Rendering classes and function useful in robot applications. More...
Classes | |
| class | ArrowVisual |
| Represents a arrow composite visual. More... | |
| class | AxisVisual |
| Represents a axis composite visual. More... | |
| class | BaseArrowVisual |
| class | BaseAxisVisual |
| class | BaseBoundingBoxCamera |
| class | BaseCamera |
| class | BaseCapsule |
| Base implementation of a Capsule Geometry. More... | |
| class | BaseCompositeStore |
| class | BaseCOMVisual |
| Base implementation of an center of mass visual. More... | |
| class | BaseDepthCamera |
| class | BaseDirectionalLight |
| class | BaseDistortionPass |
| Base distortion render pass. More... | |
| class | BaseGaussianNoisePass |
| Base Gaussian noise render pass. More... | |
| class | BaseGeometry |
| class | BaseGeometryStore |
| class | BaseGizmoVisual |
| A base implementation of the GizmoVisual class. More... | |
| class | BaseGpuRays |
| class | BaseGrid |
| Base implementation of a grid geometry. More... | |
| class | BaseHeightmap |
| class | BaseInertiaVisual |
| Base implementation of an inertia visual. More... | |
| class | BaseJointVisual |
| Base implementation of a joint visual. More... | |
| class | BaseLidarVisual |
| Base implementation of a Lidar Visual. More... | |
| class | BaseLight |
| class | BaseLightStore |
| class | BaseLightVisual |
| Base implementation of a light visual. More... | |
| class | BaseMap |
| class | BaseMarker |
| Base implementation of a Marker geometry. More... | |
| class | BaseMaterial |
| class | BaseMaterialMap |
| class | BaseMesh |
| class | BaseNode |
| class | BaseNodeCompositeStore |
| class | BaseNodeStore |
| class | BaseObject |
| class | BaseParticleEmitter |
| A base implementation of the ParticleEmitter class. More... | |
| class | BasePointLight |
| class | BaseRayQuery |
| A Ray Query class used for computing ray object intersections. More... | |
| class | BaseRenderEngine |
| class | BaseRenderPass |
| Base render pass that can be applied to a render target. More... | |
| class | BaseRenderTarget |
| class | BaseRenderTexture |
| class | BaseRenderWindow |
| class | BaseScene |
| class | BaseSceneStore |
| class | BaseSegmentationCamera |
| class | BaseSensor |
| class | BaseSensorStore |
| class | BaseSpotLight |
| class | BaseStore |
| class | BaseStoreWrapper |
| class | BaseSubMesh |
| class | BaseSubMeshStore |
| class | BaseText |
| Base implementation of a text geometry. More... | |
| class | BaseThermalCamera |
| Base implementation of the ThermalCamera class. More... | |
| class | BaseVisual |
| class | BaseVisualStore |
| class | BaseWireBox |
| Base implementation of a wireframe box. More... | |
| class | BoundingBox |
| 2D or 3D Bounding box. It stores the position / orientation / size info of the box and its label More... | |
| class | BoundingBoxCamera |
| Poseable BoundingBox camera used for rendering bounding boxes of objects in the scene. More... | |
| class | Camera |
| Posable camera used for rendering the scene graph. More... | |
| class | Capsule |
| Geometry for a capsule shape. More... | |
| class | CompositeStore |
| Represents a collection of Store objects, collectively working as a single composite store. More... | |
| class | CompositeVisual |
| Represents a predefined collection of geometries and visuals. More... | |
| class | COMVisual |
| Represents a center of mass visual. More... | |
| class | DepthCamera |
| class | DirectionalLight |
| Represents a infinite directional light. More... | |
| class | DistortionPass |
| A render pass that applies distortion to the render target. More... | |
| class | GaussianNoisePass |
| A render pass that applies Gaussian noise to the render target. More... | |
| class | Geometry |
| Represents a geometric shape to be rendered. More... | |
| class | GizmoVisual |
| A gizmo that contains rotate, translate, and scale visuals. More... | |
| class | GpuRays |
| Generate depth ray data. More... | |
| class | GraphicsAPIUtils |
| Utils to convert GraphicsAPI to and from strings. More... | |
| class | Grid |
| Represents a grid geometry drawn along the XY plane. If vertical cell count is specified then the grid becomes 3D. More... | |
| class | Heightmap |
| A terrain defined by a heightfield. More... | |
| class | HeightmapBlend |
| Blend information to be used between textures on heightmaps. More... | |
| class | HeightmapDescriptor |
| Describes how a Heightmap should be loaded. More... | |
| class | HeightmapTexture |
| Texture to be used on heightmaps. More... | |
| class | Image |
| Encapsulates a raw image buffer and relevant properties. More... | |
| class | InertiaVisual |
| Represents a inertia visual. More... | |
| class | JointVisual |
| Represents a joint visual. More... | |
| class | LidarVisual |
| A LidarVisual geometry class. The visual appearance is based on the type specified. More... | |
| class | Light |
| Represents a light source in the scene graph. More... | |
| class | LightVisual |
| Represents a light visual. More... | |
| class | Map |
| Storage map from std::string to template class T. More... | |
| class | Marker |
| A marker geometry class. The marker's visual appearance is based on the marker type specified. More... | |
| class | Material |
| Represents a surface material of a Geometry. More... | |
| class | Mesh |
| Represents a collection of mesh geometries. More... | |
| struct | MeshDescriptor |
| Describes how a Mesh should be loaded. More... | |
| class | MoveToHelper |
| Helper class for animating a user camera to move to a target entity. More... | |
| class | Node |
| Represents a single posable node in the scene graph. More... | |
| class | Object |
| Represents an object present in the scene graph. This includes sub-meshes, materials, render targets, as well as posable nodes. More... | |
| class | Ogre2ArrowVisual |
| Ogre2.x implementation of the arrow visual class. More... | |
| class | Ogre2AxisVisual |
| Ogre2.x implementation of the axis visual class. More... | |
| class | Ogre2BoundingBoxCamera |
| BoundingBox camera used to detect 2d / 3d bounding boxes of labeled objects in the scene. More... | |
| class | Ogre2Camera |
| Ogre2.x implementation of the camera class. More... | |
| class | Ogre2Capsule |
| Ogre 2.x implementation of a Capsule Geometry. More... | |
| class | Ogre2COMVisual |
| class | Ogre2Conversions |
| Conversions Conversions.hh rendering/Conversions.hh. More... | |
| class | Ogre2DepthCamera |
| Depth camera used to render depth data into an image buffer. More... | |
| class | Ogre2DirectionalLight |
| Ogre 2.x implementation of the directional light class. More... | |
| class | Ogre2DynamicRenderable |
