BaseRenderTexture< T > Class Template Reference
 BaseRenderTexture ()
virtual ~BaseRenderTexture ()
virtual unsigned int GLId () const override
virtual ~RenderTexture ()
virtual ~RenderTarget ()
◆ BaseRenderTexture()
◆ ~BaseRenderTexture()
◆ GLId()
unsigned int GLId ( ) const
Implements RenderTexture.
Reimplemented in Ogre2RenderTexture.
