gz/rendering/ogre2/Ogre2DynamicRenderable.hh
16 */
17 #ifndef GZ_RENDERING_OGRE2_OGRE2DYNAMICRENDERABLE_HH_
18 #define GZ_RENDERING_OGRE2_OGRE2DYNAMICRENDERABLE_HH_
20 #include <memory>
21 #include <string>
22 #include <vector>
23
24 #include "gz/rendering/ogre2/Export.hh"
26 #include "gz/rendering/Marker.hh"
27
28 #ifdef _MSC_VER
29  #pragma warning(push, 0)
30 #endif
31 #include <OgreHlmsPso.h>
32 #ifdef _MSC_VER
33  #pragma warning(pop)
34 #endif
35
36 namespace Ogre
37 {
38  class MovableObject;
39 }
40
41 namespace ignition
42 {
43  namespace rendering
44  {
45  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
46  //
47  // forward declarations
48  class Ogre2DynamicRenderablePrivate;
49
50  /* \class Ogre2DynamicRenderable Ogre2DynamicRenderable.hh \
51  * ignition/rendering/ogre2/Ogre2DynamicRenderable.hh
52  */
55  class IGNITION_RENDERING_OGRE2_VISIBLE Ogre2DynamicRenderable
56  {
59  public: explicit Ogre2DynamicRenderable(ScenePtr _scene);
60
62  public: virtual ~Ogre2DynamicRenderable();
63
66  public: void SetOperationType(MarkerType _opType);
67
70  public: MarkerType OperationType() const;
71
73  public: void Update();
74
76  public: Ogre::MovableObject *OgreObject() const;
77
81  public: void AddPoint(const gz::math::Vector3d &_pt,
82  const gz::math::Color &_color = gz::math::Color::White);
83
89  public: void AddPoint(const double _x, const double _y, const double _z,
90  const gz::math::Color &_color = gz::math::Color::White);
91
95  public: void SetPoint(unsigned int _index,
96  const gz::math::Vector3d &_value);
97
101  public: void SetColor(unsigned int _index,
102  const gz::math::Color &_color);
103
110  public: gz::math::Vector3d Point(unsigned int _index) const;
111
114  public: unsigned int PointCount() const;
115
117  public: void Clear();
118
120  public: void Destroy();
121
125  public: void SetMaterial(MaterialPtr _material, bool _unique = true);
126
128  private: void CreateDynamicMesh();
129
131  private: void UpdateBuffer();
132
137  private: void GenerateNormals(Ogre::OperationType _opType,
138  const std::vector<math::Vector3d> &_vertices, float *_vbuffer);
139
141  private: void DestroyBuffer();
142
145  };
146  }
147  }
148 }
149 #endif
Dynamic renderable class that manages hardware buffers for a dynamic geometry.
Definition: gz/rendering/ogre2/Ogre2DynamicRenderable.hh:56
Virtual destructor.
void AddPoint(const double _x, const double _y, const double _z, const gz::math::Color &_color=gz::math::Color::White)
Add a point to the point list.
Get the render operation type.
Return the position of an existing point in the point list.
void Clear()
Remove all points from the point list.
void SetColor(unsigned int _index, const gz::math::Color &_color)
Change the color of an existing point in the point list.
Set the render operation type.
Ogre::MovableObject * OgreObject() const
Get the ogre object associated with this dynamic renderable.
Return the total number of points in the point list.
void AddPoint(const gz::math::Vector3d &_pt, const gz::math::Color &_color=gz::math::Color::White)
void SetPoint(unsigned int _index, const gz::math::Vector3d &_value)
Change the location of an existing point in the point list.
void Destroy()
Destroy the dynamic renderable.
void SetMaterial(MaterialPtr _material, bool _unique=true)
Set the material for this dynamic renderable.
void Update()
Update the dynamic renderable.
MarkerType
Enum for marker types.
Definition: gz/rendering/Marker.hh:36