| Dynamic renderable class that manages hardware buffers for a dynamic geometry. More... | |
| class | Ogre2GaussianNoisePass |
| Ogre2 Implementation of a Gaussian noise render pass. More... | |
| class | Ogre2Geometry |
| Ogre2.x implementation of the geometry class. More... | |
| class | Ogre2GizmoVisual |
| class | Ogre2GpuRays |
| Gpu Rays used to render range data into an image buffer The ogre2 implementation takes a 2 pass process to generate the final range data. 1st Pass: Creates a cubemap of range data. The cubemap is created from six cameras looking in all directions. Depending on the min/max angles specified, not all cameras need to be created. Internally in the 1st pass shaders, we reconstruct 3d viewspace pos from depth buffer data then convert them into ranges, i.e. length(pos.xyz). 2nd Pass: Samples range data from cubemap using predefined rays. The rays are generated based on the specified vertical and horizontal min/max angles and no. of samples. Each ray is a direction vector that is used to sample/lookup the range data stored in the faces of the cubemap. More... | |
| class | Ogre2Grid |
| Ogre2 implementation of a grid geometry. More... | |
| class | Ogre2Heightmap |
| Ogre implementation of a heightmap geometry. More... | |
| class | Ogre2InertiaVisual |
| Ogre2.x implementation of the inertia visual class. More... | |
| class | Ogre2JointVisual |
| class | Ogre2LidarVisual |
| Ogre 2.x implementation of a Lidar Visual. More... | |
| class | Ogre2Light |
| Ogre 2.x implementation of the light class. More... | |
| class | Ogre2LightVisual |
| Ogre2.x implementation of the light visual class. More... | |
| class | Ogre2Marker |
| Ogre 2.x implementation of a marker geometry. More... | |
| class | Ogre2Material |
| Ogre 2.x implementation of the material class. More... | |
| class | Ogre2MaterialSwitcher |
| Helper class to assign unique colors to renderables. More... | |
| class | Ogre2Mesh |
| Ogre2.x implementation of the mesh class. More... | |
| class | Ogre2MeshFactory |
| Ogre2.x implementation of the mesh factory class. More... | |
| class | Ogre2Node |
| Ogre2.x implementation of the Node class. More... | |
| class | Ogre2Object |
| Ogre2.x implementation of the Object class. More... | |
| class | Ogre2ParticleEmitter |
| Class to manage a particle emitter. More... | |
| class | Ogre2PointLight |
| Ogre 2.x implementation of the point light class. More... | |
| class | Ogre2RayQuery |
| class | Ogre2RenderEngine |
| Ogre2 render engine class. A singleton class that manages the underlying ogre2 render engine, loads its plugins, and creates resources needed for the engine to run. More... | |
| class | Ogre2RenderEnginePlugin |
| Plugin for loading ogre render engine. More... | |
| class | Ogre2RenderPass |
| Ogre2 Implementation of a render pass. More... | |
| class | Ogre2RenderTarget |
| Ogre2.x implementation of the render target class. More... | |
| class | Ogre2RenderTargetMaterial |
| Causes all objects in a scene to be rendered with the same material when rendered by a given RenderTarget. More... | |
| class | Ogre2RenderTexture |
| Ogre2.x implementation of the render texture class. More... | |
| class | Ogre2RenderWindow |
| Ogre2.x implementation of the render window class. More... | |
| class | Ogre2Scene |
| Ogre2.x implementation of the scene class. More... | |
| class | Ogre2SegmentationCamera |
| Segmentation camera used to label each pixel with a label id. Supports Semantic / Panoptic Segmentation. More... | |
| class | Ogre2SelectionBuffer |
| Generates a selection buffer object for a given camera. The selection buffer is used of entity selection. On setup, a unique color is assigned to each entity. Whenever a selection request is made, the selection buffer camera renders to a 1x1 sized offscreen buffer. The color value of that pixel gives the identity of the entity. More... | |
| class | Ogre2Sensor |
| Ogre2.x implementation of the sensor classs. More... | |
| class | Ogre2SpotLight |
| Ogre 2.x implementation of the spot light class. More... | |
| class | Ogre2SubMesh |
| Ogre2.x implementation of the submesh class. More... | |
| class | Ogre2SubMeshStoreFactory |
| Ogre2.x implementation of a submesh store factory class. More... | |
| class | Ogre2ThermalCamera |
| Thermal camera used to render thermal data into an image buffer. More... | |
| class | Ogre2Visual |
| Ogre2.x implementation of the visual class. More... | |
| class | Ogre2WireBox |
| Ogre2 implementation of a wire box geometry. More... | |
| class | OgreArrowVisual |
| class | OgreAxisVisual |
| class | OgreCamera |
| class | OgreCapsule |
| Ogre 2.x implementation of a Capsule Visual. More... | |
| class | OgreCOMVisual |
| class | OgreConversions |
| class | OgreDepthCamera |
| class | OgreDirectionalLight |
| class | OgreDistortionPass |
| Ogre implementation of the DistortionPass class. More... | |
| class | OgreDynamicLines |
| Class for drawing lines that can change. More... | |
| class | OgreDynamicRenderable |
| Abstract base class providing mechanisms for dynamically growing hardware buffers. More... | |
| class | OgreGaussianNoisePass |
| Ogre implementation of the GaussianNoisePass class. More... | |
| class | OgreGeometry |
| class | OgreGizmoVisual |
| class | OgreGpuRays |
| Gpu Rays used to render depth data into an image buffer. More... | |
| class | OgreGrid |
| Ogre implementation of a grid geometry. More... | |
| class | OgreHeightmap |
| class | OgreInertiaVisual |
| class | OgreJointVisual |
| class | OgreLidarVisual |
| Ogre implementation of a Lidar Visual. More... | |
| class | OgreLight |
| class | OgreLightVisual |
| class | OgreMarker |
| Ogre implementation of a marker geometry. More... | |
| class | OgreMaterial |
| class | OgreMaterialSwitcher |
| class | OgreMesh |
| class | OgreMeshFactory |
| class | OgreNode |
| class | OgreObject |
| class | OgreParticleEmitter |
| class | OgrePointLight |
| class | OgreRayQuery |
| class | OgreRenderEngine |
| class | OgreRenderEnginePlugin |
| class | OgreRenderPass |
| Ogre implementation of the RenderPass class. More... | |
| class | OgreRenderTarget |
| class | OgreRenderTargetMaterial |
| class | OgreRenderTexture |
| class | OgreRenderWindow |
| class | OgreRTShaderSystem |
| Implements Ogre's Run-Time Shader system. More... | |
| class | OgreScene |
| class | OgreSelectionBuffer |
| class | OgreSensor |
| class | OgreSpotLight |
| class | OgreSubMesh |
| class | OgreSubMeshStoreFactory |
| class | OgreText |
| Ogre implementation of text geometry. More... | |
| class | OgreThermalCamera |
| Depth camera used to render thermal data into an image buffer. More... | |
