Use ROS 2 Simulation Interfaces to Interact with Gazebo#
The ROS 2 Simulation Interfaces define a standard set of ROS 2 service, message and action definitions for controlling and interacting with simulation environments. These interfaces are simulator-agnostic and aim to provide a unified way to control and observe simulation using ROS 2.
Gazebo has implemented these interfaces, enabling tasks like spawning entities, stepping simulation, querying world state, etc. through standard ROS 2 calls. In this tutorial we will learn how to interact with a running Gazebo simulation for the following tasks,
Simulation Control#
The following services and actions are available to control the flow of simulation time.
Interface Name
Topic Name
Type
Description
ResetSimulation
/gzserver/reset_simulation
Service
Reset the simulation to its initial state
StepSimulation
/gzserver/step_simulation
Service
Step the simulation forward by a specified number of steps
GetSimulationState
/gzserver/get_simulation_state
Service
Get the current simulation state (playing/paused/stopped)
SetSimulationState
/gzserver/set_simulation_state
Service
Set the simulation state (play/pause/stop)
SimulateSteps
/gzserver/simulate_steps
Action
Step the simulation forward by a specified number of steps with feedback and cancellation support
ResetSimulation Service#
Reset the simulation to its initial state.
ros2 service call /gzserver/reset_simulation simulation_interfaces/srv/ResetSimulation "{}"
StepSimulation Service#
Step the simulation forward by a specified number of steps.
ros2 service call /gzserver/step_simulation simulation_interfaces/srv/StepSimulation "{steps: 10}"
GetSimulationState Service#
Get the current simulation state (playing/paused/stopped).
ros2 service call /gzserver/get_simulation_state simulation_interfaces/srv/GetSimulationState "{}"
SetSimulationState Service#
Set the simulation state (play/pause/stop).
  • Set simulation state to stop.
    ros2 service call /gzserver/set_simulation_state simulation_interfaces/srv/SetSimulationState "{state: {state: 0}}"
  • Set simulation state to playing.
    ros2 service call /gzserver/set_simulation_state simulation_interfaces/srv/SetSimulationState "{state: {state: 1}}"
  • Set simulation state to paused.
    ros2 service call /gzserver/set_simulation_state simulation_interfaces/srv/SetSimulationState "{state: {state: 2}}"
  • Set simulation state to quitting.
    ros2 service call /gzserver/set_simulation_state simulation_interfaces/srv/SetSimulationState "{state: {state: 3}}"
SimulateSteps Action#
Step the simulation forward by a specified number of steps with feedback and cancellation support.
ros2 action send_goal /gzserver/simulate_steps simulation_interfaces/action/SimulateSteps "{steps: 10}" --feedback
Entity Management#
The following interfaces are used to create or remove entities in the simulation at runtime.
Interface Name
Topic Name
Type
Description
SpawnEntity
/gzserver/spawn_entity
Service
Spawn a new entity in the simulation at a specific location
DeleteEntity
/gzserver/delete_entity
Service
Delete an existing entity by name
SpawnEntity Service#
Spawn a new entity in the simulation at a specific location.
ros2 service call /gzserver/spawn_entity simulation_interfaces/srv/SpawnEntity "{
  uri: '/path/to/model.sdf',
  allow_renaming: false,
  initial_pose: {
    pose: {
      position: {x: 0.0, y: 0.0, z: 0.0},
      orientation: {w: 1.0, x: 0.0, y: 0.0, z: 0.0}
DeleteEntity Service#
Delete an existing entity by name.
ros2 service call /gzserver/delete_entity simulation_interfaces/srv/DeleteEntity "{entity: 'my_model'}"
State Query#
The following interfaces are used to introspect simulation world and entity state.
Interface Name
Topic Name
Type
Description
GetEntityState
/gzserver/get_entity_state
Service
Get the pose and twist of a specific entity
GetEntitiesStates
/gzserver/get_entities_states
Service
Get the state for multiple entities (optionally filtered)
GetEntities
Service
Get a list of entities (optionally filtered)
GetEntityState Service#
Get the pose and twist of a specific entity.
ros2 service call /gzserver/get_entity_state simulation_interfaces/srv/GetEntityState "{entity: 'my_model'}"
GetEntitiesStates Service#
Get the state of multiple entities (optionally filtered).
ros2 service call /gzserver/get_entities_states simulation_interfaces/srv/GetEntitiesStates "{filters: {filter: ''}}"
GetEntites Service#
Get the list of entities (optionally filtered).
ros2 service call /gzserver/get_entities simulation_interfaces/src/GetEntities "{filters: {filter: ''}}"
State Update#
The following interfaces are used to set entity states.
Interface Name
Topic Name
Type
Description
SetEntityState
/gzserver/set_entity_state
Service
Set the pose and twist of a specific entity
SetEntityState Service#
Set the pose and twist of a specific entity.
ros2 service call /gzserver/set_entity_state simulation_interfaces/srv/SetEntityState "{ entity: 'my_model', state: {pose: { position: { x: -2.0, z: 0.5 }}, twist: {linear: {x: 0.5}}}}"
Caution
When using SetEntityState, it is currently not possible to set just the pose or the twist of an entity. Both components of the entity will be assigned based on the value of the provided message. For example, of pose is left empty, the pose of the entity will be set to the origin.
This might be resolved in the future. See ros-simulation/simulation_interfaces#18
Simulator Information#
Some simulators may only support a subset of interfaces. The following services can be used to inspect supported features.
Interface Name
Topic Name
Type
Description
GetSimulatorFeatures
/gzserver/get_simulator_features
Service
Query which interface features are supported
GetSimulatorFeatures Service#
Query which interface features are supported.
ros2 service call /gzserver/get_simulator_features simulation_interfaces/srv/GetSimulationFeatures "{}"
Known Limitations#
  • Only an empty string or “world” can be used in the frame_id field of PoseStamped messages. We plan to add support for using frames known to Tf in the future.
  • Entity namespaces are not supported by the SpawnEntity service.
  • When spawning an entity, if SpawnEntity.allow_renaming is set to true and a rename occurs in Gazebo, the new name is not returned in the Result object return by the SpawnEntity service.
