gz/rendering/base/BaseCapsule.hh
16 */
17
18 #ifndef IGNITION_RENDERING_BASECAPSULE_HH_
19 #define IGNITION_RENDERING_BASECAPSULE_HH_
20
21 #include <ignition/common/Console.hh>
22
26
27 namespace ignition
28 {
29  namespace rendering
30  {
31  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
33  template <class T>
34  class BaseCapsule :
35  public virtual Capsule,
36  public virtual T
37  {
38  // Documentation inherited
39  protected: BaseCapsule();
40
41  // Documentation inherited
42  public: virtual ~BaseCapsule();
43
44  // Documentation inherited
45  public: virtual void SetRadius(double _radius) override;
46
47  // Documentation inherited
48  public: virtual void SetLength(double _length) override;
49
50  // Documentation inherited
51  public: virtual double Radius() const override;
52
53  // Documentation inherited
54  public: virtual double Length() const override;
55
56  // Documentation inherited
57  public: virtual GeometryPtr Clone() const override;
58
60  protected: double radius = 0.5;
61
63  protected: double length = 0.5;
64
66  protected: bool capsuleDirty = false;
67  };
68
70  // BaseCapsule
72  template <class T>
74  {
75  }
76
78  template <class T>
80  {
81  }
82
84  template <class T>
85  void BaseCapsule<T>::SetRadius(double _radius)
86  {
87  this->radius = _radius;
88  this->capsuleDirty = true;
89  }
90
92  template <class T>
93  double BaseCapsule<T>::Radius() const
94  {
95  return this->radius;
96  }
97
99  template <class T>
100  void BaseCapsule<T>::SetLength(double _length)
101  {
102  this->length = _length;
103  this->capsuleDirty = true;
104  }
105
107  template <class T>
108  double BaseCapsule<T>::Length() const
109  {
110  return this->length;
111  }
112
114  template <class T>
116  {
117  if (!this->Scene())
118  {
119  ignerr << "Cloning a Capsule failed because the capsule to be "
120  << "cloned does not belong to a scene.\n";
121  return nullptr;
122  }
123
124  auto result = this->Scene()->CreateCapsule();
125  if (result)
126  {
127  result->SetRadius(this->Radius());
128  result->SetLength(this->Length());
129
130  if (this->Material())
131  result->SetMaterial(this->Material());
132  }
133
134  return result;
135  }
136  }
137  }
138 }
139 #endif
Base implementation of a Capsule Geometry.
Definition: gz/rendering/base/BaseCapsule.hh:37
Get the length of the capsule.
Definition: gz/rendering/base/BaseCapsule.hh:108
BaseCapsule()
Definition: gz/rendering/base/BaseCapsule.hh:73
Clone the geometry.
Definition: gz/rendering/base/BaseCapsule.hh:115
Definition: gz/rendering/base/BaseCapsule.hh:79
Set the radius of the capsule.
Definition: gz/rendering/base/BaseCapsule.hh:85
Set the length of the capsule.
Definition: gz/rendering/base/BaseCapsule.hh:100
Get the radius of the capsule.
Definition: gz/rendering/base/BaseCapsule.hh:93
Geometry for a capsule shape.
Definition: gz/rendering/Capsule.hh:34
Definition: gz/rendering/Material.hh:49
Definition: gz/rendering/Scene.hh:50
virtual CapsulePtr CreateCapsule()=0
Create new capsule geometry.
#define ignerr
