BaseCamera< T > Class Template Referenceabstract
#include <BaseCamera.hh>
virtual ~BaseCamera ()
virtual ~Camera ()
virtual void Render ()=0
 Sensor. More...
 Set visibility mask. More...
 Get visibility mask. More...
 BaseCamera ()
 Anti-aliasing. More...
double aspect = 1.3333333
 Aspect ratio. More...
double farClip = 1000.0
NodePtr followNode
math::Vector3d followOffset
double followPGain = 1.0
bool followWorldFrame = false
math::Angle hfov
ImagePtr imageBuffer
double nearClip = 0.01
NodePtr trackNode
math::Vector3d trackOffset
double trackPGain = 1.0
bool trackWorldFrame = false
◆ BaseCamera()
BaseCamera
◆ ~BaseCamera()
~BaseCamera
◆ AddRenderPass()
Implements Camera.
Reimplemented in Ogre2DepthCamera.
References RenderTarget::AddRenderPass().
◆ AntiAliasing()
unsigned int AntiAliasing ( ) const
Implements Camera.
Reimplemented in Ogre2Camera, and OgreCamera.
◆ AspectRatio()
double AspectRatio ( ) const
The camera's aspect ratio
Implements Camera.
◆ Capture()
void Capture ( Image &  _image)
Implements Camera.
◆ ConnectNewImageFrame()
common::ConnectionPtr ConnectNewImageFrame ( Camera::NewFrameListener  _listener)
[in]_listenerNew camera listener callback
Implements Camera.
◆ Copy()
void Copy ( Image &  _image) const
Implements Camera.
References RenderTarget::Copy().
◆ CreateImage()
Image CreateImage ( ) const
A newly allocated Image for storing this cameras images
Implements Camera.
◆ CreateImageBuffer()
◆ CreateRenderWindow()
RenderWindowPtr CreateRenderWindow ( )
Implements Camera.
References std::endl(), Scene::Engine(), ignerr, and RenderEngine::Name().
◆ FarClipPlane()
double FarClipPlane ( ) const
Implements Camera.
Reimplemented in Ogre2DepthCamera, and OgreDepthCamera.
◆ FollowOffset()
math::Vector3d FollowOffset ( ) const
Offset of camera from target.
Implements Camera.
◆ FollowPGain()
double FollowPGain ( ) const
P gain for camera following
Implements Camera.
◆ FollowTarget()
NodePtr FollowTarget ( ) const
Target node being tracked.
Implements Camera.
◆ HFOV()
math::Angle HFOV ( ) const
Implements Camera.
◆ ImageFormat()
PixelFormat ImageFormat ( ) const
The image pixel format
Implements Camera.
References RenderTarget::Format().
◆ ImageHeight()
unsigned int ImageHeight ( ) const
The image height in pixels
Implements Camera.
References RenderTarget::Height().
◆ ImageMemorySize()
unsigned int ImageMemorySize ( ) const
The image memory size in bytes
Implements Camera.
References PixelUtil::MemorySize().
◆ ImageWidth()
unsigned int ImageWidth ( ) const
The image width in pixels
Implements Camera.
References RenderTarget::Width().
◆ Load()
void Load
◆ NearClipPlane()
Implements Camera.
◆ PostRender()
void PostRender ( )
Implements Camera.
Reimplemented in Ogre2ThermalCamera, Ogre2SegmentationCamera, Ogre2GpuRays, Ogre2DepthCamera, Ogre2BoundingBoxCamera, OgreThermalCamera, OgreGpuRays, and OgreDepthCamera.
References Object::PostRender().
void PreRender ( )
References ignition::math::equal(), Quaternion< class >::Identity, Matrix4< class >::LookAt(), Pose3< class >::Pos(), Object::PreRender(), Pose3< class >::Rot(), and Quaternion< class >::Slerp().
◆ Project()
math::Vector2i Project ( const math::Vector3d &  _pt) const
[in]_ptPoint in 3d world space
Point in 2d screen space
Implements Camera.
References Vector2< class >::X(), Vector3< class >::X(), Vector2< class >::Y(), Vector3< class >::Y(), and Vector3< class >::Z().
◆ ProjectionMatrix()
math::Matrix4d ProjectionMatrix ( ) const
Camera projection matrix
Implements Camera.
References std::atan(), ignition::rendering::CPT_ORTHOGRAPHIC, ignition::rendering::CPT_PERSPECTIVE, std::endl(), ignerr, and std::tan().
◆ ProjectionType()
CameraProjectionType ProjectionType ( ) const
Implements Camera.
◆ RemoveRenderPass()
Implements Camera.
References RenderTarget::RemoveRenderPass().
◆ RenderPassByIndex()
Implements Camera.
References RenderTarget::RenderPassByIndex().
◆ RenderPassCount()
Implements Camera.
References RenderTarget::RenderPassCount().
