OgreDynamicLines Class Reference
Class for drawing lines that can change. More...
#include <OgreDynamicLines.hh>
 OgreDynamicLines (MarkerType _opType=MT_LINE_STRIP)
 ~OgreDynamicLines () override
void AddPoint (const double _x, const double _y, const double _z, const gz::math::Color &_color=gz::math::Color::White)
 Add a point to the point list.
void AddPoint (const gz::math::Vector3d &_pt, const gz::math::Color &_color=gz::math::Color::White)
void Clear ()
 Remove all points from the point list.
gz::math::Vector3d Point (unsigned int _index) const
 Return the location of an existing point in the point list.
unsigned int PointCount () const
 Return the total number of points in the point list.
void SetColor (unsigned int _index, const gz::math::Color &_color)
 Change the color of an existing point in the point list.
void SetPoint (unsigned int _index, const gz::math::Vector3d &_value)
 Change the location of an existing point in the point list.
void Update ()
 Call this to update the hardware buffer after making changes.
- Public Member Functions inherited from OgreDynamicRenderable
 OgreDynamicRenderable ()
virtual ~OgreDynamicRenderable ()
 Virtual destructor.
virtual Ogre::Real getBoundingRadius () const
 Implementation of Ogre::SimpleRenderable.
virtual Ogre::Real getSquaredViewDepth (const Ogre::Camera *_cam) const
void Init (MarkerType _opType, bool _useIndices=false)
 Initializes the dynamic renderable.
MarkerType OperationType () const
 Get the render operation type.
void SetOperationType (MarkerType _opType)
 Set the render operation type.
- Protected Member Functions inherited from OgreDynamicRenderable
void PrepareHardwareBuffers (size_t _vertexCount, size_t _indexCount)
 Prepares the hardware buffers for the requested vertex and index counts.
- Protected Attributes inherited from OgreDynamicRenderable
size_t indexBufferCapacity = 0
 Maximum capacity of the currently allocated index buffer.
size_t vertexBufferCapacity = 0
 Maximum capacity of the currently allocated vertex buffer.
◆ OgreDynamicLines()
OgreDynamicLines ( MarkerType  _opType = MT_LINE_STRIP)
[in]_opTypeThe type of Line
◆ ~OgreDynamicLines()
~OgreDynamicLines ( )
◆ AddPoint() [1/2]
void AddPoint ( const double  _x,
const double  _y,
const double  _z,
const gz::math::Color &  _color = gz::math::Color::White
[in]_xX position
[in]_yY position
[in]_zZ position
[in]_colorgz::math::Color Point color
◆ AddPoint() [2/2]
void AddPoint ( const gz::math::Vector3d &  _pt,
[in]_ptgz::math::Vector3d point
◆ Clear()
void Clear ( )
◆ Point()
gz::math::Vector3d Point ( unsigned int  _index) const
[in]_indexNumber of the point to return
gz::math::Vector3d value of the point. A vector of [gz::math::INF_D, gz::math::INF_D, gz::math::INF_D] is returned when then the _index is out of bounds. gz::math::INF_D==std::numeric_limits<double>::infinity()
◆ PointCount()
Number of points
◆ SetColor()
void SetColor ( unsigned int  _index,
[in]_indexIndex of the point to set
[in]_colorgz::math::Color Pixelcolor color to set the point to
◆ SetPoint()
[in]_valuegz::math::Vector3d value to set the point to
void Update ( )
