gz/rendering/Camera.hh
virtual void Update()=0
Renders a new frame. This is a convenience function for single-camera scenes. It wraps the pre-render...
virtual void Copy(Image &_image) const =0
Writes the last rendered image to the given image buffer. This function can be called multiple times ...
Definition: gz/rendering/Sensor.hh:32
STL class.
virtual RenderPassPtr RenderPassByIndex(unsigned int _index) const =0
Get a render passes by index.
PixelFormat
Image pixel format types.
Definition: gz/rendering/PixelFormat.hh:32
virtual void PostRender()=0
Preforms any necessary final rendering work. Once rendering is complete the camera will alert any lis...
virtual NodePtr FollowTarget() const =0
std::function< void(const void *, unsigned int, unsigned int, unsigned int, const std::string &)> NewFrameListener
Definition: gz/rendering/Camera.hh:45
virtual void SetTrackPGain(const double _pGain)=0
Set track P Gain. Determines how fast the camera rotates to look at the target node....
virtual double FollowPGain() const =0
Definition: gz/rendering/Image.hh:36
virtual double NearClipPlane() const =0
virtual PixelFormat ImageFormat() const =0
Get the image pixel format. If the image pixel format has not been set with a valid value,...
virtual math::Vector3d FollowOffset() const =0
Definition: gz/rendering/Camera.hh:40
virtual VisualPtr VisualAt(const gz::math::Vector2i &_mousePos)=0
virtual void SetTrackTarget(const NodePtr &_target, const math::Vector3d &_offset=math::Vector3d::Zero, const bool _worldFrame=false)=0
Set a node for camera to track. The camera will automatically change its orientation to face the targ...
virtual void AddRenderPass(const RenderPassPtr &_pass)=0
virtual RenderWindowPtr CreateRenderWindow()=0
Create a render window.
virtual double AspectRatio() const =0
virtual unsigned int ImageHeight() const =0
static const Vector3 Zero
virtual void SetFollowPGain(const double _pGain)=0
Set follow P Gain. Determines how fast the camera moves to follow the target node....
virtual void RemoveRenderPass(const RenderPassPtr &_pass)=0
virtual ~Camera()
Deconstructor.
Definition: gz/rendering/Camera.hh:48
virtual unsigned int ImageWidth() const =0
virtual unsigned int RenderTextureGLId() const =0
Get the OpenGL texture id associated with the render texture used by this camera. A valid id is retur...
virtual void Capture(Image &_image)=0
Renders a new frame and writes the results to the given image. This is a convenience function for sin...
virtual NodePtr TrackTarget() const =0
virtual Image CreateImage() const =0
Created an empty image buffer for capturing images. The resulting image will have sufficient memory a...
virtual void SetFollowTarget(const NodePtr &_target, const math::Vector3d &_offset=math::Vector3d::Zero, const bool _worldFrame=false)=0
Set a node for camera to follow. The camera will automatically update its position to keep itself at ...
virtual math::Angle HFOV() const =0
virtual void SetImageWidth(unsigned int _width)=0
virtual void SetTrackOffset(const math::Vector3d &_offset)=0
Set track offset. Camera will track a point that's at an offset from the target node....
virtual void SetAspectRatio(const double _ratio)=0
Set the camera's aspect ratio. This value determines the cameras vertical field-of-view....
virtual unsigned int ImageMemorySize() const =0
virtual math::Matrix4d ViewMatrix() const =0
virtual double FarClipPlane() const =0
virtual double TrackPGain() const =0
virtual math::Vector3d TrackOffset() const =0
virtual void Render()=0
Renders the current scene using this camera. This function assumes PreRender() has already been calle...
virtual void SetImageHeight(unsigned int _height)=0
virtual common::ConnectionPtr ConnectNewImageFrame(NewFrameListener _listener)=0
virtual unsigned int RenderPassCount() const =0
virtual void SetAntiAliasing(const unsigned int _aa)=0
Set the level of anti-aliasing used during rendering. If a value of 0 is given, no anti-aliasing will...
virtual math::Matrix4d ProjectionMatrix() const =0
virtual void SetMaterial(const MaterialPtr &_material)=0
virtual void SetImageFormat(PixelFormat _format)=0
Set the image pixel format.
virtual void SetFarClipPlane(const double _far)=0
virtual void SetFollowOffset(const math::Vector3d &_offset)=0
Set offset of camera from target node being followed. The offset will be in the frame that is specifi...
virtual void SetNearClipPlane(const double _near)=0
virtual unsigned int AntiAliasing() const =0
virtual bool SaveFrame(const std::string &_name)=0
Writes the previously rendered frame to a file. This function can be called multiple times after Post...
virtual void SetHFOV(const math::Angle &_hfov)=0
