Posable camera used for rendering the scene graph. More...
#include <ignition/rendering/Camera.hh>
Public Types | |
| virtual | ~Camera () |
| Deconstructor. More... | |
| Renders a new frame and writes the results to the given image. This is a convenience function for single-camera scenes. It wraps the pre-render, render, post-render, and get-image calls into a single function. This should be used in applications with multiple cameras or multiple consumers of a single camera's images. More... | |
| Writes the last rendered image into a caller owned buffer, for example a message payload, without an intermediate copy. Like Copy, this can be called any number of times after PostRender. The buffer must match the camera's image size and be at least _buffer.MemorySize() bytes. Nothing keeps a pointer to the buffer once this call returns. More... | |
| Renders a new frame. This is a convenience function for single-camera scenes. It wraps the pre-render, render, and post-render into a single function. This should be used in applications with multiple cameras or multiple consumers of a single camera's images. More... | |
| virtual | ~Sensor () |
| Sensor. More... | |
| virtual | ~Node () |
| Destructor. More... | |
Poseable depth camera used for rendering the scene graph. This camera is designed to produced depth data, instead of a 2D image.
Member Typedef Documentation
◆ NewFrameListener
| typedef std::function<void(const void*, unsigned int, unsigned int, unsigned int, const std::string&)> NewFrameListener |
◆ ~Camera()
inlinevirtual |
Deconstructor.
◆ AddRenderPass()
pure virtual |
[in] _pass New render pass to add
Implemented in Ogre2DepthCamera, BaseCamera< T >, BaseCamera< Ogre2Sensor >, and BaseCamera< OgreSensor >.
◆ AntiAliasing()
pure virtual |
- Returns
- The level of anti-aliasing used during rendering
Implemented in Ogre2Camera, OgreCamera, BaseCamera< T >, BaseCamera< Ogre2Sensor >, and BaseCamera< OgreSensor >.
◆ AspectRatio()
pure virtual |
- Returns
- The camera's aspect ratio
◆ Capture()
pure virtual |
[out] _image Output image buffer
Implemented in BaseCamera< T >, BaseCamera< Ogre2Sensor >, and BaseCamera< OgreSensor >.
◆ ConnectNewImageFrame()
pure virtual |
[in] _listener New camera listener callback
◆ Copy()
pure virtual |
◆ CopyTo()
| bool CopyTo | ( | const PixelBuffer & | _buffer | ) | const |
[in] _buffer Where to write the frame
- Returns
- True if the frame was written. False, with an error logged and the buffer untouched, if the buffer is invalid or does not match the camera's image size.
◆ CreateImage()
pure virtual |
- Returns
- A newly allocated Image for storing this cameras images
◆ CreateRenderWindow()
pure virtual |
- Returns
- A pointer to the render window.
◆ FarClipPlane()
pure virtual |
- Returns
- Far clipping plane distance
Implemented in Ogre2DepthCamera, OgreDepthCamera, BaseCamera< T >, BaseCamera< Ogre2Sensor >, and BaseCamera< OgreSensor >.
◆ FollowOffset()
pure virtual |
- Returns
- Offset of camera from target.
◆ FollowPGain()
pure virtual |
- Returns
- P gain for camera following
◆ FollowTarget()
pure virtual |
- Returns
- Target node being tracked.
◆ HFOV()
pure virtual |
- Returns
- Angle containing the camera's horizontal field-of-view
◆ ImageFormat()
pure virtual |
- Returns
- The image pixel format
◆ ImageHeight()
pure virtual |
- Returns
- The image height in pixels
◆ ImageMemorySize()
pure virtual |
- Returns
- The image memory size in bytes
◆ ImageWidth()
pure virtual |
- Returns
- The image width in pixels
◆ NearClipPlane()
pure virtual |
- Returns
- Near clipping plane distance
◆ PostRender()
pure virtual |
Implemented in Ogre2ThermalCamera, Ogre2SegmentationCamera, Ogre2GpuRays, Ogre2DepthCamera, Ogre2BoundingBoxCamera, OgreThermalCamera, OgreGpuRays, OgreDepthCamera, BaseCamera< T >, BaseCamera< Ogre2Sensor >, and BaseCamera< OgreSensor >.
