#include <OgreCamera.hh>
virtual ~OgreCamera ()
virtual math::Color BackgroundColor () const
Ogre::Camera * Camera () const
 Get underlying Ogre camera. More...
double FarClip () const
 Get the far clip distance. More...
double NearClip () const
 Get the near clip distance. More...
virtual void SetBackgroundColor (const math::Color &_color)
void SetVFOV (double cameraVFOV) const
 Set visibility mask. More...
virtual ~BaseCamera ()
virtual ~Camera ()
 Sensor. More...
virtual ~OgreSensor ()
virtual ~BaseSensor ()
 Get visibility mask. More...
virtual ~OgreNode ()
 OgreCamera ()
void DestroyRenderTexture ()
 Destroy render texture created by CreateRenderTexture() Note: It's not virtual. More...
virtual void SetSelectionBuffer ()
 BaseCamera ()
 OgreSensor ()
 BaseSensor ()
 OgreNode ()
math::Color backgroundColor
OgreRenderTargetPtr renderTexture
OgreSelectionBuffer * selectionBuffer = nullptr
unsigned int antiAliasing
 Anti-aliasing. More...
double aspect
 Aspect ratio. More...
double farClip
NodePtr followNode
math::Vector3d followOffset
double followPGain
bool followWorldFrame
math::Angle hfov
ImagePtr imageBuffer
double nearClip
NodePtr trackNode
math::Vector3d trackOffset
double trackPGain
bool trackWorldFrame
uint32_t visibilityMask
OgreNodeStorePtr children
OgreNodePtr parent
◆ OgreCamera()
OgreCamera ( )
◆ ~OgreCamera()
virtual ~OgreCamera ( )
◆ AntiAliasing()
◆ AspectRatio()
The camera's aspect ratio
◆ BackgroundColor()
◆ Camera()
Ogre::Camera* Camera ( ) const
◆ CreateRenderTexture()
◆ CreateRenderWindow()
Reimplemented from OgreNode.
◆ DestroyRenderTexture()
void DestroyRenderTexture ( )
◆ FarClip()
double FarClip ( ) const
Far clip distance
◆ HFOV()
virtual math::Angle HFOV ( ) const
◆ NearClip()
double NearClip ( ) const
Near clip distance
◆ ProjectionMatrix()
Camera projection matrix
◆ Render()
virtual void Render ( )
Implements Camera.
◆ RenderTarget()
◆ RenderTextureGLId()
Texture Id of type GLuint.
◆ SetAntiAliasing()
◆ SetAspectRatio()
image_height /
image_width
◆ SetBackgroundColor()
◆ SetFarClipPlane()
◆ SetHFOV()
◆ SetMaterial()
◆ SetNearClipPlane()
◆ SetProjectionMatrix()
◆ SetProjectionType()
virtual void SetProjectionType ( CameraProjectionType  _type)
SetProjectionMatrix
◆ SetSelectionBuffer()
virtual void SetSelectionBuffer ( )
◆ SetVFOV()
void SetVFOV ( double  cameraVFOV) const
◆ SetVisibilityMask()
[in]_maskVisibility mask
Implements Sensor.
◆ ViewMatrix()
Camera view matrix
◆ VisualAt()
virtual VisualPtr VisualAt ( const gz::math::Vector2i &  _mousePos)
◆ backgroundColor
◆ ogreCamera
◆ renderTexture
◆ selectionBuffer
OgreSelectionBuffer* selectionBuffer = nullptr
