#include <OgreRayQuery.hh>
virtual ~OgreRayQuery ()
virtual RayQueryResult ClosestPoint ()
virtual void SetFromCamera (const CameraPtr &_camera, const math::Vector2d &_coord)
- Public Member Functions inherited from BaseRayQuery< OgreObject >
 Get ray direction. More...
 Get ray origin. More...
 Set ray direction. More...
 Set ray origin. More...
virtual ~RayQuery ()
 OgreRayQuery ()
- Protected Member Functions inherited from BaseRayQuery< OgreObject >
 BaseRayQuery ()
virtual void Init ()
- Protected Attributes inherited from BaseRayQuery< OgreObject >
math::Vector3d direction
 Ray direction. More...
 Ray origin. More...
ignition/rendering/base/OgreRayQuery.hh
◆ OgreRayQuery()
OgreRayQuery ( )
◆ ~OgreRayQuery()
virtual ~OgreRayQuery ( )
◆ ClosestPoint()
virtual RayQueryResult ClosestPoint ( )
Reimplemented from BaseRayQuery< OgreObject >.
◆ SetFromCamera()
