BaseDirectionalLight< T > Class Template Referenceabstract
#include <BaseLight.hh>
virtual ~BaseDirectionalLight ()
- Public Member Functions inherited from DirectionalLight
virtual ~DirectionalLight ()
virtual ~Light ()
◆ BaseDirectionalLight()
◆ ~BaseDirectionalLight()
◆ Reset()
void Reset
◆ SetDirection() [1/2]
[in]_dirNew direction vector
Implements DirectionalLight.
Implemented in Ogre2DirectionalLight, and OgreDirectionalLight.
◆ SetDirection() [2/2]
void SetDirection ( double  _x,
double  _y,
double  _z
