Ogre2.x implementation of the render target class. More...
#include <Ogre2RenderTarget.hh>
virtual ~Ogre2RenderTarget ()
 Get the anti-aliasing level. More...
virtual MaterialPtr BackgroundMaterial () const
 Get the background material of this camera. More...
 Get a pointer to the internal ogre camera. More...
 Copy the render target buffer data to an image. More...
virtual void Destroy () override=0
 Destroy the render target. More...
unsigned int GLIdImpl () const
virtual bool IsRenderWindow () const
 Returns true if this is a render window. More...
virtual void Render ()
 Main render call. More...
virtual Ogre::TextureGpu * RenderTarget () const =0
 Get a pointer to the ogre render target containing the results of the render. More...
 set the anti-aliasing level More...
 Set the background color of the render target. More...
virtual void SetBackgroundMaterial (MaterialPtr _material)
 Set the background material of this camera. More...
 Set the ogre camera to use for this render target. More...
void SetShadowsNodeDefDirty ()
 Set visibility mask for the viewport associated with this render target. More...
virtual uint32_t VisibilityMask () const
 Get visibility mask for the viewport associated with this render target. More...
- Public Member Functions inherited from BaseRenderTarget< Ogre2Object >
 BaseRenderTarget ()
virtual ~BaseRenderTarget ()
virtual ~RenderTarget ()
static void UpdateRenderPassChain (Ogre::CompositorWorkspace *_workspace, const std::string &_workspaceDefName, const std::string &_baseNode, const std::string &_finalNode, const std::vector< RenderPassPtr > &_renderPasses, bool _recreateNodes, Ogre::TextureGpu *(*_ogreTextures)[2], bool _isRenderWindow)
 Update the render pass chain. More...
virtual void BuildCompositor ()
 Build the compositor. More...
void BuildTargetImpl ()
 Build the render texture. More...
virtual void DestroyCompositor ()
 Destroy the compositor. More...
void DestroyTargetImpl ()
 Destroy the render texture. More...
virtual void RebuildCompositor ()
 Rebuild the compositor. More...
 Implementation of the Rebuild function. More...
void RebuildMaterial ()
virtual void RebuildTarget ()=0
 Rebuild the render target. More...
Ogre::TextureGpu * RenderTargetImpl () const
 Get a pointer to the ogre render target containing the results of the render (implemented separately to avoid breaking ABI of the pure virtual function) More...
uint8_t TargetFSAA () const
 Returns the FSAA to use based on supported specs by HW and value specified in Ogre2RenderTarget::AntiAliasing. More...
 Update the background color. More...
virtual void UpdateBackgroundMaterial ()
 Update the background material. More...
- Protected Member Functions inherited from BaseRenderTarget< Ogre2Object >
virtual void Rebuild ()
virtual void Init ()
unsigned int antiAliasing = 4
 Anti-aliasing level. More...
MaterialPtr backgroundMaterial
 Background material of the render target. More...
bool backgroundMaterialDirty = false
 Flag to indicate if the render target background material has changed. More...
bool colorDirty = true
 Flag to indicate if the render target color has changed. More...
Ogre2RenderTargetMaterialPtr materialApplicator
 Stores the background color of the render target. More...
 Pointer to the internal ogre camera. More...
Ogre::CompositorWorkspace * ogreCompositorWorkspace = nullptr
 Ogre's compositor workspace - the main interface to render into a render target or render texture. More...
std::string ogreCompositorWorkspaceDefName
 Ogre's compositor workspace definition name. More...
uint32_t visibilityMask = IGN_VISIBILITY_ALL
 visibility mask associated with this render target More...
- Protected Attributes inherited from BaseRenderTarget< Ogre2Object >
PixelFormat format
unsigned int height
bool renderPassDirty
bool targetDirty
unsigned int width
◆ Ogre2RenderTarget()
Ogre2RenderTarget ( )
◆ ~Ogre2RenderTarget()
virtual ~Ogre2RenderTarget ( )
◆ AntiAliasing()
◆ BackgroundColor()
Reimplemented from BaseRenderTarget< Ogre2Object >.