| class | OgreVisual |
| class | OgreWireBox |
| Ogre implementation of a wire box geometry. More... | |
| class | OrbitViewController |
| A camera view controller. More... | |
| class | OrthoViewController |
| Orthographic view controller. More... | |
| class | ParticleEmitter |
| class | PixelBuffer |
| Non owning, writable view of a caller owned pixel buffer. More... | |
| class | PixelUtil |
| Provides supporting functions for PixelFormat enum. More... | |
| class | PointLight |
| Represents a point light. More... | |
| class | RayQuery |
| class | RayQueryResult |
| A class that stores ray query intersection results. More... | |
| class | RenderEngine |
| An abstract interface to a concrete render-engine. A RenderEngine is responsible for initializing a render-engine as well as creating, storing, and destroying scenes. More... | |
| class | RenderEngineManager |
| Collection of render-engines. This provides access to all the render-engines available at runtime. RenderEngine objects should not be access directly, but instead via the RenderEngineManager to maintain a flexible render-engine agnostic design. More... | |
| class | RenderEnginePlugin |
| Base plugin class for render engines. More... | |
| class | RenderPass |
| A render pass can be added to a camera to affect how the scene is rendered. It can be used to add post-processing effects. Multiple passes can be chained together. More... | |
| class | RenderPassFactory |
| A factory interface for creating render passes. More... | |
| class | RenderPassSystem |
| A class for creating and managing render passes. More... | |
| class | RenderTarget |
| Represents a render-target to which cameras can render images. More... | |
| class | RenderTexture |
| Represents a off-screen render-texture to which cameras can render images. More... | |
| class | RenderWindow |
| Represents a on-screen render-window to which cameras can render images. More... | |
| class | Scene |
| Manages a single scene-graph. This class updates scene-wide properties and holds the root scene node. A Scene also serves as a factory for all scene objects. More... | |
| class | SegmentationCamera |
| Poseable Segmentation camera used for rendering the scene graph. This camera is designed to produce segmentation data, instead of a 2D image. More... | |
| class | Sensor |
| Represents a scene sensor. The most obvious example is a camera, but it can be anything that generates output from the scene. More... | |
| class | ShaderParam |
| a variant type that holds params that can be passed to a shader More... | |
| class | ShaderParams |
| a map that holds params to be passed to a shader More... | |
| class | ShaderUtil |
| Provides supporting functions for ShaderType enum. More... | |
| class | SpotLight |
| Represents a spotlight. More... | |
| class | Store |
| Multi-access storage structure of template class T. Template class T is expected to have functions GetId, GetName(), Destroy() which return unsigned int, std::string, and void respectively. This store will ensure that each element's name and ID are unique. More... | |
| class | StoreWrapper |
| Simple wrapper class that allows a Store of type Derived to be treated as a Store of type Base, where Derived is some class derived from Base. This is useful in storing Stores of different derived types in a single CompositeStore instance. More... | |
| class | SubMesh |
| Represents a single mesh geometry. More... | |
| class | Text |
| Represents a billboard text geometry that is always facing the camera. More... | |
| class | ThermalCamera |
| Thermal camera that produces temperature data. An object's temperature can be set through the Visual class using SetUserData with the key "temperature". Ambient temperature is returned for object that do not have this property set. Note that temperature variations for the environment and objects can be set using the Set*Range functions in this class. For simplicity, the variations are modeled as a function of depth (which is not how a real thermal sensor works). Ideally we support heatmaps for visuals in order to produce more realistic temperature output. More... | |
| class | TransformController |
| An transform tool for translating, rotating, and scaling objects. More... | |
| class | ViewController |
| class | Visual |
| Represents a visual node in a scene graph. A Visual is the only node that can have Geometry and other Visual children. More... | |
| class | WireBox |
| Draws a wireframe box. More... | |
Enumerations | |
| enum class | BoundingBoxType { BBT_FULLBOX2D = 0 , BBT_VISIBLEBOX2D = 1 , BBT_BOX3D = 2 } |
| BoundingBox types for Visible / Full 2D Boxes / 3D Boxes. More... | |
| enum | CameraProjectionType { CPT_PERSPECTIVE , CPT_ORTHOGRAPHIC } |
| Enum for projection types. More... | |
| enum | EmitterType { EM_POINT = 0 , EM_BOX = 1 , EM_CYLINDER = 2 , EM_ELLIPSOID = 3 , EM_NUM_EMITTERS = 4 } |
| Enum for emitter types. More... | |
| enum class | GraphicsAPI : uint16_t { GRAPHICS_API_BEGIN = 0 , UNKNOWN = GRAPHICS_API_BEGIN , OPENGL = 1 , DIRECT3D11 = 2 , VULKAN = 3 , METAL = 4 , GRAPHICS_API_END } |
| The graphics API used by the render engine. More... | |
| enum | JointVisualType { JVT_NONE = 0 , JVT_REVOLUTE = 1 , JVT_REVOLUTE2 = 2 , JVT_PRISMATIC = 3 , JVT_UNIVERSAL = 4 , JVT_BALL = 5 , JVT_SCREW = 6 , JVT_GEARBOX = 7 , JVT_FIXED = 8 } |
| Enum for JointVisual types. More... | |
| enum | LidarVisualType { LVT_NONE = 0 , LVT_RAY_LINES = 1 , LVT_POINTS = 2 , LVT_TRIANGLE_STRIPS = 3 } |
| Enum for LidarVisual types. More... | |
| enum | LightVisualType { LVT_EMPTY = 0 , LVT_POINT = 1 , LVT_DIRECTIONAL = 2 , LVT_SPOT = 3 } |
| Enum for LightVisual types. More... | |
| enum | MarkerType { MT_NONE = 0 , MT_BOX = 1 , MT_CYLINDER = 2 , MT_LINE_STRIP = 3 , MT_LINE_LIST = 4 , MT_POINTS = 5 , MT_SPHERE = 6 , MT_TEXT = 7 , MT_TRIANGLE_FAN = 8 , MT_TRIANGLE_LIST = 9 , MT_TRIANGLE_STRIP = 10 , MT_CAPSULE = 11 } |
| Enum for marker types. More... | |
| enum | MaterialType { MT_CLASSIC = 0 , MT_PBS = 1 } |
| An enum for the type of material. More... | |
| enum | PixelFormat { PF_UNKNOWN = 0 , PF_L8 = 1 , PF_R8G8B8 = 2 , PF_B8G8R8 = 3 , PF_BAYER_RGGB8 = 4 , PF_BAYER_BGGR8 = 5 , PF_BAYER_GBGR8 = 6 , PF_BAYER_GRGB8 = 7 , PF_FLOAT32_R = 8 , PF_FLOAT32_RGBA = 9 , PF_FLOAT32_RGB = 10 , PF_L16 = 11 , PF_R8G8B8A8 = 12 , PF_COUNT = 13 } |
| Image pixel format types. More... | |
| enum class | SegmentationType { ST_SEMANTIC = 0 , ST_PANOPTIC = 1 } |
| Segmentation types for Semantic / Panpoptic segmentation. More... | |
| enum | ShaderType { ST_UNKNOWN = 0 , ST_PIXEL = 1 , ST_VERTEX = 2 , ST_NORM_OBJ = 3 , ST_NORM_TAN = 4 , ST_COUNT = 5 } |
