PixelBuffer Class Reference
Non owning, writable view of a caller owned pixel buffer. More...
#include <ignition/rendering/PixelBuffer.hh>
 PixelBuffer (const PixelBuffer &_other)=default
 Copy constructor. Copies of a view share the same buffer. More...
 PixelBuffer (Image &_image)
 View the storage of an existing image. The view is only valid while the image, or a copy of it, is alive. More...
 PixelBuffer (unsigned int _width, unsigned int _height, PixelFormat _format, void *_data, std::size_t _size)
 Describe a caller owned buffer. More...
 ~PixelBuffer ()=default
 Destructor. Does not free the buffer. More...
unsigned char * Data () const
 Get a pointer to the first byte of the buffer. The pointer is writable even through a const view: this is a span, not a read only view. More...
PixelFormat Format () const
 Get the pixel format. More...
unsigned int Height () const
 Get the height in pixels. More...
std::size_t MemorySize () const
 Get the number of bytes Width x Height pixels of Format need. More...
PixelBuffer & operator= (const PixelBuffer &)=delete
 Views cannot be rebound. More...
PixelBuffer & operator= (PixelBuffer &&)=delete
std::size_t Size () const
 Get the size of the buffer in bytes, as given by the caller. More...
bool Valid () const
 Check that the buffer can hold a frame: the pointer is not null and Size() is at least MemorySize(). More...
unsigned int Width () const
 Get the width in pixels. More...
A PixelBuffer describes where a frame should be written: dimensions, pixel format, the start of a contiguous row major buffer and its size in bytes. It owns nothing and never frees the memory. Build one right before handing it to Camera::CopyTo and let it die when the call returns; nothing in the library keeps a pointer to the memory after that.
Every field is immutable and assignment is deleted, so code that receives a PixelBuffer can write through it but cannot point it somewhere else. That is what lets the render engines write straight into caller memory without being able to drop it by mistake.
◆ PixelBuffer() [1/3]
PixelBuffer ( unsigned int  _width,
void *  _data,
std::size_t  _size
[in]_widthWidth in pixels
[in]_heightHeight in pixels
[in]_formatPixel format of the buffer
[in]_dataStart of the buffer. Not owned.
[in]_sizeSize of the buffer in bytes
◆ PixelBuffer() [2/3]
PixelBuffer ( Image &  _image)
[in]_imageImage whose buffer is viewed
◆ PixelBuffer() [3/3]
PixelBuffer ( const PixelBuffer &  _other)
default
[in]_otherView to copy
◆ ~PixelBuffer()
~PixelBuffer ( )
default
◆ Data()
unsigned char* Data ( ) const
Pointer to the buffer
◆ Format()
PixelFormat Format ( ) const
Pixel format
◆ Height()
unsigned int Height ( ) const
Height in pixels
◆ MemorySize()
std::size_t MemorySize ( ) const
Required size in bytes
◆ operator=() [1/2]
PixelBuffer& operator= ( const PixelBuffer &  )
delete
◆ operator=() [2/2]
PixelBuffer& operator= ( PixelBuffer &&  )
delete
◆ Size()
std::size_t Size ( ) const
Buffer size in bytes
◆ Valid()
bool Valid ( ) const
True if a frame can be written into the buffer
◆ Width()
unsigned int Width ( ) const
Width in pixels
