RenderTarget Class Referenceabstract
#include <ignition/rendering/RenderTarget.hh>
virtual ~RenderTarget ()
◆ ~RenderTarget()
virtual ~RenderTarget ( )
inlinevirtual
◆ AddRenderPass()
Implemented in BaseRenderTarget< T >, BaseRenderTarget< Ogre2Object >, and BaseRenderTarget< OgreObject >.
Referenced by BaseCamera< T >::AddRenderPass().
◆ BackgroundColor()
Implemented in Ogre2RenderTarget, OgreRenderTarget, BaseRenderTarget< T >, BaseRenderTarget< Ogre2Object >, and BaseRenderTarget< OgreObject >.
◆ Copy()
Implemented in Ogre2RenderTarget, and OgreRenderTarget.
Referenced by BaseCamera< T >::Copy().
◆ Format()
virtual PixelFormat Format ( ) const
Render target format
Referenced by BaseCamera< T >::ImageFormat().
◆ Height()
virtual unsigned int Height ( ) const
Referenced by BaseCamera< T >::ImageHeight().
◆ RemoveRenderPass()
Referenced by BaseCamera< T >::RemoveRenderPass().
◆ RenderPassByIndex()
Referenced by BaseCamera< T >::RenderPassByIndex().
◆ RenderPassCount()
Referenced by BaseCamera< T >::RenderPassCount().
◆ SetFormat()
virtual void SetFormat ( PixelFormat  _format)
[in]_formatNew target format
Referenced by BaseCamera< T >::SetImageFormat().
◆ SetHeight()
virtual void SetHeight ( const unsigned int  _height)
Referenced by BaseCamera< T >::SetImageHeight().
◆ SetWidth()
virtual void SetWidth ( const unsigned int  _width)
Referenced by BaseCamera< T >::SetImageWidth().
◆ Width()
virtual unsigned int Width ( ) const
Referenced by BaseCamera< T >::ImageWidth().
