CameraLens Class Reference
Describes a lens of a camera as amapping function of type r = c1*f*fun(theta/c2+c3) More...
#include <CameraLens.hh>
 CameraLens ()
 CameraLens (const CameraLens &_other)
virtual ~CameraLens ()
AngleFunctionType AngleFunction () const
 Gets angle transform function.
float ApplyMappingFunction (float _f) const
 Apply mapping function to input number.
double C1 () const
 Gets c1 parameter.
double C2 () const
 Gets c2 parameter.
double C3 () const
 Gets c3 parameter.
double CutOffAngle () const
 Gets cut off angle.
double F () const
 Gets f parameter.
bool IsCustom () const
 Checks if lens type is of the custom type.
math::Vector3d MappingFunctionAsVector3d () const
CameraLens & operator= (const CameraLens &_other)
 Assignment operator.
bool ScaleToHFOV () const
 Checks if image should be scaled to fit horizontal FOV.
void SetAngleFunction (AngleFunctionType _fun)
 Sets angle transform function.
void SetC1 (double _c)
 Sets c1 parameter.
void SetC2 (double _c)
 Sets c2 parameter.
void SetC3 (double _c)
 Sets c3 parameter.
void SetCustomMappingFunction (double _c1, double _c2, AngleFunctionType _fun, double _f, double _c3)
 Set custom camera lens with specified parameters.
void SetCutOffAngle (double _angle)
 Sets cut-off angle.
void SetF (double _f)
 Sets f parameter.
void SetScaleToHFOV (bool _scale)
 Sets whether the image should be scaled to fit horizontal FOV If True, the projection will compute a new focal length for achieving the desired FOV.
void SetType (MappingFunctionType _type)
 Set lens projection type.
MappingFunctionType Type () const
 Get lens projection type.
◆ CameraLens() [1/2]
◆ ~CameraLens()
virtual ~CameraLens ( )
◆ CameraLens() [2/2]
CameraLens ( const CameraLens &  _other)
[in]_otherThe other camera lens
◆ AngleFunction()
AngleFunctionType AngleFunction ( ) const
Angle transform function
◆ ApplyMappingFunction()
float ApplyMappingFunction ( float  _f) const
[in]_fInput floating point number to apply the mapping function to.
Result of the application
◆ C1()
double C1 ( ) const
Gets c1 parameter.
c1 parameter
◆ C2()
double C2 ( ) const
Gets c2 parameter.
c2 parameter
◆ C3()
double C3 ( ) const
Gets c3 parameter.
c3 parameter
◆ CutOffAngle()
double CutOffAngle ( ) const
Gets cut off angle.
Cut off angle
◆ F()
double F ( ) const
Gets f parameter.
f parameter
◆ IsCustom()
bool IsCustom ( ) const
True if this->Type() == MFT_CUSTOM
◆ MappingFunctionAsVector3d()
math::Vector3d MappingFunctionAsVector3d ( ) const
◆ operator=()
CameraLens & operator= ( const CameraLens &  _other)
◆ ScaleToHFOV()
bool ScaleToHFOV ( ) const
True if the image will be scaled
◆ SetAngleFunction()
void SetAngleFunction ( AngleFunctionType  _fun)
[in]_funAngle transform function
◆ SetC1()
void SetC1 ( double  _c)
Sets c1 parameter.
[in]_cc1 parameter
◆ SetC2()
void SetC2 ( double  _c)
Sets c2 parameter.
[in]_cc2 parameter
◆ SetC3()
void SetC3 ( double  _c)
Sets c3 parameter.
[in]_cc3 parameter
◆ SetCustomMappingFunction()
void SetCustomMappingFunction ( double  _c1,
double  _c2,
double  _f,
double  _c3
[in]_c1Image scaling factor
[in]_c2Angle scaling factor
[in]_fFocal length of the optical system
[in]_c3Angle shift parameter, should be 0 in most cases
◆ SetCutOffAngle()
void SetCutOffAngle ( double  _angle)
Sets cut-off angle.
[in]_anglecut-off angle
◆ SetF()
void SetF ( double  _f)
Sets f parameter.
[in]_ff parameter
◆ SetScaleToHFOV()
void SetScaleToHFOV ( bool  _scale)
[in]_scaletrue if it should, note: c1 and f parameters are ignored in this case
◆ SetType()
void SetType ( MappingFunctionType  _type)
[in]_typeLens projection / mapping function type
◆ Type()
MappingFunctionType Type ( ) const
