Geometry Class Referenceabstract
#include <ignition/rendering/Geometry.hh>
 Clone the geometry. More...
◆ ~Geometry()
virtual ~Geometry ( )
inlinevirtual
Deconstructor.
◆ Clone()
◆ HasParent()
Implemented in Ogre2Geometry, and OgreGeometry.
◆ Parent()
◆ RemoveParent()
virtual void RemoveParent ( )
Implemented in BaseGeometry< T >, BaseGeometry< Ogre2Object >, and BaseGeometry< OgreObject >.
◆ SetMaterial() [1/2]
bool  _unique = true
Implemented in BaseMesh< T >, BaseMesh< Ogre2Geometry >, BaseMesh< OgreGeometry >, BaseGeometry< T >, BaseGeometry< Ogre2Object >, and BaseGeometry< OgreObject >.
◆ SetMaterial() [2/2]
bool  _unique = true
Implemented in BaseGeometry< T >, BaseGeometry< Ogre2Object >, BaseGeometry< OgreObject >, BaseMesh< T >, BaseMesh< Ogre2Geometry >, BaseMesh< OgreGeometry >, Ogre2WireBox, Ogre2Marker, Ogre2Heightmap, Ogre2Capsule, OgreWireBox, OgreText, OgreMarker, OgreHeightmap, OgreCapsule, Ogre2Grid, and OgreGrid.
