-repo-scripts/source_changelog.bash 3.5.0
The Migration.md
document needs to be updated if some breaking changes are in the Changelog.
Open a pull request for reviewing (example PR). When opening a PR look for the āReleaseā section in the template and follow the instructions there.
3. Update packages version#
Once the PR for bumping the code version is merged, the binary packages version
needs to be updated for the Debian/Ubuntu packages. Brew metadata will be
updated by the building server when creating the binary packages
(known as bottles
The version in the packages (binary version) should be similar to the one updated in the code in the step above but usually has some other components that reflect the package metadata version (i.e: new code version 2.1.0, new version in Debian packages is usually 2.1.0-1).
There should be a repository matching the name and major version of Gz library that you want to bump in the gz-release GitHub organization. (see release repositories document for more information about how they are used).
It is required to clone the corresponding release repository to update the binary version:
# Gz library named foo and major version X git clone https://github.com/gazebo-release/gz-fooX-release
To bump the package versions that will appear in Debian/Ubuntu binary packages there is a helper script in
release-tools
(see initial setup). The script is calledchangelog_spawn.sh
and require to be executed while the active directory is arelease repository
:# Gz library named foo and major version X cd gz-fooX-release ~/release-tools/release-repo-scripts/changelog_spawn.sh X.Y.Z-R # Example gz-cmake3 bumped from 3.0.0 to 3.0.1 cd gz-cmake3-release ~/release-tools/release-repo-scripts/changelog_spawn.sh 3.0.1-1
changelog_spawn.sh
will display information about the Ubuntu/Debian versions being updated as well as a git diff
before uploading information to the GitHub release repository.
Triggering the release#
After updating the code and releasing metadata everything is ready to launch the build in the server. Now, the following needs to happen:
Tag the corresponding code in the repository and upload that tag to GitHub.
Request
server to start a chain of job by callinggz-fooX-source
.gz-fooX-source
will generate the source tarball and callrepository_uploader_packages
to upload it togz-fooX-source
will call_releasepy
that will generate the builders jobs:Debian/Ubuntu: use
ign/gz-fooX-debbuilder
job namesBrew: entry job is
generic-release-homebrew_pull_request_updater
The release.py
script and Jenkins will perform all these actions. For more information of all the processes
triggered by the release.py
script please check the release process.
4. Executing release.py#
Make sure you are in the source code repository before running release.py
You should be on the branch to be released, after the pull request bumping
the version has been merged (run git status
to check the branch, and git log
to check that the version bump pull request has been included).
Running release.py
from the source code repository will generate and
upload some Git tags (ārelease tagsā) to the source code repository.
You will also need the token described in the credentials section.
There are a few external dependencies for running release.py. They can be esily installed using virtual enviroments and pip:
# you can change .releasepy_venv by any directory of your preference
python3 -m venv ~/.releasepy_venv
. ~/.releasepy_venv/bin/activate
cd <release-tools-dir>
pip install .
dry-run simulation mode
The release.py
tool supports a --dry-run
flag that allows users to
simulate releases (nothing is modified) in order to ensure that the correct
arguments are being used to trigger a particular release. Gz releasers
should always call release.py
with --dry-run
first in order to
ensure that proper commands are being used to trigger releases.
The script needs to be run from the repository with the source code (i.e., the repository where the Gz library version bump pull request took place):
# Example of dry-run for gz-cmake3 bumped to 3.0.1
cd gz-cmake3
git checkout gz-cmake3
~/release-tools/release.py gz-cmake3 3.0.1 --dry-run
release.py for stable releases
cd ign/gz-fooX
git checkout ign/gz-fooX
# Example gz-cmake3 bumped to 3.0.1
cd gz-cmake3
release.py for prereleases or nightlies
When releasing prereleases or nightly releases, there are some special flags
to be set. The --upload-to-repo
argument is mandatory when running
release.py
, and should be set to prerelease
or nightly
# Example gz-cmake3 bumped to prerelease 3.0.0~pre1
cd gz-cmake3
~/release-tools/release.py gz-cmake3 3.0.0~pre1 --upload-to-repo prerelease
Nightly invocation is generally coded in the server. The version will be
taken from the last changelog entry and modified during building. No source
code will be uploaded, but taken directly in the binary build from the
branch pointed by --nightly-src-branch
# Example gz-cmake3 nightly from main branch
~/release-tools/release.py gz-cmake3 3.0.0~pre1 --upload-to-repo nightly --nightly-src-branch main
Binary version schema for prereleases and nightlies
Prerelease and nightlies binary versions use particular naming schema to define right ordering for package managers. This information about versioning in Gazebo Classic applies to the [Gazebo] too.
release.py for revision bumps
Bumping the revision number for binary packages is a special
case of releasing since the original tarball with the source code will
remain the same. Once the release repository is ready with the new release
version, release.py
needs the --only-bump-revision-linux
flag.
Note that the --source-tarball-uri
parameter is needed with the original tarball
of the software version. All the tarballs can be found at https://classic.gazebosim.org/distributions
or the information should appear in the parameters of the Jenkins -debbuilder build that created
the first version of the sofware.
