Ogre2 implementation of a wire box geometry. More...
#include <Ogre2WireBox.hh>
virtual ~Ogre2WireBox ()
- Public Member Functions inherited from BaseWireBox< Ogre2Geometry >
virtual ~BaseWireBox ()
virtual ignition::math::AxisAlignedBox Box () const
 Get the wireframe box. More...
virtual void Destroy ()
virtual void SetBox (const ignition::math::AxisAlignedBox &_box)
 Set the axis aligned box. More...
- Public Member Functions inherited from WireBox
virtual ~WireBox ()
virtual ~Ogre2Geometry ()
virtual ~BaseGeometry ()
 Clone the geometry. More...
 Ogre2WireBox ()
 Set material to wire box geometry. More...
- Protected Member Functions inherited from BaseWireBox< Ogre2Geometry >
 BaseWireBox ()
- Protected Member Functions inherited from WireBox
 WireBox ()
 Ogre2Geometry ()
 BaseGeometry ()
- Protected Attributes inherited from BaseWireBox< Ogre2Geometry >
ignition::math::AxisAlignedBox box
bool wireBoxDirty
 Flag to indicate WireBox properties have changed. More...
Ogre2VisualPtr parent
 Parent visual. More...
◆ Ogre2WireBox()
Ogre2WireBox ( )
◆ ~Ogre2WireBox()
virtual ~Ogre2WireBox ( )
Implements Geometry.
◆ OgreObject()
Implements Ogre2Geometry.
Reimplemented from BaseWireBox< Ogre2Geometry >.
◆ SetMaterial()
bool  _unique
◆ SetMaterialImpl()
[in]_materialOgre material.
