gz/rendering/ogre2/Ogre2DepthCamera.hh
16 */
17
18 #ifndef GZ_RENDERING_OGRE2_OGRE2DEPTHCAMERA_HH_
19 #define GZ_RENDERING_OGRE2_OGRE2DEPTHCAMERA_HH_
20
21 #ifdef _WIN32
22  // Ensure that Winsock2.h is included before Windows.h, which can get
23  // pulled in by anybody (e.g., Boost).
24  #include <Winsock2.h>
25 #endif
26
27 #include <memory>
28 #include <string>
29
32
33 #include "gz/common/Event.hh"
34 #include "gz/common/Console.hh"
35
36 namespace Ogre
37 {
38  class Material;
39  class RenderTarget;
40  class Texture;
41  class Viewport;
42 }
43
44 namespace ignition
45 {
46  namespace rendering
47  {
48  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
49  //
50  // Forward declaration
51  class Ogre2DepthCameraPrivate;
52
54  class IGNITION_RENDERING_OGRE2_VISIBLE Ogre2DepthCamera :
55  public BaseDepthCamera<Ogre2Sensor>
56  {
58  protected: Ogre2DepthCamera();
59
61  public: virtual ~Ogre2DepthCamera();
62
64  public: virtual void Init() override;
65
66  // Documentation inherited
67  public: virtual void Destroy() override;
68
70  public: virtual void CreateRenderTexture();
71
74  public: virtual void CreateDepthTexture() override;
75
78  private: void CreateWorkspaceInstance();
79
80  // Documentation inherited
81  public: virtual void PreRender() override;
82
84  public: virtual void PostRender() override;
85
88  public: virtual const float *DepthData() const override;
89
93  public: virtual gz::common::ConnectionPtr ConnectNewDepthFrame(
94  std::function<void(const float *, unsigned int, unsigned int,
95  unsigned int, const std::string &)> _subscriber) override;
96
100  public: virtual gz::common::ConnectionPtr ConnectNewRgbPointCloud(
101  std::function<void(const float *, unsigned int, unsigned int,
102  unsigned int, const std::string &)> _subscriber) override;
103
105  public: virtual void Render() override;
106
109  public: virtual void SetFarClipPlane(const double _far) override;
110
113  public: virtual void SetNearClipPlane(const double _near) override;
114
118  public: double NearClipPlane() const override;
119
123  public: double FarClipPlane() const override;
124
125  // Documentation inherited.
126  public: void SetShadowsDirty() override;
127
128  // Documentation inherited.
129  public: void AddRenderPass(const RenderPassPtr &_pass) override;
130
133  protected: virtual RenderTargetPtr RenderTarget() const override;
134
139  protected: static double LimitFOV(const double _fov);
140
142  protected: void CreateCamera();
143
149  private: void SetShadowsNodeDefDirty();
150
152  protected: Ogre::Camera *ogreCamera;
153
157
158  private: friend class Ogre2Scene;
159  };
160  }
161  }
162 }
163 #endif
Definition: gz/rendering/base/BaseDepthCamera.hh:37
Depth camera used to render depth data into an image buffer.
Definition: gz/rendering/ogre2/Ogre2DepthCamera.hh:56
virtual const float * DepthData() const override
All things needed to get back z buffer for depth data.
Get the far clip distance.
Get a pointer to the render target.
Get the near clip distance.
Set the far clip distance.
virtual gz::common::ConnectionPtr ConnectNewDepthFrame(std::function< void(const float *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber) override
Connect a to the new depth image signal.
Render the camera.
Ogre::Camera * ogreCamera
Pointer to the ogre camera.
Definition: gz/rendering/ogre2/Ogre2DepthCamera.hh:152
Limit field of view taking care of using a valid value for an OGRE camera.
virtual gz::common::ConnectionPtr ConnectNewRgbPointCloud(std::function< void(const float *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber) override
Connect a to the new rgb point cloud signal.
void CreateCamera()
Create the camera.
Create a texture which will hold the depth data.
Initialize the camera.
Set the near clip distance.
Implementation of the render call.
Create dummy render texture. Needed to satisfy inheritance.
Ogre2.x implementation of the scene class.
Definition: gz/rendering/ogre2/Ogre2Scene.hh:59