# Example gz-cmake3 bumped from 3.0.1-1 to 3.0.1-2
~/release-tools/release.py gz-cmake3 3.0.1 --source-tarball-uri https://osrf-distributions.s3.amazonaws.com/gz-cmake/releases/gz-cmake-3.0.1.tar.bz2 --only-bump-revision-linux -release-version 2
Checking the Building Process#
For checking that the build process is ongoing as expected:
Checking the source generation and upload:
The
gz-fooX-source
job (change fooX by the software name being released, i.e: math7) is triggered directly byrelease.py
(script output will point to it) should have finished successfully.The
gz-fooX-source
job launches a one new build in therepository_uploader_packages
job with the name of the software.If there is a failure, contact with the Infra team.
There should be one new build in the
_releasepy
job with the name of the software.If there is a failure, you can check the output if you can access to the job workspace in the Jenkins build, since it is disabled by default. Contact with the Infra team for help.
Checking package generation after the
_releasepy
build:Several
-debbuilder
jobs should be in https://build.osrfoundation.org/. For watching the jobs to see if any of them fail or are marked unstable, open the page for a specific debbuild, such as https://build.osrfoundation.org/job/gz-math7-debbuilder/.If there is a failure, check the list of supported architectures in the corresponding Gazebo Platform Support issue
To check if a debbuild has previously succeeded for a given architecture, check packages.osrfoundation.org to see the most recent successful builds. (i.e most recent Ubuntu builds of ignition-gazebo6 or the Debian builds of ignition-gazebo6.
If the failure is on a supported architecture, check the source repository for an existing report of this failure and if none exists, report the failure (see gazebosim/gz-math#161 for an example).
If a build is unstable, check if it was unstable before this release and if it has already been reported. A common cause of unstable debbuilds is newly installed files that are not captured by the patterns in the
.install
files in the-release
repository. This can be checked by searching fordh_missing
in the console log of the unstable build and looking for a list of uninstalled files. Example pull requests that fix problems withdh_missing
are gazebo-release/gz-transport11-release#4 and gazebo-release/gz-tools-release#4.
A pull request was opened to osrf/homebrew-simulation
This pull request may take a minute or two to open.
Once it is open, make a comment containing the text ābuild bottleā. For further details, see the README at osrf/homebrew-simulation.
A pull request was opened to gazebo-release/$VENDOR_PACKAGE, where
$VENDOR_PACKAGE
is the name of the Gazebo vendor package for ROS (see https://gazebosim.org/docs/latest/ros2_gz_vendor_pkgs/)Ensure that the ROS CI build passes. Note that some builds have warnings which show up as failures on the Github UI while the build actually succeeded.
For packages that are considered to be part of ROS core (
gz_cmake_vendor
,gz_utils_vendor
, andgz_math_vendor
), start additional CI tests using ci.ros2.org to build and test all ROS core packages that depend on these Gazebo vendor packages.To do so, start a new
ci_launcher
build with the following parameters:CI_BRANCH_TO_TEST
: branch name of the PR (e.g.releasepy/rolling/3.1.1
)CI_ROS2_REPOS_URL
: If the vendor package is going torolling
, this can be skipped, otherwise usehttps://raw.githubusercontent.com/ros2/ros2/$ROSDISTRO/ros2.repos
where$ROSDISTRO
is replaced by the target ROS distribution.CI_UBUNTU_DISTRO
: Pick the Ubuntu distro that matches the target ROS distributionCI_ROS_DISTRO
: The target ROS distribution. For Harmonic this isjazzy
, for Ionic this isrolling
untilkilted
is released.CI_BUILD_ARGS
:--event-handlers console_cohesion+ console_package_list+ --cmake-args -DINSTALL_EXAMPLES=OFF -DSECURITY=ON -DAPPEND_PROJECT_NAME_TO_INCLUDEDIR=ON --packages-above-and-dependencies $VENDOR_PACKAGE
where$VENDOR_PACKAGE
is the name of the Gazebo vendor package.CI_TEST_ARGS
:--event-handlers console_cohesion+ --retest-until-pass 2 --ctest-args -LE xfail --pytest-args -m 'not xfail' --executor sequential --packages-above $VENDOR_PACKAGE
Note: you might have to ask the Infrastructure team to get permission to run builds on ci.ros2.org.
Once all of CI builds are successful, merge the PR
Make sure you have the required permission by checking ros2-gbp/ros2-gbp-github-org. If your username is not there, follow these instructions to get added to the release team.
Follow the steps of releasing a ROS package to release the vendor package https://docs.ros.org/en/rolling/How-To-Guides/Releasing/Subsequent-Releases.html
Bump patch versions if the package has already been released for the target ROS distribution. This is almost always what you want to do.
Bump minor version only if the package is being released into
rolling
and if the release happens immediately after a new ROS distribution has been branched off ofrolling
. The intention here is that all release branches (e.g.jazzy
,kilted
,rolling
, etc.) have distinct minor version numbers.Never bump the major version number.
