GlobalIlluminationVct Class Referenceabstract
Implements Global Illumination using VCT (Voxel Cone Tracing) More...
#include <GlobalIlluminationVct.hh>
Public Types
enum  DebugVisualizationMode {
  DVM_Albedo , DVM_Normal , DVM_Emissive , DVM_Lighting ,
  DVM_None
 Debug visualization modes for GlobalIlluminationVct::SetDebugVisualization. More...
- Public Types inherited from GlobalIlluminationBase
enum  ParticipatingVisualsFlags { DYNAMIC_VISUALS = 1u << 0u , STATIC_VISUALS = 1u << 1u }
 Bitmask of which objects are considered by GI bounces. Note that all objects can receive indirect illumination. More...
 GlobalIlluminationVct ()
virtual ~GlobalIlluminationVct ()
virtual bool Anisotropic () const =0
 Whether anisotropic setting is on.
virtual bool ConserveMemory () const =0
 Whether we're releasing memory as fast as possible.
virtual DebugVisualizationMode DebugVisualization () const =0
 Returns current visualization mode.
virtual bool HighQuality () const =0
 Whether we're using 6 (true) or 4 (false) cones.
virtual void LightingChanged ()=0
 Called by Scene when lighting changes so that GI can be updated.
virtual const uint32_t * OctantCount () const =0
 Returns number of octant subdivisions per axis.
virtual const uint32_t * Resolution () const =0
 Returns 3D Voxel resolution.
virtual void SetAnisotropic (bool _anisotropic)=0
 Anisotropic VCT provides much higher quality because it better captures incoming indirect illumination from all directions.
virtual void SetConserveMemory (bool _conserveMemory)=0
 This will try to release resources that aren't needed when lights and static objects don't change.
virtual void SetDebugVisualization (DebugVisualizationMode _dvm)=0
 Draws the voxels on screen for inspection and understand what is going on with GI. You should be looking at a minecraft-like world.
virtual void SetHighQuality (bool _highQuality)=0
 True for high quality (slower). VRAM consumption stays the same. Ogre2 will use 6 cones instead of 4.
virtual void SetOctantCount (const uint32_t _octants[3])=0
 Number of divisions per axis to divide the scene into multiple octants. Setting this value > 1 may improve voxelization performance when there is a lot of static Meshes; but it may also decrease it. Profiling is required for each scene.
virtual void SetResolution (const uint32_t _resolution[3])=0
 Resolution of the 3D Voxel. Must be multiple of 2.
virtual void SetThinWallCounter (float _thinWallCounter)=0
 Shadows are calculated by raymarching towards the light source. However sometimes the ray 'may go through' a wall due to how bilinear interpolation works.
virtual float ThinWallCounter () const =0
 Value of SetThinWallCounter.
- Public Member Functions inherited from GlobalIlluminationBase
 GlobalIlluminationBase ()
virtual ~GlobalIlluminationBase ()
virtual uint32_t BounceCount () const =0
 Get number of bounces.
virtual void Build ()=0
 Build the internal structures required for producing GI This function may take significant time.
virtual bool Enabled () const =0
 Returns true if this GI configuration is currently enabled.
virtual uint32_t ParticipatingVisuals () const =0
 Visuals that can bounce GI.
virtual void SetBounceCount (uint32_t _bounceCount)=0
 Set the number of GI bounces. Very high number can cause a large performance impact.
virtual void SetParticipatingVisuals (uint32_t _mask)=0
 Set which visuals can bounce GI.
virtual void UpdateCamera ()=0
 Called by Scene on an active GlobalIlluminationBase whenever first rendering happens for a new frame. This implies Build has been called already.
virtual void UpdateLighting ()=0
 Called by Scene on an active GlobalIlluminationBase whenever lighting changes. This implies Build has been called already.
- Protected Member Functions inherited from GlobalIlluminationBase
 Destroy the class.
virtual void Init ()=0
 Initialize the class.
 Sets this GI solution as enabled.
gz/rendering/GlobalIlluminationVct.hh
◆ DebugVisualizationMode
Enumerator
DVM_Albedo
Debug voxelized Albedo.
DVM_Normal
Debug voxelized Normals.
DVM_Emissive
Debug voxelized Emissive materials.
DVM_Lighting
Debug VCT result (i.e. what's used by GI)
DVM_None
Disable debugging.
◆ GlobalIlluminationVct()
◆ ~GlobalIlluminationVct()
virtual ~GlobalIlluminationVct ( )
◆ Anisotropic()
virtual bool Anisotropic ( ) const
Anisotropy setting
Implemented in BaseGlobalIlluminationVct< T >, BaseGlobalIlluminationVct< Ogre2Object >, and Ogre2GlobalIlluminationVct.
◆ ConserveMemory()
virtual bool ConserveMemory ( ) const
Conserve Memory setting
◆ DebugVisualization()
virtual DebugVisualizationMode DebugVisualization ( ) const
Visualization mode
Implemented in Ogre2GlobalIlluminationVct.
◆ HighQuality()
virtual bool HighQuality ( ) const
High Quality setting
◆ LightingChanged()
virtual void LightingChanged ( )
◆ OctantCount()
virtual const uint32_t * OctantCount ( ) const
Octant subdivisions. Length of array is 3
◆ Resolution()
virtual const uint32_t * Resolution ( ) const
Resolution in each axis. Length of array is 3
◆ SetAnisotropic()
virtual void SetAnisotropic ( bool  _anisotropic)
However it consumes more VRAM and is slower. Recommended: true
Remarks
This setting has nothing to do with anistropic texture filtering in GPUs
[in]_anisotropicAnisotropy setting
◆ SetConserveMemory()
virtual void SetConserveMemory ( bool  _conserveMemory)
When true, every time light changes we will recreate those resources, update the GI, and release them; causing VRAM spikes. This can be bad for memory fragmentation (and performance) if VCT is updated too often.
When false, those resources will stay loaded at all times
[in]_conserveMemoryTrue to release memory as fast as possible
◆ SetDebugVisualization()
virtual void SetDebugVisualization ( DebugVisualizationMode  _dvm)
[in]_dvmWhat component to visualize
◆ SetHighQuality()
virtual void SetHighQuality ( bool  _highQuality)
[in]_highQualityQuality setting
◆ SetOctantCount()
virtual void SetOctantCount ( const uint32_t  _octants[3])
[in]_octantsNumber of octant subdivisions per axis
◆ SetResolution()
virtual void SetResolution ( const uint32_t  _resolution[3])
Remarks
To avoid wasting RAM, make this function your first call if you intend to change the defaults.
[in]_resolutionResolution
◆ SetThinWallCounter()
virtual void SetThinWallCounter ( float  _thinWallCounter)
Bilinear interpolation can produce nicer soft shadows, but it can also cause this light leaking from behind a wall.
Increase this value (e.g. to 2.0f) to fight light leaking. This should generally (over-)darken the scene
Lower values will lighten the scene and allow more light leaking
Note that thinWallCounter can not fight all sources of light leaking, thus increasing it to ridiculous high values may not yield any benefit.
[in]_thinWallCounterValue in range (0; inf)
◆ ThinWallCounter()
virtual float ThinWallCounter ( ) const
ThingWallCounter value
