gz/rendering/ogre/OgreCamera.hh
17 #ifndef GZ_RENDERING_OGRE_OGRECAMERA_HH_
18 #define GZ_RENDERING_OGRE_OGRECAMERA_HH_
20 #include <string>
21
26
27 namespace Ogre
28 {
29  class Camera;
30 }
31
32 namespace ignition
33 {
34  namespace rendering
35  {
36  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
37  //
38  // forward declaration
39  class OgreSelectionBuffer;
40
41  class IGNITION_RENDERING_OGRE_VISIBLE OgreCamera :
42  public BaseCamera<OgreSensor>
43  {
44  protected: OgreCamera();
45
46  public: virtual ~OgreCamera();
47
48  // Documentation inherited.
49  public: virtual math::Angle HFOV() const override;
50
51  // Documentation inherited.
52  public: virtual void SetHFOV(const math::Angle &_hfov) override;
53
54  // Documentation inherited.
55  public: virtual double AspectRatio() const override;
56
57  // Documentation inherited.
58  public: virtual void SetAspectRatio(const double _ratio) override;
59
60  // Documentation inherited.
61  public: virtual unsigned int AntiAliasing() const override;
62
63  // Documentation inherited.
64  public: virtual void SetAntiAliasing(const unsigned int _aa) override;
65
66  // Documentation inherited.
67  public: virtual void SetFarClipPlane(const double _far) override;
68
69  // Documentation inherited.
70  public: virtual void SetNearClipPlane(const double _near) override;
71
72  public: virtual math::Color BackgroundColor() const;
73
74  public: virtual void SetBackgroundColor(const math::Color &_color);
75
76  // Documentation inherited.
77  public: virtual void Render() override;
78
79  // Documentation inherited.
80  public: virtual RenderWindowPtr CreateRenderWindow() override;
81
82  // Documentation inherited.
83  public: virtual math::Matrix4d ProjectionMatrix() const override;
84
85  // Documentation inherited.
86  public: virtual void SetProjectionMatrix(
87  const math::Matrix4d &_matrix) override;
88
89  // Documentation inherited.
90  public: virtual math::Matrix4d ViewMatrix() const override;
91
92  // Documentation inherited.
93  public: virtual void SetProjectionType(CameraProjectionType _type)
94  override;
95
96  public: void SetVFOV(double cameraVFOV) const;
97
100  public: double NearClip() const;
101
104  public: double FarClip() const;
105
106  // Documentation inherited
107  public: virtual VisualPtr VisualAt(const gz::math::Vector2i
108  &_mousePos) override;
109
110  // Documentation Inherited.
111  // \sa Camera::SetMaterial(const MaterialPtr &)
112  public: virtual void SetMaterial(
113  const MaterialPtr &_material) override;
114
115  // Documentation inherited.
116  public: virtual unsigned int RenderTextureGLId() const override;
117
118  // Documentation inherited.
119  public: virtual void Destroy() override;
120
121  // Documentation inherited.
122  public: virtual void SetVisibilityMask(uint32_t _mask) override;
123
125  public: Ogre::Camera *Camera() const;
126
127  // Documentation inherited.
128  // public: virtual uint32_t VisibilityMask() const override;
129
130  protected: virtual RenderTargetPtr RenderTarget() const override;
131
132  protected: virtual void Init() override;
133
134  protected: virtual void SetSelectionBuffer();
135
136  private: void CreateCamera();
137
138  protected: virtual void CreateRenderTexture();
139
142  protected: void DestroyRenderTexture();
143
144  protected: Ogre::Camera *ogreCamera = nullptr;
145
146  protected: OgreSelectionBuffer *selectionBuffer = nullptr;
147
149
151
152  private: friend class OgreScene;
153  private: friend class OgreRayQuery;
154  };
155  }
156  }
157 }
158 #endif
Definition: gz/rendering/base/BaseCamera.hh:47
Definition: gz/rendering/ogre/OgreCamera.hh:43
Get the far clip distance.
Set visibility mask.
Destroy render texture created by CreateRenderTexture() Note: It's not virtual.
virtual VisualPtr VisualAt(const gz::math::Vector2i &_mousePos) override
Create a render window.
Get the near clip distance.
Get the OpenGL texture id associated with the render texture used by this camera. A valid id is retur...
math::Color backgroundColor
Definition: gz/rendering/ogre/OgreCamera.hh:150
virtual void SetMaterial(const MaterialPtr &_material) override
Set the camera's aspect ratio. This value determines the cameras vertical field-of-view....
virtual void SetProjectionType(CameraProjectionType _type) override
Set the projection type for this camera This changes the projection matrix of the camera based on the...
Ogre::Camera * Camera() const
Get underlying Ogre camera.
virtual void SetProjectionMatrix(const math::Matrix4d &_matrix) override
Set the projection matrix for this camera. This overrides the standard projection matrix computed bas...
Set the level of anti-aliasing used during rendering. If a value of 0 is given, no anti-aliasing will...
Renders the current scene using this camera. This function assumes PreRender() has already been calle...
OgreRenderTargetPtr renderTexture
Definition: gz/rendering/ogre/OgreCamera.hh:148
A Ray Query class used for computing ray object intersections.
Definition: gz/rendering/ogre/OgreRayQuery.hh:41
Definition: gz/rendering/ogre/OgreScene.hh:41
Generates a selection buffer object for a given camera. The selection buffer is used of entity select...
Definition: gz/rendering/ogre/OgreSelectionBuffer.hh:48
Enum for projection types.
Definition: gz/rendering/Camera.hh:41