| Available types of shaders. Note that not all rendering-engines will be able to use each type. They will instead default to the closest alternative. More... | |
| enum class | TextHorizontalAlign { LEFT = 0 , CENTER = 1 , RIGHT = 2 } |
| Text Horizontal alignment. More... | |
| enum class | TextVerticalAlign { BOTTOM = 0 , CENTER = 1 , TOP = 2 } |
| Text vertical alignment. More... | |
| enum | TransformAxis { TA_NONE = 0 , TA_TRANSLATION_X = 0x00000001 , TA_TRANSLATION_Y = 0x00000002 , TA_TRANSLATION_Z = 0x00000004 , TA_ROTATION_X = 0x00000010 , TA_ROTATION_Y = 0x00000020 , TA_ROTATION_Z = 0x00000040 , TA_SCALE_X = 0x00000100 , TA_SCALE_Y = 0x00000200 , TA_SCALE_Z = 0x00000400 } |
| Unique identifiers for transformation axes. More... | |
| enum | TransformMode { TM_NONE = 0 , TM_TRANSLATION = TA_TRANSLATION_X | TA_TRANSLATION_Y | TA_TRANSLATION_Z , TM_ROTATION = TA_ROTATION_X | TA_ROTATION_Y | TA_ROTATION_Z , TM_SCALE = TA_SCALE_X | TA_SCALE_Y , TA_SCALEZ } |
| Unique identifiers for transformation modes. More... | |
| enum | TransformSpace { TS_LOCAL , TS_WORLD } |
| Unique identifiers for transformation spaces. More... | |
Functions | |
| RenderEngine * | engine (const std::string &_name, const std::map< std::string, std::string > &_params={}, const std::string &_path="") |
| Get the render-engine registered under the given name. If no render-engine is registered under the given name, NULL will be returned. If the engine is registered, but not loaded, this function will load it. More... | |
| RenderEngine * | engine (const unsigned int _index, const std::map< std::string, std::string > &_params={}, const std::string &_path="") |
| Get the render-engine registered at the given index. If no render-engine is registered at the given index, NULL will be returned. If the engine is registered, but not loaded, this function will load it. More... | |
| unsigned int | engineCount () |
| Get the number of available render-engines. More... | |
| bool | fini () |
| Destroy all render-engines and related resources. More... | |
| bool | hasEngine (const std::string &_name) |
| Determine if a render-engine is registered under the given name. More... | |
| bool | init () |
| Initialized shared render-engine features. More... | |
| bool | isEngineLoaded (const std::string &_name) |
| Determine if a render-engine is already loaded. More... | |
| bool | load () |
| Load shared render-engine resources. More... | |
| std::vector< std::string > | loadedEngines () |
| Get the names of all engines currently loaded. More... | |
| ignition::math::Matrix3d | projectionToCameraIntrinsic (const ignition::math::Matrix4d &_projectionMatrix, double _width, double _height) |
| Convert a given camera projection matrix to an intrinsics matrix. Intrinsics matrix is different from the matrix returned by Camera::ProjectionMatrix(), which is used by OpenGL internally. The matrix returned contains the camera calibrated values. More... | |
| void | registerEngine (const std::string &_name, RenderEngine *_engine) |
| Register a new render-engine under the given name. If the given name is already in use, the render-engine will not be registered. More... | |
| ScenePtr | sceneFromFirstRenderEngine () |
| Most applications will only have one rendering engine loaded at a time, and only one scene within that. This helper function gets the first scene that can be found in the first loaded rendering engine. More... | |
| float | screenScalingFactor () |
| Get the screen scaling factor. More... | |
| math::Vector3d | screenToPlane (const math::Vector2i &_screenPos, const CameraPtr &_camera, const RayQueryPtr &_rayQuery, const float _offset=0.0) |
| Retrieve the point on a plane at z = 0 in the 3D scene hit by a ray cast from the given 2D screen coordinates. More... | |
| math::Vector3d | screenToScene (const math::Vector2i &_screenPos, const CameraPtr &_camera, const RayQueryPtr &_rayQuery, float _maxDistance=10.0) |
| Retrieve the first point on a surface in the 3D scene hit by a ray cast from the given 2D screen coordinates. More... | |
| math::Vector3d | screenToScene (const math::Vector2i &_screenPos, const CameraPtr &_camera, const RayQueryPtr &_rayQuery, RayQueryResult &_rayResult, float _maxDistance=10.0) |
| void | setPluginPaths (const std::list< std::string > &_paths) |
| Set the plugin paths from which render engines can be loaded. More... | |
| ignition::math::AxisAlignedBox | transformAxisAlignedBox (const ignition::math::AxisAlignedBox &_box, const ignition::math::Pose3d &_pose) |
| Transform a bounding box. More... | |
| bool | unloadEngine (const std::string &_name) |
| Unload the render-engine registered under the given name. More... | |
| void | unregisterEngine (const std::string &_name) |
| Unregister a render-engine registered under the given name. If the no render-engine is registered under the given name no work will be done. More... | |
| void | unregisterEngine (const unsigned int _index) |
| Unregister a render-engine at the given index. If the no render-engine is registered at the given index, no work will be done. More... | |
| void | unregisterEngine (RenderEngine *_engine) |
| Unregister the given render-engine. If the given render-engine is not currently registered, no work will be done. More... | |
Variables | |
| const std::string | depth_fragment_shader_file |
| const std::string | depth_vertex_shader_file |
| static const common::Pbr | kDefaultPbr |
| Default pbr material properties. More... | |
Typedef Documentation
◆ ArrowVisualPtr
| const ArrowVisualPtr |
Shared pointer to ArrowVisual.
Shared pointer to const ArrowVisual.
◆ AxisVisualPtr
| const AxisVisualPtr |
Shared pointer to AxisVisual.
Shared pointer to const AxisVisual.
◆ BaseNodeCompositeStorePtr
◆ BaseObjectPtr
| typedef std::shared_ptr<BaseObject> BaseObjectPtr |
◆ BoundingBoxCameraPtr
| const BoundingBoxCameraPtr |
Shared pointer to BoundingBoxCamera.
Shared pointer to const BoundingBox Camera.
◆ CameraPtr
◆ CapsulePtr
Shared pointer to Capsule.
◆ COMVisualPtr
Shared pointer to COMVisual.
◆ ConstArrowVisualPtr
| typedef shared_ptr<const ArrowVisual> ConstArrowVisualPtr |
◆ ConstAxisVisualPtr
| typedef shared_ptr<const AxisVisual> ConstAxisVisualPtr |
◆ ConstBoundingBoxCameraPtr
| typedef shared_ptr<const BoundingBoxCamera> ConstBoundingBoxCameraPtr |
◆ ConstCameraPtr
| typedef shared_ptr<const Camera> ConstCameraPtr |
◆ ConstDepthCameraPtr
| typedef shared_ptr<const DepthCamera> ConstDepthCameraPtr |
◆ ConstDirectionalLightPtr
| typedef shared_ptr<const DirectionalLight> ConstDirectionalLightPtr |
◆ ConstGaussianNoisePass
| const ConstGaussianNoisePass |
Shared pointer to const GaussianNoisePass.
