Ogre implementation of a heightmap geometry. More...
#include <OgreHeightmap.hh>
virtual ~OgreHeightmap ()
 Returns NULL, heightmap materials don't inherit from MaterialPtr. More...
 Returns NULL, heightmaps don't have movable objects. More...
 Has no effect for heightmaps. The material is set through a HeightmapDescriptor. More...
- Public Member Functions inherited from BaseHeightmap< OgreGeometry >
virtual const HeightmapDescriptor & Descriptor () override
 Get the immutable heightmap descriptor. More...
virtual ~OgreGeometry ()
virtual ~BaseGeometry ()
 Clone the geometry. More...
 OgreHeightmap (const HeightmapDescriptor &_desc)
- Protected Member Functions inherited from BaseHeightmap< OgreGeometry >
 BaseHeightmap (const HeightmapDescriptor &_desc)
 OgreGeometry ()
 BaseGeometry ()
- Public Attributes inherited from BaseHeightmap< OgreGeometry >
HeightmapDescriptor descriptor
 Descriptor containing heightmap information. More...
OgreVisualPtr parent
◆ OgreHeightmap()
OgreHeightmap ( const HeightmapDescriptor &  _desc)
explicitprotected
◆ ~OgreHeightmap()
virtual ~OgreHeightmap ( )
Null pointer.
Implements Geometry.
◆ OgreObject()
Null pointer.
Implements OgreGeometry.
Reimplemented from BaseHeightmap< OgreGeometry >.
◆ SetMaterial()
bool  _unique
[in]_materialNot used.
[in]_uniqueNot used.
