gz/rendering/ogre2/Ogre2RenderTarget.hh
Definition: gz/rendering/base/BaseRenderTarget.hh:38
Definition: gz/rendering/base/BaseRenderTarget.hh:101
Definition: gz/rendering/base/BaseRenderTarget.hh:114
Definition: gz/rendering/Image.hh:40
Ogre2.x implementation of the render target class.
Definition: gz/rendering/ogre2/Ogre2RenderTarget.hh:58
virtual void SetVisibilityMask(uint32_t _mask)
Set visibility mask for the viewport associated with this render target.
virtual unsigned int AntiAliasing() const
Get the anti-aliasing level.
virtual void Copy(Image &_image) const override
Copy the render target buffer data to an image.
virtual void SetCamera(Ogre::Camera *_camera)
Set the ogre camera to use for this render target.
MaterialPtr backgroundMaterial
Background material of the render target.
Definition: gz/rendering/ogre2/Ogre2RenderTarget.hh:218
void RebuildMaterial()
Re-initializes render target material to apply a material to everything in the scene....
virtual void UpdateRenderPassChain()
Update the render pass chain.
virtual void SetBackgroundColor(math::Color _color)
Set the background color of the render target.
uint8_t TargetFSAA() const
Returns the FSAA to use based on supported specs by HW and value specified in Ogre2RenderTarget::Anti...
Ogre::ColourValue ogreBackgroundColor
Stores the background color of the render target.
Definition: gz/rendering/ogre2/Ogre2RenderTarget.hh:215
virtual Ogre::TextureGpu * RenderTarget() const =0
Get a pointer to the ogre render target containing the results of the render.
virtual void PostRender() override
virtual void SetBackgroundMaterial(MaterialPtr _material)
Set the background material of this camera.
virtual void RebuildCompositor()
Rebuild the compositor.
virtual bool IsRenderWindow() const
Returns true if this is a render window.
static void UpdateRenderPassChain(Ogre::CompositorWorkspace *_workspace, const std::string &_workspaceDefName, const std::string &_baseNode, const std::string &_finalNode, const std::vector< RenderPassPtr > &_renderPasses, bool _recreateNodes, Ogre::TextureGpu *(*_ogreTextures)[2], bool _isRenderWindow)
virtual void DestroyCompositor()
Destroy the compositor.
void BuildTargetImpl()
Build the render texture.
void SetMaterial(MaterialPtr _material)
Set a material to render on every object. This method is used for special cases like the render targe...
virtual void RebuildTarget()=0
Rebuild the render target.
Ogre::TextureGpu * RenderTargetImpl() const
Get a pointer to the ogre render target containing the results of the render (implemented separately ...
virtual void BuildCompositor()
Build the compositor.
virtual MaterialPtr BackgroundMaterial() const
Get the background material of this camera.
virtual uint32_t VisibilityMask() const
Get visibility mask for the viewport associated with this render target.
virtual void SetAntiAliasing(unsigned int _aa)
set the anti-aliasing level
void DestroyTargetImpl()
Destroy the render texture.
virtual void Destroy() override=0
Destroy the render target.
void SetShadowsNodeDefDirty()
std::string ogreCompositorWorkspaceDefName
Ogre's compositor workspace definition name.
Definition: gz/rendering/ogre2/Ogre2RenderTarget.hh:212
virtual void UpdateBackgroundColor()
Update the background color.
Ogre2RenderTargetMaterialPtr materialApplicator
Helper class that applies the material to the render target.
Definition: gz/rendering/ogre2/Ogre2RenderTarget.hh:224
unsigned int GLIdImpl() const
virtual void UpdateBackgroundMaterial()
Update the background material.
virtual math::Color BackgroundColor() const override
virtual void RebuildImpl() override
Implementation of the Rebuild function.
virtual Ogre::Camera * Camera() const
Get a pointer to the internal ogre camera.
a material used by for the render target
Definition: gz/rendering/ogre2/Ogre2RenderTarget.hh:221
Ogre2.x implementation of the render texture class.
Definition: gz/rendering/ogre2/Ogre2RenderTarget.hh:246
virtual void BuildTarget()
virtual void RebuildTarget() override
virtual void DestroyTarget()
virtual ~Ogre2RenderTexture()
virtual unsigned int GLId() const override
Returns the OpenGL texture Id. A valid Id is returned only.
virtual Ogre::TextureGpu * RenderTarget() const override
Ogre2.x implementation of the render window class.
Definition: gz/rendering/ogre2/Ogre2RenderTarget.hh:286
Build the render window.
virtual bool IsRenderWindow() const override
Ogre2.x implementation of the scene class.
Definition: gz/rendering/ogre2/Ogre2Scene.hh:59
Non owning, writable view of a caller owned pixel buffer.
Definition: gz/rendering/PixelBuffer.hh:49
#define IGN_VISIBILITY_ALL
Render everything visibility mask.
Definition: gz/rendering/RenderTypes.hh:26