◆ ConstGeometryPtr
| typedef shared_ptr<const Geometry> ConstGeometryPtr |
◆ ConstGizmoVisualPtr
| typedef shared_ptr<const GizmoVisual> ConstGizmoVisualPtr |
◆ ConstGpuRaysPtr
| typedef shared_ptr<const GpuRays> ConstGpuRaysPtr |
◆ ConstHeightmapPtr
| typedef shared_ptr<const Heightmap> ConstHeightmapPtr |
◆ ConstImagePtr
| typedef shared_ptr<const Image> ConstImagePtr |
◆ ConstJointVisualPtr
| typedef shared_ptr<const JointVisual> ConstJointVisualPtr |
◆ ConstLidarVisualPtr
| typedef shared_ptr<const LidarVisual> ConstLidarVisualPtr |
◆ ConstLightPtr
| typedef shared_ptr<const Light> ConstLightPtr |
◆ ConstMaterialPtr
| typedef shared_ptr<const Material> ConstMaterialPtr |
◆ ConstMeshPtr
| typedef shared_ptr<const Mesh> ConstMeshPtr |
◆ ConstNodePtr
| typedef shared_ptr<const Node> ConstNodePtr |
◆ ConstObjectFactoryPtr
| typedef shared_ptr<const ObjectFactory> ConstObjectFactoryPtr |
◆ ConstObjectPtr
| typedef shared_ptr<const Object> ConstObjectPtr |
◆ ConstParticleEmitterPtr
| typedef shared_ptr<const ParticleEmitter> ConstParticleEmitterPtr |
◆ ConstPointLightPtr
| typedef shared_ptr<const PointLight> ConstPointLightPtr |
◆ ConstRayQueryPtr
| typedef shared_ptr<const RayQuery> ConstRayQueryPtr |
◆ ConstRenderPassPtr
| typedef shared_ptr<const RenderPass> ConstRenderPassPtr |
◆ ConstRenderPassSystemPtr
| typedef shared_ptr<const RenderPassSystem> ConstRenderPassSystemPtr |
◆ ConstRenderTargetPtr
| typedef shared_ptr<const RenderTarget> ConstRenderTargetPtr |
◆ ConstRenderTexturePtr
| typedef shared_ptr<const RenderTexture> ConstRenderTexturePtr |
◆ ConstRenderWindowPtr
| typedef shared_ptr<const RenderWindow> ConstRenderWindowPtr |
◆ ConstScenePtr
| typedef shared_ptr<const Scene> ConstScenePtr |
◆ ConstSegmentationCameraPtr
| typedef shared_ptr<const SegmentationCamera> ConstSegmentationCameraPtr |
◆ ConstSensorPtr
| typedef shared_ptr<const Sensor> ConstSensorPtr |
◆ ConstShaderParamsPtr
| typedef shared_ptr<const ShaderParams> ConstShaderParamsPtr |
Shared pointer to const ShaderParams.
◆ ConstSpotLightPtr
| typedef shared_ptr<const SpotLight> ConstSpotLightPtr |
◆ ConstSubMeshPtr
| typedef shared_ptr<const SubMesh> ConstSubMeshPtr |
◆ ConstTextPtr
| typedef shared_ptr<const Text> ConstTextPtr |
◆ ConstThermalCameraPtr
| typedef shared_ptr<const ThermalCamera> ConstThermalCameraPtr |
◆ ConstVisualPtr
| typedef shared_ptr<const Visual> ConstVisualPtr |
◆ DepthCameraPtr
| const DepthCameraPtr |
Shared pointer to DepthCamera.
Shared pointer to const DepthCamera.
◆ DirectionalLightPtr
| const DirectionalLightPtr |
Shared pointer to DirectionalLight.
Shared pointer to const DirectionalLight.
◆ DistortionPassPtr
Shared pointer to DistortionPass.
◆ GaussianNoisePassPtr
Shared pointer to GaussianNoisePass.
◆ GeometryPtr
| const GeometryPtr |
◆ GeometryStore
| typedef Store<Geometry> GeometryStore |
◆ GeometryStorePtr
| typedef std::shared_ptr<GeometryStore> GeometryStorePtr |
◆ GizmoVisualPtr
| const GizmoVisualPtr |
Shared pointer to GizmoVisual.
Shared pointer to const GizmoVisual.
◆ GpuRaysPtr
| const GpuRaysPtr |
◆ GridPtr
◆ HeightmapPtr
| const HeightmapPtr |
◆ ImagePtr
◆ InertiaVisualPtr
◆ JointVisualPtr
| const JointVisualPtr |
Shared pointer to JointVisual.
Shared pointer to const JointVisual.
◆ LidarVisualPtr
| const LidarVisualPtr |
Shared pointer to LidarVisual.
Shared pointer to const LidarVisual.
◆ LightPtr
◆ LightStore
| typedef Store<Light> LightStore |
◆ LightStorePtr
| typedef std::shared_ptr<LightStore> LightStorePtr |
◆ LightVisualPtr
Shared pointer to Light.
◆ MarkerPtr
◆ MaterialMap
| typedef Map<Material> MaterialMap |
◆ MaterialMapPtr
| typedef std::shared_ptr<MaterialMap> MaterialMapPtr |
◆ MaterialPtr
| const MaterialPtr |
◆ MeshPtr
◆ NodeCompositeStore
| typedef CompositeStore<Node> NodeCompositeStore |
◆ NodeCompositeStorePtr
◆ NodePtr
◆ NodeStore
◆ NodeStorePtr
| typedef std::shared_ptr<NodeStore> NodeStorePtr |
◆ ObjectFactoryPtr
| const ObjectFactoryPtr |
Shared pointer to ObjectFactory.
Shared pointer to const ObjectFactory.
