Sensor Class Referenceabstract
#include <ignition/rendering/Sensor.hh>
 Sensor. More...
 Set visibility mask. More...
 Get visibility mask. More...
◆ ~Sensor()
virtual ~Sensor ( )
inlinevirtual
◆ SetVisibilityMask()
[in]_maskVisibility mask
Implemented in Ogre2Camera, OgreCamera, BaseSensor< T >, BaseSensor< Ogre2Node >, and BaseSensor< OgreNode >.
◆ VisibilityMask()
virtual uint32_t VisibilityMask ( ) const
visibility mask
Implemented in BaseSensor< T >, BaseSensor< Ogre2Node >, and BaseSensor< OgreNode >.
