Non owning, writable view of a caller owned pixel buffer. More...
#include <gz/rendering/PixelBuffer.hh>
| PixelBuffer (const PixelBuffer &_other) | |
| Copy constructor. Copies of a view share the same buffer. | |
| PixelBuffer (Image &_image) | |
| View the storage of an existing image. The view is only valid while the image, or a copy of it, is alive. | |
| PixelBuffer (unsigned int _width, unsigned int _height, PixelFormat _format, void *_data, std::size_t _size) | |
| Describe a caller owned buffer. | |
| ~PixelBuffer () | |
| Destructor. Does not free the buffer. | |
| unsigned char * | Data () const |
| Get a pointer to the first byte of the buffer. The pointer is writable even through a const view: this is a span, not a read only view. | |
| PixelFormat | Format () const |
| Get the pixel format. | |
| unsigned int | Height () const |
| Get the height in pixels. | |
| std::size_t | MemorySize () const |
| Get the number of bytes Width x Height pixels of Format need. | |
| PixelBuffer & | operator= (const PixelBuffer &)=delete |
| Views cannot be rebound. | |
| PixelBuffer & | operator= (PixelBuffer &&)=delete |
| std::size_t | Size () const |
| Get the size of the buffer in bytes, as given by the caller. | |
| bool | Valid () const |
| Check that the buffer can hold a frame: the pointer is not null and Size() is at least MemorySize(). | |
| unsigned int | Width () const |
| Get the width in pixels. | |
A PixelBuffer describes where a frame should be written: dimensions, pixel format, the start of a contiguous row major buffer and its size in bytes. It owns nothing and never frees the memory. Build one right before handing it to Camera::CopyTo and let it die when the call returns; nothing in the library keeps a pointer to the memory after that.
Every field is immutable and assignment is deleted, so code that receives a PixelBuffer can write through it but cannot point it somewhere else. That is what lets the render engines write straight into caller memory without being able to drop it by mistake.
◆ PixelBuffer() [1/3]
| PixelBuffer | ( | unsigned int | _width, |
| unsigned int | _height, | ||
| PixelFormat | _format, | ||
| void * | _data, | ||
| std::size_t | _size | ||
[in] _width Width in pixels [in] _height Height in pixels [in] _format Pixel format of the buffer [in] _data Start of the buffer. Not owned. [in] _size Size of the buffer in bytes
◆ PixelBuffer() [2/3]
explicit |
[in] _image Image whose buffer is viewed
◆ PixelBuffer() [3/3]
| PixelBuffer | ( | const PixelBuffer & | _other | ) |
[in] _other View to copy
◆ ~PixelBuffer()
| ~PixelBuffer | ( | ) |
◆ Data()
| unsigned char * Data | ( | ) | const |
- Returns
- Pointer to the buffer
◆ Format()
| PixelFormat Format | ( | ) | const |
- Returns
- Pixel format
◆ Height()
| unsigned int Height | ( | ) | const |
- Returns
- Height in pixels
◆ MemorySize()
| std::size_t MemorySize | ( | ) | const |
- Returns
- Required size in bytes
◆ operator=() [1/2]
delete |
◆ operator=() [2/2]
delete |
◆ Size()
| std::size_t Size | ( | ) | const |
- Returns
- Buffer size in bytes
◆ Valid()
| bool Valid | ( | ) | const |
- Returns
- True if a frame can be written into the buffer
◆ Width()
| unsigned int Width | ( | ) | const |
- Returns
- Width in pixels
