gz/rendering/ogre/OgreHeightmap.hh
16 */
17
18 #ifndef IGNITION_RENDERING_OGRE_OGREHEIGHTMAP_HH_
19 #define IGNITION_RENDERING_OGRE_OGREHEIGHTMAP_HH_
20
21 #include <memory>
22 #include <string>
23 #include <vector>
24
28
29 // Ignoring warning: "non dll-interface class
30 // 'ignition::rendering::v5::Heightmap' used as base for dll-interface class"
31 // because `Heightmap` and `BaseHeightmap` are header-only
32 #ifdef _MSC_VER
33  #pragma warning(push)
34  #pragma warning(disable:4275)
35 #endif
36
37 namespace ignition
38 {
39  namespace rendering
40  {
41  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
42  //
43  // Forward declaration
44  class OgreHeightmapPrivate;
45
47  class IGNITION_RENDERING_OGRE_VISIBLE OgreHeightmap
48  : public BaseHeightmap<OgreGeometry>
49  {
51  protected: explicit OgreHeightmap(const HeightmapDescriptor &_desc);
52
54  public: virtual ~OgreHeightmap();
55
56  // Documentation inherited.
57  public: virtual void Init() override;
58
59  // Documentation inherited.
60  public: virtual void PreRender() override;
61
64  public: virtual Ogre::MovableObject *OgreObject() const override;
65
69  public: virtual MaterialPtr Material() const override;
70
75  public: virtual void SetMaterial(MaterialPtr _material, bool _unique)
76  override;
77
80  private: void ConfigureTerrainDefaults();
81
87  private: bool PrepareTerrain(const std::string &_terrainDirPath);
88
96  private: void UpdateTerrainHash(const std::string &_hash,
97  const std::string &_terrainDir);
98
103  private: void SplitHeights(const std::vector<float> &_heightmap,
104  int _n, std::vector<std::vector<float>> &_v);
105
109  private: void DefineTerrain(int _x, int _y);
110
115  private: void CreateMaterial();
116
119  private: bool InitBlendMaps(Ogre::Terrain *_terrain);
120
123  private: void SetupShadows(bool _enabled);
124
126  private: friend class OgreScene;
127
129  private: std::unique_ptr<OgreHeightmapPrivate> dataPtr;
130  };
131  }
132  }
133 }
134 #ifdef _MSC_VER
135  #pragma warning(pop)
136 #endif
137
138 #endif
Definition: gz/rendering/base/BaseHeightmap.hh:33
Describes how a Heightmap should be loaded.
Definition: gz/rendering/HeightmapDescriptor.hh:147
Ogre implementation of a heightmap geometry.
Definition: gz/rendering/ogre/OgreHeightmap.hh:49
virtual Ogre::MovableObject * OgreObject() const override
Returns NULL, heightmaps don't have movable objects.
virtual void SetMaterial(MaterialPtr _material, bool _unique) override
Has no effect for heightmaps. The material is set through a HeightmapDescriptor.
Returns NULL, heightmap materials don't inherit from MaterialPtr.
Definition: gz/rendering/ogre/OgreScene.hh:41
