Base implementation of a Capsule Geometry. More...
#include <BaseCapsule.hh>
virtual ~BaseCapsule ()
 Clone the geometry. More...
virtual double Length () const override
 Get the length of the capsule. More...
virtual double Radius () const override
 Get the radius of the capsule. More...
virtual void SetLength (double _length) override
 Set the length of the capsule. More...
virtual void SetRadius (double _radius) override
 Set the radius of the capsule. More...
- Public Member Functions inherited from Capsule
virtual ~Capsule ()
 BaseCapsule ()
bool capsuleDirty = false
 Flag to indicate capsule properties have changed. More...
double length = 0.5
 Length of the capsule. More...
double radius = 0.5
 Radius of the capsule. More...
template<class T>
class ignition::rendering::BaseCapsule< T >
◆ BaseCapsule()
BaseCapsule
◆ ~BaseCapsule()
~BaseCapsule
◆ Clone()
GeometryPtr Clone ( ) const
Clone the geometry.
The cloned geometry.
Implements Geometry.
References Scene::CreateCapsule(), and ignerr.
◆ Length()
double Length ( ) const
Implements Capsule.
◆ Radius()
double Radius ( ) const
Implements Capsule.
◆ SetLength()
void SetLength ( double  _length)
Implements Capsule.
◆ SetRadius()
void SetRadius ( double  _radius)
Implements Capsule.
◆ capsuleDirty
◆ length
double length = 0.5
◆ radius
double radius = 0.5