◆ RenderTarget()
◆ RenderTextureGLId()
unsigned int RenderTextureGLId ( ) const
Texture Id of type GLuint.
Implements Camera.
References std::endl(), and ignerr.
◆ Reset()
void Reset
◆ SaveFrame()
bool SaveFrame ( const std::string &  _name)
[in]_nameName of the output file
Implements Camera.
◆ SetAntiAliasing()
void SetAntiAliasing ( const unsigned int  _aa)
Implements Camera.
◆ SetAspectRatio()
void SetAspectRatio ( const double  _ratio)
image_height /
image_width
Implements Camera.
◆ SetFarClipPlane()
void SetFarClipPlane ( const double  _far)
Implements Camera.
Reimplemented in Ogre2DepthCamera, Ogre2Camera, OgreDepthCamera, and OgreCamera.
◆ SetFollowOffset()
void SetFollowOffset ( const math::Vector3d &  _offset)
[in]_offsetOffset distance from target node.
Implements Camera.
◆ SetFollowPGain()
void SetFollowPGain ( const double  _pGain)
[in]_pGainP gain for camera following
Implements Camera.
References ignition::math::clamp().
◆ SetFollowTarget()
void SetFollowTarget ( const NodePtr &  _target,
const math::Vector3d &  _offset,
[in]_targetTarget node to follow
[in]_offsetTether the camera at an offset distance from the target node.
[in]_worldFrameTrue to follow the target node at a distance that's fixed in world frame. Default is false which means the camera follows at fixed distance in target node's local frame.
Implements Camera.
◆ SetHFOV()
void SetHFOV ( const math::Angle &  _hfov)
Implements Camera.
◆ SetImageFormat()
void SetImageFormat ( PixelFormat  _format)
[in]_formatNew image pixel format
Implements Camera.
References RenderTarget::SetFormat().
◆ SetImageHeight()
void SetImageHeight ( const unsigned int  _height)
[in]_heightNew image height in pixels
Implements Camera.
References RenderTarget::SetHeight().
◆ SetImageWidth()
void SetImageWidth ( const unsigned int  _width)
[in]_widthNew image width in pixels
Implements Camera.
References RenderTarget::SetWidth().
◆ SetMaterial()
void SetMaterial ( const MaterialPtr &  _material)
Implements Camera.
◆ SetNearClipPlane()
void SetNearClipPlane ( const double  _near)
Implements Camera.
◆ SetProjectionMatrix()
void SetProjectionMatrix ( const math::Matrix4d &  _matrix)
Implements Camera.
◆ SetProjectionType()
void SetProjectionType ( CameraProjectionType  _type)
SetProjectionMatrix
Implements Camera.
◆ SetShadowsDirty()
Implements Camera.
Reimplemented in Ogre2DepthCamera, and Ogre2Camera.
◆ SetTrackOffset()
void SetTrackOffset ( const math::Vector3d &  _offset)
[in]_offsetPoint offset to track
Implements Camera.
◆ SetTrackPGain()
void SetTrackPGain ( const double  _pGain)
[in]_pGainP gain for camera tracking
Implements Camera.
◆ SetTrackTarget()
void SetTrackTarget ( const NodePtr &  _target,
[in]_targetTarget node to track
[in]_offsetTrack a point that is at an offset relative to target.
[in]_worldFrameIf true, the offset point to track will be treated in world frame and its position relative to the target node remains fixed regardless of the target node's rotation. Default is false, which means the camera tracks the point in target node's local frame.
Implements Camera.
◆ TrackOffset()
math::Vector3d TrackOffset ( ) const
Point offset from target.
Implements Camera.
◆ TrackPGain()
double TrackPGain ( ) const
Implements Camera.
◆ TrackTarget()
NodePtr TrackTarget ( ) const
Implements Camera.
void Update ( )
Implements Camera.
References Scene::PostRender(), and Scene::PreRender().
◆ ViewMatrix()
math::Matrix4d ViewMatrix ( ) const
Camera view matrix
Implements Camera.
References Matrix4< class >::SetTranslation(), and Matrix3< class >::Transpose().
◆ VisualAt()
VisualPtr VisualAt ( const gz::math::Vector2i &  _mousePos)
Implements Camera.
Reimplemented in OgreCamera.
◆ antiAliasing
Anti-aliasing.
◆ aspect
Aspect ratio.
◆ farClip
◆ followNode
NodePtr followNode
◆ followOffset
◆ followPGain
◆ followWorldFrame
◆ hfov
math::Angle hfov
◆ imageBuffer
◆ nearClip
◆ newFrameEvent
common::EventT<void(const void *, unsigned int, unsigned int, unsigned int, const std::string &)> newFrameEvent
◆ projectionMatrix
◆ projectionType
◆ trackNode
NodePtr trackNode
◆ trackOffset
◆ trackPGain
◆ trackWorldFrame
