Ogre2.x implementation of the geometry class. More...
#include <Ogre2Geometry.hh>
virtual ~Ogre2Geometry ()
virtual Ogre::MovableObject * OgreObject () const =0
virtual ~BaseGeometry ()
 Clone the geometry. More...
virtual void SetMaterial (MaterialPtr _material, bool _unique=true) override=0
 Ogre2Geometry ()
 BaseGeometry ()
virtual void Init ()
Ogre2VisualPtr parent
 Parent visual. More...
◆ Ogre2Geometry()
Ogre2Geometry ( )
◆ ~Ogre2Geometry()
virtual ~Ogre2Geometry ( )
◆ HasParent()
Implements Geometry.
◆ OgreObject()
Implemented in Ogre2WireBox, Ogre2Mesh, Ogre2Marker, Ogre2Heightmap, Ogre2Capsule, and Ogre2Grid.
◆ Parent()
the parent Visual
Implements BaseGeometry< Ogre2Object >.
◆ SetParent()
virtual void SetParent ( Ogre2VisualPtr  _parent)
[in]_parentParent visual
◆ parent
Parent visual.