◆ BackgroundMaterial()
virtual MaterialPtr BackgroundMaterial ( ) const
background material
◆ BuildCompositor()
virtual void BuildCompositor ( )
◆ BuildTargetImpl()
void BuildTargetImpl ( )
◆ Camera()
virtual Ogre::Camera* Camera ( ) const
Pointer to ogre camera
◆ Copy()
[in]_imageImage to copy the data to
Implements RenderTarget.
overridepure virtual
Implemented in Ogre2RenderWindow, and Ogre2RenderTexture.
◆ DestroyCompositor()
virtual void DestroyCompositor ( )
◆ DestroyTargetImpl()
void DestroyTargetImpl ( )
◆ GLIdImpl()
unsigned int GLIdImpl ( ) const
◆ IsRenderWindow()
virtual bool IsRenderWindow ( ) const
True if this render target is a render window
Reimplemented in Ogre2RenderWindow.
◆ PostRender()
virtual void PostRender ( )
Reimplemented in Ogre2RenderTexture.
◆ RebuildCompositor()
virtual void RebuildCompositor ( )
◆ RebuildImpl()
virtual void RebuildImpl ( )
Implements BaseRenderTarget< Ogre2Object >.
◆ RebuildMaterial()
void RebuildMaterial ( )
Ogre2RenderTarget::RebuildImpl()
BaseRenderTarget::Rebuild()
◆ RebuildTarget()
protectedpure virtual
◆ Render()
virtual void Render ( )
Main render call.
◆ RenderTarget()
virtual Ogre::TextureGpu* RenderTarget ( ) const
◆ RenderTargetImpl()
Ogre::TextureGpu* RenderTargetImpl ( ) const
◆ SetAntiAliasing()
virtual void SetAntiAliasing ( unsigned int  _aa)
[in]_aaAnti-aliasing level
◆ SetBackgroundColor()
virtual void SetBackgroundColor ( math::Color  _color)
[in]_colorColor to set the background to
◆ SetBackgroundMaterial()
virtual void SetBackgroundMaterial ( MaterialPtr  _material)
[in]_materialMaterial to set the background to
◆ SetCamera()
virtual void SetCamera ( Ogre::Camera *  _camera)
[in]_cameraPointer to ogre camera
◆ SetMaterial()
void SetMaterial ( MaterialPtr  _material)
[in]_materialThe material to render
◆ SetShadowsNodeDefDirty()
void SetShadowsNodeDefDirty ( )
Camera::SetShadowsNodeDefDirty
◆ SetVisibilityMask()
[in]_maskVisibility mask
◆ TargetFSAA()
uint8_t TargetFSAA ( ) const
Value in range [1; 256). 1 means no antialiasing.
◆ UpdateBackgroundColor()
virtual void UpdateBackgroundColor ( )
◆ UpdateBackgroundMaterial()
virtual void UpdateBackgroundMaterial ( )
◆ UpdateRenderPassChain() [1/2]
virtual void UpdateRenderPassChain ( )
◆ UpdateRenderPassChain() [2/2]
static void UpdateRenderPassChain ( Ogre::CompositorWorkspace *  _workspace,
const std::string &  _workspaceDefName,
const std::string &  _baseNode,
const std::string &  _finalNode,
const std::vector< RenderPassPtr > &  _renderPasses,
Ogre::TextureGpu *(*)  _ogreTextures[2],
static
◆ VisibilityMask()
virtual uint32_t VisibilityMask ( ) const
Visibility mask
◆ antiAliasing
◆ backgroundMaterial
◆ backgroundMaterialDirty
◆ colorDirty
◆ material
◆ materialApplicator
◆ ogreBackgroundColor
◆ ogreCamera
◆ ogreCompositorWorkspace
Ogre::CompositorWorkspace* ogreCompositorWorkspace = nullptr
◆ ogreCompositorWorkspaceDefName
◆ visibilityMask