◆ ObjectPtr
◆ Ogre2ArrowVisualPtr
◆ Ogre2AxisVisualPtr
| typedef shared_ptr<Ogre2AxisVisual> Ogre2AxisVisualPtr |
◆ Ogre2BoundingBoxCameraPtr
◆ Ogre2CameraPtr
| typedef shared_ptr<Ogre2Camera> Ogre2CameraPtr |
◆ Ogre2CapsulePtr
| typedef shared_ptr<Ogre2Capsule> Ogre2CapsulePtr |
◆ Ogre2COMVisualPtr
| typedef shared_ptr<Ogre2COMVisual> Ogre2COMVisualPtr |
◆ Ogre2DepthCameraPtr
◆ Ogre2DirectionalLightPtr
◆ Ogre2GeometryPtr
| typedef shared_ptr<Ogre2Geometry> Ogre2GeometryPtr |
◆ Ogre2GeometryStore
| typedef BaseGeometryStore< Ogre2Geometry > Ogre2GeometryStore |
◆ Ogre2GeometryStorePtr
◆ Ogre2GizmoVisualPtr
◆ Ogre2GpuRaysPtr
| typedef shared_ptr<Ogre2GpuRays> Ogre2GpuRaysPtr |
◆ Ogre2GridPtr
| typedef shared_ptr<Ogre2Grid> Ogre2GridPtr |
◆ Ogre2HeightmapPtr
| typedef shared_ptr<Ogre2Heightmap> Ogre2HeightmapPtr |
◆ Ogre2InertiaVisualPtr
◆ Ogre2JointVisualPtr
◆ Ogre2LidarVisualPtr
◆ Ogre2LightPtr
| typedef shared_ptr<Ogre2Light> Ogre2LightPtr |
◆ Ogre2LightStore
| typedef BaseLightStore< Ogre2Light > Ogre2LightStore |
◆ Ogre2LightStorePtr
| typedef std::shared_ptr< Ogre2LightStore > Ogre2LightStorePtr |
◆ Ogre2LightVisualPtr
◆ Ogre2MarkerPtr
| typedef shared_ptr<Ogre2Marker> Ogre2MarkerPtr |
◆ Ogre2MaterialMap
| typedef BaseMaterialMap<Ogre2Material> Ogre2MaterialMap |
◆ Ogre2MaterialMapPtr
◆ Ogre2MaterialPtr
| typedef shared_ptr<Ogre2Material> Ogre2MaterialPtr |
◆ Ogre2MeshFactoryPtr
◆ Ogre2MeshPtr
| typedef shared_ptr<Ogre2Mesh> Ogre2MeshPtr |
◆ Ogre2NodePtr
| typedef shared_ptr<Ogre2Node> Ogre2NodePtr |
◆ Ogre2NodeStore
| typedef BaseNodeStore< Ogre2Node > Ogre2NodeStore |
◆ Ogre2NodeStorePtr
| typedef std::shared_ptr< Ogre2NodeStore > Ogre2NodeStorePtr |
◆ Ogre2ObjectPtr
| typedef shared_ptr<Ogre2Object> Ogre2ObjectPtr |
◆ Ogre2ParticleEmitterPtr
◆ Ogre2PointLightPtr
| typedef shared_ptr<Ogre2PointLight> Ogre2PointLightPtr |
◆ Ogre2RayQueryPtr
| typedef shared_ptr<Ogre2RayQuery> Ogre2RayQueryPtr |
◆ Ogre2RenderEnginePtr
◆ Ogre2RenderTargetMaterialPtr
◆ Ogre2RenderTargetPtr
◆ Ogre2RenderTexturePtr
◆ Ogre2RenderWindowPtr
◆ Ogre2ScenePtr
| typedef shared_ptr<Ogre2Scene> Ogre2ScenePtr |
◆ Ogre2SceneStore
| typedef BaseSceneStore< Ogre2Scene > Ogre2SceneStore |
◆ Ogre2SceneStorePtr
| typedef std::shared_ptr< Ogre2SceneStore > Ogre2SceneStorePtr |
◆ Ogre2SegmentationCameraPtr
◆ Ogre2SensorPtr
| typedef shared_ptr<Ogre2Sensor> Ogre2SensorPtr |
◆ Ogre2SensorStore
| typedef BaseSensorStore< Ogre2Sensor > Ogre2SensorStore |
◆ Ogre2SensorStorePtr
| typedef std::shared_ptr< Ogre2SensorStore > Ogre2SensorStorePtr |
◆ Ogre2SpotLightPtr
| typedef shared_ptr<Ogre2SpotLight> Ogre2SpotLightPtr |
◆ Ogre2SubMeshPtr
| typedef shared_ptr<Ogre2SubMesh> Ogre2SubMeshPtr |
◆ Ogre2SubMeshStore
| typedef BaseSubMeshStore< Ogre2SubMesh > Ogre2SubMeshStore |
◆ Ogre2SubMeshStorePtr
| typedef std::shared_ptr< Ogre2SubMeshStore > Ogre2SubMeshStorePtr |
◆ Ogre2ThermalCameraPtr
◆ Ogre2VisualPtr
| typedef shared_ptr<Ogre2Visual> Ogre2VisualPtr |
◆ Ogre2VisualStore
| typedef BaseVisualStore< Ogre2Visual > Ogre2VisualStore |
◆ Ogre2VisualStorePtr
| typedef std::shared_ptr< Ogre2VisualStore > Ogre2VisualStorePtr |
◆ Ogre2WireBoxPtr
| typedef shared_ptr<Ogre2WireBox> Ogre2WireBoxPtr |
◆ OgreArrowVisualPtr
| typedef shared_ptr<OgreArrowVisual> OgreArrowVisualPtr |
◆ OgreAxisVisualPtr
| typedef shared_ptr<OgreAxisVisual> OgreAxisVisualPtr |
◆ OgreCameraPtr
| typedef shared_ptr<OgreCamera> OgreCameraPtr |
◆ OgreCapsulePtr
| typedef shared_ptr<OgreCapsule> OgreCapsulePtr |
◆ OgreCOMVisualPtr
| typedef shared_ptr<OgreCOMVisual> OgreCOMVisualPtr |
◆ OgreDepthCameraPtr
| typedef shared_ptr<OgreDepthCamera> OgreDepthCameraPtr |
◆ OgreDirectionalLightPtr
◆ OgreGeometryPtr
| typedef shared_ptr<OgreGeometry> OgreGeometryPtr |
◆ OgreGeometryStore
| typedef BaseGeometryStore< OgreGeometry > OgreGeometryStore |
◆ OgreGeometryStorePtr
| typedef std::shared_ptr< OgreGeometryStore > OgreGeometryStorePtr |
◆ OgreGizmoVisualPtr
| typedef shared_ptr<OgreGizmoVisual> OgreGizmoVisualPtr |
◆ OgreGpuRaysPtr
| typedef shared_ptr<OgreGpuRays> OgreGpuRaysPtr |
◆ OgreGridPtr
| typedef shared_ptr<OgreGrid> OgreGridPtr |
◆ OgreHeightmapPtr
| typedef shared_ptr<OgreHeightmap> OgreHeightmapPtr |
◆ OgreInertiaVisualPtr
◆ OgreJointVisualPtr
| typedef shared_ptr<OgreJointVisual> OgreJointVisualPtr |
◆ OgreLidarVisualPtr
| typedef shared_ptr<OgreLidarVisual> OgreLidarVisualPtr |
◆ OgreLightPtr
| typedef shared_ptr< OgreLight > OgreLightPtr |
◆ OgreLightStore
| typedef BaseLightStore< OgreLight > OgreLightStore |
◆ OgreLightStorePtr
| typedef std::shared_ptr< OgreLightStore > OgreLightStorePtr |
◆ OgreLightVisualPtr
