BaseMaterialMap< T > Class Template Reference
#include <BaseStorage.hh>
- Public Member Functions inherited from BaseMap< Material, T >
 BaseMap ()
virtual ~BaseMap ()
virtual bool ContainsKey (const std::string &_key) const
 Determine if an elements is mapped to the given key.
virtual bool ContainsValue (ConstTPtr _value) const
 Determine if the given element exists in this map.
virtual UPtr Derived (const std::string &_key) const
virtual TPtr Get (const std::string &_key) const
 Get the element mapped to the given key.
 Get the element at the given index.
virtual bool Put (const std::string &_key, TPtr _value)
 Map to given element to the given key. If the given key is already in use, no work will be done.
virtual void Remove (const std::string &_key)
 Remove the element mapped to the given key. If the specified element does not exists, no work will be done.
virtual void Remove (TPtr _value)
 Remove the given element. If the given element does not exist no work will be done.
virtual void RemoveAll ()
 Remove all elements from this map.
 Get the number of elements in this map.
- Public Member Functions inherited from Map< T >
virtual ~Map ()=default
- Protected Member Functions inherited from BaseMap< Material, T >
- Protected Attributes inherited from BaseMap< Material, T >
UMap map
