| virtual | ~Ogre2DepthCamera () |
| | Destructor. More...
| void | AddRenderPass (const RenderPassPtr &_pass) override |
| virtual gz::common::ConnectionPtr | ConnectNewDepthFrame (std::function< void(const float *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber) override |
| | Connect a to the new depth image signal. More...
| virtual gz::common::ConnectionPtr | ConnectNewRgbPointCloud (std::function< void(const float *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber) override |
| | Connect a to the new rgb point cloud signal. More...
| virtual void | CreateDepthTexture () override |
| | Create a texture which will hold the depth data. More...
| virtual void | CreateRenderTexture () |
| | Create dummy render texture. Needed to satisfy inheritance. More...
| virtual const float * | DepthData () const override |
| | All things needed to get back z buffer for depth data. More...
| double | FarClipPlane () const override |
| | Get the far clip distance. More...
| | Initialize the camera. More...
| double | NearClipPlane () const override |
| | Get the near clip distance. More...
| | Render the camera. More...
| | Implementation of the render call. More...
| | Set the far clip distance. More...
| | Set the near clip distance. More...
| void | SetShadowsDirty () override |
| virtual | ~BaseDepthCamera () |
| virtual gz::common::ConnectionPtr | ConnectNewRGBPointCloud (std::function< void(const float *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber) |
| virtual | ~DepthCamera () |
| | Destructor. More...
| virtual gz::common::ConnectionPtr | ConnectNewRgbPointCloud (std::function< void(const float *_pointCloud, unsigned int _width, unsigned int _height, unsigned int _depth, const std::string &_format)> _subscriber)=0 |
| | Connect to the new rgb point cloud signal. More...
| virtual | ~Camera () |
| | Deconstructor. More...
| virtual | ~Sensor () |
| | Sensor. More...
| virtual | ~Node () |
| | Destructor. More...
| virtual | ~BaseCamera () |
| virtual | ~Ogre2Sensor () |
| | Destructor. More...
| virtual | ~BaseSensor () |
| virtual | ~Ogre2Node () |
| | Destructor. More...
| | Get a pointer to the underlying scene node. More...
| virtual | ~BaseNode () |
| virtual | ~Ogre2Object () |
| | Destructor. More...
| virtual | ~BaseObject () |