| typedef shared_ptr<OgreLightVisual> OgreLightVisualPtr |
◆ OgreMarkerPtr
| typedef shared_ptr<OgreMarker> OgreMarkerPtr |
◆ OgreMaterialMap
| typedef BaseMaterialMap< OgreMaterial > OgreMaterialMap |
◆ OgreMaterialMapPtr
| typedef std::shared_ptr< OgreMaterialMap > OgreMaterialMapPtr |
◆ OgreMaterialPtr
| typedef shared_ptr<OgreMaterial> OgreMaterialPtr |
◆ OgreMeshFactoryPtr
| typedef shared_ptr<OgreMeshFactory> OgreMeshFactoryPtr |
◆ OgreMeshPtr
| typedef shared_ptr<OgreMesh> OgreMeshPtr |
◆ OgreNodePtr
| typedef shared_ptr<OgreNode> OgreNodePtr |
◆ OgreNodeStore
| typedef BaseNodeStore< OgreNode > OgreNodeStore |
◆ OgreNodeStorePtr
| typedef std::shared_ptr< OgreNodeStore > OgreNodeStorePtr |
◆ OgreObjectPtr
| typedef shared_ptr<OgreObject> OgreObjectPtr |
◆ OgreParticleEmitterPtr
◆ OgrePointLightPtr
| typedef shared_ptr<OgrePointLight> OgrePointLightPtr |
◆ OgreRayQueryPtr
| typedef shared_ptr<OgreRayQuery> OgreRayQueryPtr |
◆ OgreRenderEnginePtr
◆ OgreRenderTargetMaterialPtr
◆ OgreRenderTargetPtr
◆ OgreRenderTexturePtr
◆ OgreRenderWindowPtr
◆ OgreScenePtr
| typedef shared_ptr<OgreScene> OgreScenePtr |
◆ OgreSceneStore
| typedef BaseSceneStore< OgreScene > OgreSceneStore |
◆ OgreSceneStorePtr
| typedef std::shared_ptr< OgreSceneStore > OgreSceneStorePtr |
◆ OgreSensorPtr
| typedef shared_ptr<OgreSensor> OgreSensorPtr |
◆ OgreSensorStore
| typedef BaseSensorStore< OgreSensor > OgreSensorStore |
◆ OgreSensorStorePtr
| typedef std::shared_ptr< OgreSensorStore > OgreSensorStorePtr |
◆ OgreSpotLightPtr
| typedef shared_ptr<OgreSpotLight> OgreSpotLightPtr |
◆ OgreSubMeshPtr
| typedef shared_ptr<OgreSubMesh> OgreSubMeshPtr |
◆ OgreSubMeshStore
| typedef BaseSubMeshStore< OgreSubMesh > OgreSubMeshStore |
◆ OgreSubMeshStorePtr
| typedef std::shared_ptr< OgreSubMeshStore > OgreSubMeshStorePtr |
◆ OgreTextPtr
| typedef shared_ptr<OgreText> OgreTextPtr |
◆ OgreThermalCameraPtr
◆ OgreVisualPtr
| typedef shared_ptr<OgreVisual> OgreVisualPtr |
◆ OgreVisualStore
| typedef BaseVisualStore< OgreVisual > OgreVisualStore |
◆ OgreVisualStorePtr
| typedef std::shared_ptr< OgreVisualStore > OgreVisualStorePtr |
◆ OgreWireBoxPtr
| typedef shared_ptr<OgreWireBox> OgreWireBoxPtr |
◆ ParticleEmitterPtr
| const ParticleEmitterPtr |
Shared pointer to ParticleEmitter.
Shared pointer to const ParticleEmitter.
◆ PointLightPtr
| const PointLightPtr |
Shared pointer to PointLight.
Shared pointer to const PointLight.
◆ RayQueryPtr
Shared pointer to RayQuery.
◆ RenderPassPtr
| const RenderPassPtr |
Shared pointer to RenderPass.
Shared pointer to const RenderPass.
◆ RenderPassSystemPtr
| const RenderPassSystemPtr |
Shared pointer to RenderPassSystem.
Shared pointer to const RenderPassSystem.
◆ RenderTargetPtr
| const RenderTargetPtr |
Shared pointer to RenderTarget.
Shared pointer to const RenderTarget.
◆ RenderTexturePtr
| const RenderTexturePtr |
Shared pointer to RenderTexture.
Shared pointer to const RenderTexture.
◆ RenderWindowPtr
| const RenderWindowPtr |
Shared pointer to RenderWindow.
Shared pointer to const RenderWindow.
◆ ScenePtr
◆ SceneStore
| typedef Store<Scene> SceneStore |
◆ SceneStorePtr
| typedef std::shared_ptr<SceneStore> SceneStorePtr |
◆ SegmentationCameraPtr
| const SegmentationCameraPtr |
◆ SensorPtr
◆ SensorStore
| typedef Store<Sensor> SensorStore |
◆ SensorStorePtr
| typedef std::shared_ptr<SensorStore> SensorStorePtr |
◆ ShaderParamsPtr
| typedef shared_ptr<ShaderParams> ShaderParamsPtr |
Shared pointer to ShaderParams.
◆ shared_ptr
| using shared_ptr = std::shared_ptr<T> |
◆ SpotLightPtr
| const SpotLightPtr |
◆ SubMeshPtr
| const SubMeshPtr |
◆ SubMeshStore
| typedef Store<SubMesh> SubMeshStore |
◆ SubMeshStorePtr
| typedef std::shared_ptr<SubMeshStore> SubMeshStorePtr |
◆ TextPtr
◆ ThermalCameraPtr
| const ThermalCameraPtr |
Shared pointer to ThermalCamera.
Shared pointer to const ThermalCamera.
◆ Variant
| using Variant = std::variant<std::monostate, int, float, double, std::string, bool, unsigned int> |
Alias for a variant that can hold various types of data. The first type of the variant is std::monostate in order to prevent default-constructed variants from holding a type (a default-constructed variant is returned when a user calls Node::UserData with a key that doesn't exist for the node. In this case, since the key doesn't exist, the variant that is returned shouldn't hold any types - an "empty variant" should be returned for keys that don't exist)
◆ VisualPtr
◆ VisualStore
| typedef Store<Visual> VisualStore |
◆ VisualStorePtr
| typedef std::shared_ptr<VisualStore> VisualStorePtr |
◆ WireBoxPtr
Shared pointer to WireBox.