◆ Project()
pure virtual |
[in] _pt Point in 3d world space
- Returns
- Point in 2d screen space
◆ ProjectionMatrix()
pure virtual |
- Returns
- Camera projection matrix
◆ ProjectionType()
pure virtual |
- Returns
- Camera projection type
◆ RemoveRenderPass()
pure virtual |
[in] _pass render pass to remove
◆ Render()
pure virtual |
Implemented in Ogre2ThermalCamera, Ogre2SegmentationCamera, Ogre2DepthCamera, Ogre2Camera, Ogre2BoundingBoxCamera, OgreThermalCamera, OgreDepthCamera, and OgreCamera.
◆ RenderPassByIndex()
pure virtual |
- Returns
- Render pass at the specified index
◆ RenderPassCount()
pure virtual |
- Returns
- Number of render passes applied
◆ RenderTextureGLId()
pure virtual |
- Returns
- Texture Id of type GLuint.
◆ SaveFrame()
pure virtual |
[in] _name Name of the output file
◆ SetAntiAliasing()
pure virtual |
[in] _aa Level of anti-aliasing used during rendering
◆ SetAspectRatio()
pure virtual |
- Returns
◆ SetFarClipPlane()
pure virtual |
[in] _far Far clipping plane distance
Implemented in Ogre2DepthCamera, Ogre2Camera, OgreDepthCamera, OgreCamera, BaseCamera< T >, BaseCamera< Ogre2Sensor >, and BaseCamera< OgreSensor >.
◆ SetFollowOffset()
pure virtual |
[in] _offset Offset distance from target node.
◆ SetFollowPGain()
pure virtual |
[in] _pGain P gain for camera following
◆ SetFollowTarget()
pure virtual |
[in] _target Target node to follow [in] _offset Tether the camera at an offset distance from the target node. [in] _worldFrame True to follow the target node at a distance that's fixed in world frame. Default is false which means the camera follows at fixed distance in target node's local frame.
◆ SetHFOV()
pure virtual |
[in] _hfov Desired horizontal field-of-view
◆ SetImageFormat()
pure virtual |
[in] _format New image pixel format
◆ SetImageHeight()
pure virtual |
[in] _height New image height in pixels
◆ SetImageWidth()
pure virtual |
[in] _width New image width in pixels
◆ SetMaterial()
pure virtual |
[in] _material a material instance
◆ SetNearClipPlane()
pure virtual |
[in] _near Near clipping plane distance
◆ SetProjectionMatrix()
pure virtual |
[in] _matrix Camera projection matrix
◆ SetProjectionType()
pure virtual |
[in] _type Camera projection type
- See also
- SetProjectionMatrix
◆ SetShadowsDirty()
pure virtual |
Implemented in Ogre2DepthCamera, Ogre2Camera, BaseCamera< T >, BaseCamera< Ogre2Sensor >, and BaseCamera< OgreSensor >.
◆ SetTrackOffset()
pure virtual |
[in] _offset Point offset to track
◆ SetTrackPGain()
pure virtual |
[in] _pGain P gain for camera tracking
◆ SetTrackTarget()
pure virtual |
[in] _target Target node to track [in] _offset Track a point that is at an offset relative to target. [in] _worldFrame If true, the offset point to track will be treated in world frame and its position relative to the target node remains fixed regardless of the target node's rotation. Default is false, which means the camera tracks the point in target node's local frame.
◆ TrackOffset()
pure virtual |
- Returns
- Point offset from target.
◆ TrackPGain()
pure virtual |
- Returns
- P gain for camera tracking
◆ TrackTarget()
pure virtual |
- Returns
◆ Update()
pure virtual |
◆ ViewMatrix()
pure virtual |
- Returns
- Camera view matrix
◆ VisualAt()
pure virtual |
Implemented in OgreCamera, BaseCamera< T >, BaseCamera< Ogre2Sensor >, and BaseCamera< OgreSensor >.
