RenderTexture Class Referenceabstract
Represents a off-screen render-texture to which cameras can render images. More...
#include <RenderTarget.hh>
virtual ~RenderTexture ()
virtual unsigned int GLId () const =0
virtual ~RenderTarget ()
◆ ~RenderTexture()
virtual ~RenderTexture ( )
inlinevirtual
Deconstructor.
◆ GLId()
virtual unsigned int GLId ( ) const
Implemented in Ogre2RenderTexture, BaseRenderTexture< T >, BaseRenderTexture< OgreRenderTarget >, and BaseRenderTexture< Ogre2RenderTarget >.