◆ BoundingBoxType
strong |
| Enumerator | |
| BBT_FULLBOX2D | 2D box that shows the full box of occluded objects |
| BBT_VISIBLEBOX2D | 2D box that shows the visible part of the occluded object |
| BBT_BOX3D | 3D oriented box |
◆ CameraProjectionType
| enum CameraProjectionType |
◆ EmitterType
| enum EmitterType |
◆ GraphicsAPI
strong |
◆ JointVisualType
| enum JointVisualType |
◆ LidarVisualType
| enum LidarVisualType |
| Enumerator | |
| LVT_NONE | No type. |
| LVT_RAY_LINES | Ray line visual. |
| LVT_POINTS | Points visual. |
| LVT_TRIANGLE_STRIPS | Triangle strips visual. |
◆ LightVisualType
| enum LightVisualType |
| Enumerator | |
| LVT_EMPTY | No type. |
| LVT_POINT | Point light. |
| LVT_DIRECTIONAL | Directional light. |
| LVT_SPOT | Spot light. |
◆ MarkerType
| enum MarkerType |
| Enumerator | |
| MT_NONE | No type. |
| MT_BOX | Box geometry. |
| MT_CYLINDER | Cylinder geometry. |
| MT_LINE_STRIP | Line strip primitive. |
| MT_LINE_LIST | Line list primitive. |
| MT_POINTS | Points primitive. |
| MT_SPHERE | Sphere geometry. |
| MT_TEXT | Text geometry. |
| MT_TRIANGLE_FAN | Triangle fan primitive. |
| MT_TRIANGLE_LIST | Triangle list primitive. |
| MT_TRIANGLE_STRIP | Triangle strip primitive. |
| MT_CAPSULE | Capsule geometry. |
◆ MaterialType
| enum MaterialType |
◆ PixelFormat
| enum PixelFormat |
PixelFormat.hh ignition/rendering/PixelFormat.hh
◆ SegmentationType
strong |
◆ ShaderType
| enum ShaderType |
ShaderType.hh ignition/rendering/ShaderType.hh
◆ TextHorizontalAlign
strong |
| Enumerator | |
| LEFT | Left alignment. |
| CENTER | Center alignment. |
| RIGHT | Right alignment. |
◆ TextVerticalAlign
strong |
| Enumerator | |
| BOTTOM | Align bottom. |
| CENTER | Align center. |
| TOP | Align top. |
◆ TransformAxis
| enum TransformAxis |
◆ TransformMode
| enum TransformMode |
◆ TransformSpace
| enum TransformSpace |
Function Documentation
◆ engine() [1/2]
| RenderEngine* ignition::rendering::engine | ( | const std::string & | _name, |
| const std::map< std::string, std::string > & | _params = {}, |
| const std::string & | _path = "" |
[in] _name Name of the desired render-engine [in] _params Parameters to be passed to the render engine. [in] _path Another search path for rendering engine plugin.
- Returns
- The specified render-engine
◆ engine() [2/2]
| RenderEngine* ignition::rendering::engine | ( | const unsigned int | _index, |
[in] _index Index of the desired render-engine [in] _params Parameters to be passed to the render engine. [in] _path Another search path for rendering engine plugin.
- Returns
◆ engineCount()
| unsigned int ignition::rendering::engineCount | ( | ) |
- Returns
- The number of available render-engines
◆ fini()
| bool ignition::rendering::fini | ( | ) |
- Returns
- True if successful
◆ hasEngine()
| bool ignition::rendering::hasEngine | ( | const std::string & | _name | ) |
- Returns
- True if a render-engine is registered under the given name
◆ init()
| bool ignition::rendering::init | ( | ) |
- Returns
◆ isEngineLoaded()
| bool ignition::rendering::isEngineLoaded | ( | const std::string & | _name | ) |
- Returns
- True if a render-engine is loaded under the given name
◆ load()
| bool ignition::rendering::load | ( | ) |
- Returns
◆ loadedEngines()
| std::vector<std::string> ignition::rendering::loadedEngines | ( | ) |
- Returns
- All the engines currently loaded.
◆ projectionToCameraIntrinsic()
| ignition::math::Matrix3d ignition::rendering::projectionToCameraIntrinsic | ( | const ignition::math::Matrix4d & | _projectionMatrix, |
| double | _width, | ||
| double | _height | ||
[in] _projectionMatrix Camera's projection matrix. [in] _width Camera's image width. [in] _height Camera's image height.
- Returns
- Camera's intrinsic matrix.
◆ registerEngine()
| void ignition::rendering::registerEngine | ( | const std::string & | _name, |
| RenderEngine * | _engine | ||
[in] _name Name the render-engine will be registered under [in] _engine Render-engine to be registered
◆ sceneFromFirstRenderEngine()
| ScenePtr ignition::rendering::sceneFromFirstRenderEngine | ( | ) |
It's not recommended to call this function when there's more than one engine or scene.
- Returns
- Pointer to a scene that was found, null if no scene is loaded.
◆ screenScalingFactor()
| float ignition::rendering::screenScalingFactor | ( | ) |
- Returns
- The screen scaling factor.
◆ screenToPlane()
| math::Vector3d ignition::rendering::screenToPlane | ( | const math::Vector2i & | _screenPos, |
| const CameraPtr & | _camera, | ||
| const RayQueryPtr & | _rayQuery, | ||
| const float | _offset = 0.0 |
[in] _screenPos 2D coordinates on the screen, in pixels. [in] _camera User camera [in] _rayQuery Ray query for mouse clicks [in] _offset Offset along the plane normal
- Returns
- 3D coordinates of a point in the 3D scene.
◆ screenToScene() [1/2]
| math::Vector3d ignition::rendering::screenToScene | ( | const math::Vector2i & | _screenPos, |
| float | _maxDistance = 10.0 |
[in] _screenPos 2D coordinates on the screen, in pixels. [in] _camera User camera [in] _rayQuery Ray query for mouse clicks [in] _maxDistance maximum distance to check the collision
- Returns
◆ screenToScene() [2/2]
| RayQueryResult & | _rayResult, | ||
[in] _screenPos 2D coordinates on the screen, in pixels. [in] _camera User camera [in] _rayQuery Ray query for mouse clicks [in,out] _rayResult Ray query result [in] _maxDistance maximum distance to check the collision
- Returns
◆ setPluginPaths()
| void ignition::rendering::setPluginPaths | ( | const std::list< std::string > & | _paths | ) |
[in] _paths The list of the plugin paths
◆ transformAxisAlignedBox()
| ignition::math::AxisAlignedBox ignition::rendering::transformAxisAlignedBox | ( | const ignition::math::AxisAlignedBox & | _box, |
| const ignition::math::Pose3d & | _pose | ||
[in] _box The bounding box. [in] _pose Pose used to transform the bounding box.
- Returns
- Vertices of the transformed bounding box in world coordinates.
◆ unloadEngine()
| bool ignition::rendering::unloadEngine | ( | const std::string & | _name | ) |
- Returns
- True if the engine is unloaded
◆ unregisterEngine() [1/3]
| void ignition::rendering::unregisterEngine | ( | const std::string & | _name | ) |
[in] _name Name of the render-engine to unregister
◆ unregisterEngine() [2/3]
| void ignition::rendering::unregisterEngine | ( | const unsigned int | _index | ) |
[in] _index Index of the render-engine to unregister
◆ unregisterEngine() [3/3]
| void ignition::rendering::unregisterEngine | ( | RenderEngine * | _engine | ) |
[in] _engine Render-engine to unregister
Variable Documentation
◆ depth_fragment_shader_file
| const std::string depth_fragment_shader_file |
◆ depth_vertex_shader_file
| const std::string depth_vertex_shader_file |
◆ kDefaultPbr
static |
Referenced by BaseMaterial< T >::CopyFrom(), and BaseMaterial< T >::Reset().
